RE: Right side of trailer lights not working?
All Forums >> [Most Popular Discussions] >> The MUD Hole >> RE: Right side of trailer lights not working? Page: <<   < prev  1 [2] 3   next >   >>
RE: Right side of trailer lights not working? - 9/9/2008 11:47:09 PM
1bigforeman
My 07 tahoe has seperate running light for truck, blinker light for truck, running for trailer, and blinker for trailer. They are all under the hood. They have a seperate fuse block in the truck for inside truck wiring. If you have a meter, check each fuse in both if you aren't sure. My guess though, is the bulb. Swap the bulb with the other side and see if it follows. If it stays on that side and works on the other side, it is the wiring of the trailer or a fuse. Start narrowing things down.
2007 Camo Brute 750
2" HL Lift Kit
28" Outlaws with 12" ITP SS112's
Maroon Primary/Almond Secondary
HMF Exhaust
Moose CDI
Warn 2.5 RT
HlRadiator Relocated with Engince Ice
Highlifter Diamond Plate Front
Ricochet Skids
UNI Air Filter
Center Snorkels
Dynojet Jet Kit
Ammo Box Storage
http://www.myspace.com/JohnnieRubio
05 Honda Rancher (Mom's)
05 Foreman 500 (Sold)
02 Raptor 660 (Sold)
99 400EX (Sold)
91 Fourtrax 200 (Katrina Killed)
(in reply to Foulplay)
Post #: 31
RE: Right side of trailer lights not working? - 9/10/2008 12:53:44 AM
Foulplay
ORIGINAL: 1bigforeman
Correct. However on newer model vehicles, they started putting even more fuses than that. They started putting the trailers left turn signal on one fues and the trailers right turn signal on another. Totally seperate from the towing vehicles turn signal fuse.
'06 Popo 800 EFI on 29.5" Outlaws
'05 Popo 700 carb on 29.5" Outlaws
'07 Popo 500 H.O. EFI (hers) on 27" Outlaws
'78 Jeep CJ-7 w/304 V8
http://s125.photobucket.com/albums/p44/Foulplay_photo/
This Honda's gone...
http://video.yahoo.com/watch/341841/2183512
(in reply to 1bigforeman)
Post #: 32
RE: Right side of trailer lights not working? - 9/10/2008 7:32:46 AM
Kawa650
Well if he turns the right side turn signal on, get a test light and and check the plug on the truck for a blinking light then that will tell him if it is the truck or trailer. But I would bet (since he said it did it on two different vehicals) its the trailer bad connection somewhere or the bulb/light itself, people make working on trailer lights harder than it really is. Good luck!!!
07' Silver Brute Force 650i
2" HL lift
Supertrapp Mudslinger
Moose module
MIMB snorkels
Dynojet jet kit
K&N & outerwears prefilter
3500 viper max winch
HL pen-lock
Ride N' Rest backrest
1.5" spacers
EBC severe duty pads
Highlifter XL2 12x7
Outlaw 29.5x10 & 12
Swamp Fox 28x9 & 12
New MudInMyBlood Forum
Post #: 33
RE: Right side of trailer lights not working? - 9/10/2008 7:50:59 AM
rzrdawg
You know, it seems like if some folks could or would read the post thoroughly , They would have seen He said It was a Toyota truck , and that It does the same thing on two different trucks. Now foulplay , you still think its a freakin fuse? I bet thats you answer to everything, I got a rod knocking,better check my fuses, haha. This poor fellow is prolly all confused as to what his problem really is now. Anyway, I think he now has enough info to get his problem fixed. Good luck on getting the lights fixed.
2008 Polaris RZR, HMF Dual Exhaust, 3" Lift, HL Springs,
30" Mudzilla's w/ 2" wheel spacers , 3000lb winch, Fender Flares, J-Strong hardtop, Kenwood Deck, 500watt Kenwood amp with 2-10" Rockford Fosgate subs.
" TEAM LET IT EAT "
(in reply to little grasshopper)
Post #: 34
RE: Right side of trailer lights not working? - 9/10/2008 7:58:49 AM
C1iffBurton
whats it mean when the running lights work fine and the brake lights work but then when u hit the left or right blinker they both flash like caution lights?  is that wiring wrong somewheres along the way?  ive pulled other trailers before and they worked fine so its not anything to do with my truck, its the wiring on the trailer but i have checked it and still does the same thing
any ideas?
