RE: gutt less cat
RE: gutt less cat
All Forums >> [OEM Discussions] >> Arctic Cat >> RE: gutt less cat Page: <<   < prev  1 [2]
RE: gutt less cat - 8/24/2008 10:23:37 PM
TWS
sound like a glasspack on a truck, think i,m ok there
(in reply to GWC)
Post #: 31
RE: gutt less cat - 8/24/2008 11:06:39 PM
oilfieldbeggar
I would try getting a DJ kit. These come w/h a needle also to go with your new jet. IMOP you kinda shoot yourself in the foot with just a jet, no needle. The 2" snorkle will help considerably. horsepower is air in/air out. you got air out, lets try in.
As for the differences in bikes, I can lineup w/h my bro. He leaves me EVERYTIME. We bought our bikes a week apart from the same dealer. only diff is color "supposedly"! My Dynatek will not fit in his bike though. Not quite sure what the diff is YET!! But definitely looking.
2" sneak snorkle,
Djet w/h 148 and 42
all the free mods listed so far
sweedwerx pipe
"Puck-lift installed"
Dynatek, drilled rollers
Da Purple springs installed!!
29.5 S/Lites on Type 7's
clip on 3, 4 curls on spring
(in reply to TWS)
Post #: 32
RE: gutt less cat - 8/25/2008 10:50:50 AM
doober
When did they start making a dynatech for the H1?
(in reply to GWC)
Post #: 33
RE: gutt less cat - 8/25/2008 12:37:13 PM
oilfieldbeggar
Same as the prowler!
2" sneak snorkle,
Djet w/h 148 and 42
sweedwerx pipe
(in reply to doober)
Post #: 34
RE: gutt less cat - 8/25/2008 7:57:30 PM
Jason
if your looking for speed you may want to get another bike.before mods and stock tires mine would only run 51 to 53 than it was hitting the rev limiter.i put 27'' tires on it would hit 55 thats being clocked by car behind me.
08 650 h1
27'' swamp lites
snorkels
jetted
slide mod,clipped spring
speedwerxs pipe
secondary mod
(in reply to TWS)
Post #: 35
RE: gutt less cat - 8/25/2008 9:15:50 PM
TWS
well i,  changed jets went back to 40 pilot and 145 main, helped a little, than i put stock cdi back in and it came alive, when the tires would hookup the wheelies were big and long. still needs clutch work not working right should pull harder from 20 - 30 mph top end went to 55. checked vents both where clear, need to find snorkel kit and suggestions???  is there any that don't go up so for ,i don't usually dive in that deep anymore paid that price.. or is there a different airbox that is better out there?? what it the difference between dj needle ,what do the notches do?? ant other mod i could do??
(in reply to Jason)
Post #: 36
RE: gutt less cat - 8/25/2008 9:19:55 PM
bustedknuckles
Snorkel Kit?
$50 worth of pvc at lowe's....
click here and buy my suburban
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
(in reply to TWS)
Post #: 37
RE: gutt less cat - 8/25/2008 9:20:24 PM
I would make your own snorkels, the dyno jet needle is WAY better then the stock needle is way better.
if you just ran some hinden snorkels in 2" for more air that would help as well, there is a post in the helpful links at the top of the page that will show you how to do snorkels.
list off everything you have again..  i keep hearing that the dyna tech for the 650H1 does not work well for some reason..??????
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to TWS)
Post #: 38
RE: gutt less cat - 8/25/2008 9:23:34 PM
bustedknuckles
Dyno Jet needle really woke mine up.
There's also a link to the free secondary clutch mod, well almost free, you will need to make a tool. $15 at the most. This mod will really increase your low end acceleration.
"APE AXLE"
STEELHORSES
CATVOS
08 ThunderCat
08 650H1
(in reply to GWC)
Post #: 39
RE: gutt less cat - 8/25/2008 9:26:20 PM
TWS
amr racing coil, epi clutch kit, k&n filter, hmf exhaust, jetted(will be putting a dj kit in if they help that much), 26" mudlites w/alum rims.
(in reply to GWC)
Post #: 40
RE: gutt less cat - 8/25/2008 9:32:30 PM
I had to buy the jet kit for mine, with the stock jet needle my bike had a bad stumble and the Dyno needle took it clear out and it runs great now.
only thing i have other then you is the 4.0 gears and they do help with getting the fat cat moving faster but will cut some top speed down.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to TWS)
Post #: 41
RE: gutt less cat - 8/25/2008 9:38:50 PM
truponycar2
Mine has that stumble just off idle.  I've tried everything but a DJ needle.  Can I buy just the needle?
'07 AC 500 Auto
2500# Warn Winch
Front Brush Guard
Rear Bumper
Carb Slide Mod
Exhaust Mod
27x10x12 & 27x12x12 Mud Bugs
Clutch Mods
(in reply to GWC)
Post #: 42
RE: gutt less cat - 8/25/2008 9:43:49 PM
nope they wont sell just the needle  they know no one would buy the whole "kit" then, i figured i pay $50 for a needle becuase i still had to buy bigger jets because they wont put big enough jets in there kits
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to truponycar2)
Post #: 43
RE: gutt less cat - 8/25/2008 9:52:40 PM
truponycar2
That sucks!!!!
'07 AC 500 Auto
2500# Warn Winch
Front Brush Guard
Rear Bumper
Carb Slide Mod
Exhaust Mod
Clutch Mods
(in reply to GWC)
Post #: 44
RE: gutt less cat - 8/25/2008 9:55:01 PM
yeap $50 buck from HL cheaper then buying it from dyno jet for some reason..?
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 45
RE: gutt less cat - 8/25/2008 10:04:38 PM
oilfieldbeggar
I got lucky, picke dmine up at NATS for $40. But still had to go w/h the 48 jet. a little extra!
2" sneak snorkle,
Djet w/h 148 and 42
sweedwerx pipe
(in reply to GWC)
Post #: 46
RE: gutt less cat - 8/26/2008 8:50:31 AM
TWS
will that secondary clutch mod do anything ?? the EPI clutch kit had mods for both secondary and primary included. ordered dj kit today.
(in reply to oilfieldbeggar)
Post #: 47
RE: gutt less cat - 8/26/2008 9:03:15 AM
you dont want to do the secondary mod if you have the EPI kit in there allready, it makes the rear spring alot tighter, but your after market spring allready does this.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to TWS)
Post #: 48
RE: gutt less cat - 8/26/2008 9:11:17 AM
TWS
thanks for all the help everyone
(in reply to GWC)
Post #: 49
