RE: What have you broke??
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> RE: What have you broke?? Page: <<   < prev  1 [2]
RE: What have you broke?? - 10/1/2008 10:15:40 PM
Swamp Star
ORIGINAL: EAMay
I hope I dont have the same problems SWAMP STAR has with EDGE boxes.
dont worry if you do they will take care if it they have never done me wrong and i feel ya on the trans stuff when i tore 6th outta my NV5600 i got about a coat pocket of parts and it was $1100
02 Grizz 660
28" Mudzillas
ITP type 4 wheels
HL 2" front lift
Fliped Spindels rear
HL belt
HL Super Duty Outlaw clutch kit
FMF Powerline (want a HMF you got one?)
DynaJet jet kit
Pro Flow
K&N
Bayou Snorkels trans and air box
4 easily broken Monkey's
Radiator Relocated
Shes always down but never OUT
03 YZ250F
FMF Titanium 4 full
Triple clamps
Renthal bars
01 Dodge 3500 6x6
Cummins
6-speed
450 rwhp but still not enough
(in reply to EAMay)
Post #: 31
RE: What have you broke?? - 10/2/2008 7:01:18 PM
HondaGuy
ORIGINAL: Rinny650
The only starters I have found are the MSD super starter or something like that. I thought a C4 was the heavy duty auto tranny that ford made to go behind the 460 longblocks?
No the C4 is the three speed auto that went behind the small blocks, the C6 is the three speed auto that was behind the Big Blocks and Cleveland small blocks. Both are stong trans when properly built and can be made full manual, relatively inexpensive, in either foreward or reverse shift pattern.
I thought I was wrong once, but I was mistaken.
Supertrapp Mudslinger
HL EPI Clutch Kit
Relocated Radiator
Permacool 8" electric fan (covers the whole radiator)
12x7 ITP C Series Type 5 wheels
27in Bi/Tri Claw Magnum combo
Mud guard fender flares A-arm skid plates
88 Yamaha Banshee red and grey
stockish
21" Mud Sharks
(in reply to Rinny650)
Post #: 32
RE: What have you broke?? - 10/3/2008 11:16:19 AM
Dock Rocker
ORIGINAL: Rinny650
I have been running my built 302 with a T4 4speed behind it and I can tell it doesnt like the power. My clutch disks are wearing out faster than anything remotely normal. My starters arent handling the compression either. Anybody got any suggestions?
Get a good high torque starter and make sure that you do everything you can to keep the heat of the manifolds off of it.  Heat will kill your starters ability to start.  Also check your ground and make sure that you have big enough cable going to your starter.  If you are having a voltage drop that will help.
Post #: 33
RE: What have you broke?? - 10/3/2008 4:49:22 PM
Swamp Star
my brother had i think it was a CVR high tourge startor in his 55 ford with a built 350 bowtie in it but it would crank even after the main bearing seized up so it was deffinatly a good startor
02 Grizz 660
28" Mudzillas
ITP type 4 wheels
HL 2" front lift
HL belt
DynaJet jet kit
Pro Flow
K&N
Radiator Relocated
03 YZ250F
FMF Titanium 4 full
Triple clamps
Renthal bars
01 Dodge 3500 6x6
Cummins
6-speed
(in reply to Dock Rocker)
Post #: 34
RE: What have you broke?? - 10/4/2008 8:47:35 AM
Rinny650
My starter has no ground cable. Just a pos+
Team C.I.C.
2004 F-150
6" Fabtech
2" Daystar
36x12.50x18 Baja Claws
1984 Ranger 5.0
302ci bored
6" superlift
33x12.50x15 TSL's
Previous Quads
2004 V-force 900cc, 26" Skat Trak Haulers
2005 Rincon 702cc,GR, 26x12 Laws
2007 Popo Sportsman,28x9.5 Laws
2002 Foreman, GR, 475 BBK, 27x12.5 Laws
2000 Rancher, 25x12.50 TSl swampers
1989 Bayou 22" wooly boogers
(in reply to Swamp Star)
Post #: 35
RE: What have you broke?? - 10/15/2008 2:36:08 AM
nonnieselman
Thats cause it is grounded through the body of the starter to the engine block :D
2005 Red Foreman 4x4 S
-Rubi Rims w/ 26" MST
2000 Silverado ECSB
LQ4 4L80E STS Nitrous
Post #: 36
RE: What have you broke?? - 10/15/2008 7:10:36 PM
Rinny650
Yeah I found that out after I looked at it again. Any idea how much it should cost to rebuild my T4?
Team C.I.C.
2004 F-150
6" Fabtech
2" Daystar
1984 Ranger 5.0
302ci bored
6" superlift
33x12.50x15 TSL's
Previous Quads
(in reply to nonnieselman)
Post #: 37
RE: What have you broke?? - 10/18/2008 11:16:13 PM
GoiNdEEp24/7
80 cj-7
.blew the stock 304 amc motor and when i say blew i mean blew 3 rods outta the side of the block!
.trashed out t156 trans
.put a drive shaft thru the floor boards
.sheared about 12 teeth off the rear ring gear.
.ripped a pass rim off the hub
.rolled the jeep and spring creek offroad park
05 titan
.2 transmissions
.blew the rearend apart
.ripped 2 22in rims off the passenger side of the truck.
04 dodge ram 2500 cummins
CANT KEEP BOOST HOSES ON IT! something about 100psi of boost is to much...... i dunno what they are talking about. lol
TEAM 4 PLAY!
07 raptor 700se
+2 arms, holeshots, stage 4 trinity kit.(For Sale)
04 honda rubicon
Lifted, Cut, 30in zillas, hmf, k&n, jet kit, clutch kit
04 Artic Cat 400
581bbk, lift, trans work, 28in laws
04 cummins 4dr 2wd
700hp, 1300ft lbs, 12 sec 1/4 mile, lowered, smokes like a train!
80 jeep cj7
lifted, locked, 35's, 500hp sbc
88 cherokee
lifted..... (work in progress)
Post #: 38
RE: What have you broke?? - 10/19/2008 10:03:49 PM
HondaGuy
Thats too much?!
HL EPI Clutch Kit
Relocated Radiator
stockish
21" Mud Sharks
(in reply to GoiNdEEp24/7)
Post #: 39
RE: What have you broke?? - 10/20/2008 5:34:28 PM
GoiNdEEp24/7
lol thats what im sayin! but apparently no1 agrees lol.
TEAM 4 PLAY!
07 raptor 700se
04 honda rubicon
04 Artic Cat 400
04 cummins 4dr 2wd
80 jeep cj7
88 cherokee
(in reply to HondaGuy)
Post #: 40