MINE*08 big bear 400, 27" skinny outlaws, CRSbear custom snorkel, Gumbo03 custom lift, oil cooler relocated, fan switch, audiopipe, viper 2500 max
--TEAM ANYTING GOES RACING--
R.I.P. JAYSON MATTHEW PARKER
Post #: 35
RE: Right side of trailer lights not working? - 9/10/2008 8:13:05 AM
rzrdawg
Check your fuse, hahahaha. No really,  It does sound like the lights on the trailer are just wired different than your truck. Switch some wires around on the trailer at the plug till you get it right, or a 12 volt test light would make it easier and faster. I would first check it at the trucks plug first with a test light and see if it does it , then go from there.
< Message edited by rzrdawg -- 9/10/2008 8:15:50 AM >
" TEAM LET IT EAT "
(in reply to C1iffBurton)
Post #: 36
RE: Right side of trailer lights not working? - 9/10/2008 9:14:13 AM
Big_T
Cliff, that is often caused by a bad ground.  Sometimes if a ground is not present it will complete the circuit through the other hot wire (I know it seems odd) but when both are on it causes erratic behavior.
Make sure everything is wired right as well.  If you have a round plug the wire colors mean different things than if you have a flat plug.
Split audiopipe (self built)
Heelclicker
(in reply to rzrdawg)
Post #: 37
RE: Right side of trailer lights not working? - 9/10/2008 9:23:01 AM
C1iffBurton
yea i hear yah
well the trailer is a flat plug, ill check into it this weekend, i bet ur right it is the ground on the trailer, ill look into it and get it figured out
thanks for the help
(in reply to Big_T)
Post #: 38
RE: Right side of trailer lights not working? - 9/10/2008 11:29:16 AM
Scooped_Kawasaki
A loose or bad ground can cause all kinds of weird things to happen. I always hook up the white wire ( on a 4 wire flat plug ) directly to the trailer frame somewhere. Using the ball for a ground is asking for trouble. Also it doesn't hurt to use some dialectric grease inside the brass holder that holds the bulb.
  • 04 Kawasaki 700
  • Radiator relocated
  • Hand crafted hood scoop
  • H/L 1" lift kit and springs
  • Stainless dry storage keg
  • 2"Spring spacers
  • Custom receiver hitch
  • 1.5" Spacers
  • 29.5 Laws
    If you find yourself in a fair fight, your tactics suck.
  • Post #: 39
    RE: Right side of trailer lights not working? - 9/10/2008 1:12:13 PM
    kodiak660
    When building trailers I never use the frame as the ground.
    I always run ground wires to all the lights from the trailer plug.
    Video
    07 Honda 420 Rancher ES 4x4
    06 Outlander 800 XT 2,900 miles (sold)
    03 Grizz 5,000 miles (sold)
    01 Rancher 5,800 miles (sold)
    00 Kodiak 7,500 miles (sold)
    94 Warrior 6,500 miles (sold)
    (in reply to Scooped_Kawasaki)
    Post #: 40
    RE: Right side of trailer lights not working? - 9/10/2008 2:44:00 PM
    Scooped_Kawasaki
    ORIGINAL: kodiak660
    An excellent idea when it's being built. I do the same thing. After the fact on an old trailer it's still the best way to do it but the white wire to the frame beats using the trailer ball for a ground any day of the week.
  • 04 Kawasaki 700
  • 2"Spring spacers
  • 1.5" Spacers
  • 29.5 Laws
    (in reply to kodiak660)
  • Post #: 41
    RE: Right side of trailer lights not working? - 9/10/2008 3:13:42 PM
    kickaskey
    the rust on the ball shouldnt matter because you have a ground on ur trailer plug that plugs into the truck.  i build trls for a living and the fuses are the problem 99% of the time.  as far as fords and dodges they have seperate left and right trl lgt fuses in them and if the truck lgts are working it doesnt mean your trl lgts should. the easiest way to check it would be to grab a batt charger and ground it to the trl and touch the red to each of the 3 prongs on the plug.  the brown should light the whole trl up, the green should be the right side, and the yellow should be the left side.  if it works its not your trl and something on your truck.  prolly just a fuse.
    2007 red rhino, 2in HL lift, custom stereo, 27" XTRs w/ 14" ITP, 4500 Venom winch, rear bumper with lgts, diamond plate switch panel, custom lgt bar with 4 6" hella lgts, console w/ storage
    Post #: 42
    RE: Right side of trailer lights not working? - 9/10/2008 3:23:37 PM
    Scooped_Kawasaki
    ORIGINAL: kickaskey
    Assuming the white wire on the trailer side of the plug is either ran all the way back to the lights or it is attached to the frame, you are correct. If neither one of those conditions exist, rust on the ball makes all the difference in the world as for as trailer light performance is concerned.
  • 04 Kawasaki 700
  • 2"Spring spacers
  • 1.5" Spacers
  • 29.5 Laws
    (in reply to kickaskey)
  • Post #: 43
    RE: Right side of trailer lights not working? - 9/10/2008 3:27:30 PM
    slowoldhonda
    You could have a bare wire touching the trailer somewhere or you could have a light on that side of the trailer that has an issue. Trace the wires good. Take the covers off of the lights and check them good.
    I can't make it through there, I'm going around.......
    Post #: 44
    RE: Right side of trailer lights not working? - 9/10/2008 3:48:20 PM
    kodiak660
    I'm not sure on the newer Toyota but on the older toyota's you had to use a Trailer Light Taillight Converter.
    Maybe the new one has this and it has gone bad.
    Looks like this.
    http://www.autoaccessconnect.com/untaco5amp.html
    Video
    (in reply to slowoldhonda)
    Post #: 45
    RE: Right side of trailer lights not working? - 9/10/2008 4:21:56 PM
    kodiak660
    ORIGINAL: rzrdawg
    If that circuit on the trailer has a short its going to do the same thing on every truck he plugs it into.........it will blow that fuse.
    Thats what fuses do......thats why they are there.......to let you know you may have a problem.
    Video
    Post #: 46
    RE: Right side of trailer lights not working? - 9/10/2008 6:45:46 PM
    Jake450s
    Lots of info in this post, but break down what's here and make it simple--
    Parking lights work, one brake light works, the other diesn't.  One blinker works, one doesn't.  That's one wire or one light bulb.
    The truck is a Toyota, so it uses a converter box.  That rules out anywhere else on the truck including separate fuses on trucks that are so equipped (which this one is not).  So the wiring issue is between that box and the trailer plug (the pigtail on the truck) or on the trailer wiring, or again, the bulb.  Pretty easy to chase.  Start witht the bulb.  It's the bulb or the green wire's broken somewhere.
    ORIGINAL: coyote170
    For what its worth my ball was real rusty put a new one on took care
    of the problem,the ground thru the ball is important,good luck.
    That's not correct.  The ground through the ball is not important, and is intermittant at best on a good day.  It switches on and off every time you hit a bump.  It is not present at all on brand new hitches with paint still on them.  You have a wiring fault, and your lights are flashing like crazy from bright to dim, left to right, sometimes with the tow vehicles directionals, sometimes opposite, sometimes complete stealth mode...  You really should fix the ground wire.
    (in reply to duckman06)
    Post #: 47
    RE: Right side of trailer lights not working? - 9/10/2008 7:00:25 PM
    rkw38
    ORIGINAL: Foulplay
    ORIGINAL: bustedknuckles
    So are you saying that toyota does not have seperate fuses for trailer lights? All the other brands do now, it seems odd that they don't.
    No one is saying that Toyota's do not have seperate fuses. We are simply saying that most newer model trucks have seperate fuses so the Toyota's most likely do as well.
    My '01 Tacoma has separate fuses for the trailer lights. I am sure Tundras are separate too.
    High Lifter Pro Staff Member...
    2003 Yamaha Grizzly 660
    High Lifter full skid plate package
    Ramsey 2500# winch
    27 " Zillas on HL XL-2's
    26" Outlaw MST's on type 4 C Series wheels.
    God Bless the United States Armed Forces.
    You keep us free. Freedom is not free!!!!!!!
    Post #: 48
    RE: Right side of trailer lights not working? - 9/11/2008 12:50:25 AM
    Foulplay
    ORIGINAL: Jake450s
    When a vehicle has a seperate turn signal from the tail light (most commonly the amber turn signal and red tail light) it will use a converter box. It is converting it from a three wire system to a two wire system. That doesn't mean that it won't have fuses under the hood for the trailer lights which is part of the towing package. Trailer lights are no longer just spliced into the tail lights any more like they once were. You can fry the electrical system of a vehicle doing that these days. Check what it cost to have trailer wiring put on a mid 90's Jeep Grand Cherokee and similar year model Ford Explorer. Times have changed and so have the vehicles that we drive!
    (in reply to Jake450s)
    Post #: 49
    RE: Right side of trailer lights not working? - 9/11/2008 1:11:15 AM
    POPO800EFI
    I have a goood ole 4 pin connector on my trailer so it is pretty easy to repair
    2007 Polaris 800EFI
    29.5 Outlaws 10 Front 12 Rear
    Vision Buckshot Deepdish 12X8 Rims
    3 Inch Puck Lift Front
    EPI 140# Rear Springs
    1 Inch Rear Spacers
    AAEN Mega Power Pipe
    K&N
    Rear Rack Extender
    Rear Rack Plate From Triangle ATV
    Rear Seat From Triangle ATV
    Ammo Cans
    Igloo Cooler
    2004 Yamaha Big Bear 400 4X4 SOLD!!!
    504 miles
    2 inch lift
    26" ITP 589's 9 in front 12 in rear
    dynojet kit
    K&N
    HMF utility
    high lifter extreme clutch kit
    fully snorkele
    Post #: 50
    RE: Right side of trailer lights not working? - 10/17/2008 11:36:27 PM
    duckman06
    I got a chance to work on it today.  I found the ground from the wiring connection from the trailer had rusted & I redone it.  Now everything is working like it should for now.
    You have to pay to Play!!! Play hard or don't play at all!!! Everything happens for a reason!!! I work hard but play even Harder!!!
    06 Rancher E.S. 4x4, with 2 inch lift, H/L springs, Jet Kit, K&N air filter, clutch kit, F/R Snorkel, HMF pipe, front brake kit, Warn 424, 26 inch Outlaws MST's on rims, Rule winch, ball hitch lift, Audio Formz Radio.
    07 Big Bear 4x4, 2 inch lift, 27inch 589's, ITP Rims, H/L Springs, Jet Kit, Clutch Kit, Snorkel, HMF Pipe, K&N air filter, Warn Winch
    (in reply to POPO800EFI)
    Post #: 51
    RE: Right side of trailer lights not working? - 10/18/2008 9:04:30 AM
    BigCountry500
    ORIGINAL: ubba Aldridge
    What rzrdawg is saying is, if the lights are working on the truck as he stated. Then the fuses are good, regaurdless if has 1, 2 or 10 fuses. The problem has to be in the trailer wiring or bulb. The rust on ball has nothing to do with it as the other lights are getting a ground.
    That is incorrect for many newer trucks. I know for a fact late model Fords, Dodges, and Chevrolets have  seperate fuses for trailer lights. Check your owners manual.
    My ford, which had the same problem with trailer lights, has a left towing fuse and a right towing fuse. It'll show you in the owners manual where these are if your truck has them.
    2006 HONDA FOREMAN 500ES
    27" KENDA EXECUTIONERS
    ITP SERIES 12 RIMS
    J&B CUSTOM SNORKLE
    WARN 2.5 WINCH
    (in reply to bustedknuckles)
    Post #: 52
    RE: Right side of trailer lights not working? - 10/18/2008 2:10:02 PM
    doublerinnys
    This has happened to me with several trailers. On my truck, left side stop and turn and right side stop and turn are seperate fuses. Get your owner's manual out and find the fuse panel chart. It will show you where each fuse is and what it controls. Find that fuse and check it. I'm about 99.9% sure that's the problem. As many times as this has happened to me, I can count on that as the problem.
    07 Rancher manual, black SS212's, 26" swamplites
    2000 Mazda truck
    "I am in shape, round is a shape"
    Post #: 53
    RE: Right side of trailer lights not working? - 10/18/2008 10:47:44 PM
    BrootGoot
    same thing happened to my 07 Tundra and it was the fuse.  tundras have  separate fuses for the trailer connections.  ground ? hmmm.  lol...but it took a while for me to find the right fuse...
    btw i meant : SAME THING HAPPENED
    2008 Team Green KFX 450r
    2007 Honda Recon ES (codename "Big Red")
    WEAR A HELMET
    (in reply to doublerinnys)
    Post #: 54
    RE: Right side of trailer lights not working? - 10/19/2008 12:46:46 AM
    duckman06
    It is working fine now on my 08 Tundra but not working right on wife's 04 Xterra.  I don't have right right side blinker with the Xterra?
    (in reply to BrootGoot)
    Post #: 55
    RE: Right side of trailer lights not working? - 10/19/2008 7:23:01 AM
    Jake450s
    ORIGINAL: duckman06
    Keep an eye on it.  The ground is common to the lights on both sides.  It should have affected both sides.  I bet something else close by has an intermittant connection and just got wiggled a little during the process...
    Post #: 56
    RE: Right side of trailer lights not working? - 11/25/2008 11:01:36 PM
    duckman06
    What does it mean when put on 1 side or the other of the blinkers & both blink?  I am now having this problem?  Any ideas?
    Post #: 57
    RE: Right side of trailer lights not working? - 11/26/2008 6:47:00 AM
    Scooped_Kawasaki
    You have a bad ground.
  • 04 Kawasaki 700
  • 2"Spring spacers
  • 1.5" Spacers
  • 29.5 Laws
  • Post #: 58
    RE: Right side of trailer lights not working? - 11/26/2008 10:08:41 AM
    duckman06
    I noticed that my ball was really rusty.  I will have to clean it off.  That is also what I was thinking about the ground but don't think it is the 1 on my trailer because everything else works fine.  I just hope it is the ball on my truck?
    Post #: 59
