RE: mimb snorkel ?
RE: mimb snorkel ?
All Forums >> [OEM Discussions] >> Kawasaki >> RE: mimb snorkel ? Page: <<   < prev  1 2 [3]
RE: mimb snorkel ? - 9/5/2008 9:36:03 AM
Blue Falcon
I have three holes in my air box on my 06 brute 750i, one is in the inner part of the box (near the two carb openings)
there is two more holes on the right side of the air box (if sitting on it) one towards the front of the box and one towards the rear.
what are all these holes for?????
the one near the front appears to just dump out into the bottom of the bike, there is no tubes connected to this
06 Brute Force 750 - camo
27" ITP Mudlite XTRs on 14" ITP C-Series Type 7 wheels
Moose module
Warn - 2500 lb
(in reply to irideasv6)
Post #: 61
RE: mimb snorkel ? - 9/5/2008 10:02:47 AM
burglett
did u run ur vent lines up
07 650i
27" xtrs on 14" ss112
LRD Torc exhaust
MIMB Snorkels
Post #: 62
RE: mimb snorkel ? - 9/5/2008 10:12:57 AM
outlawbro
there should only be two small hole one is under your airfilter next to you carbs that is the crankcase vent. the other one is to the right that is the airbox drain you should plug that up if you are snorkeling
05 BRUTE FORCE 750, 2" HL LIFT, HL SPRINGS, CENTER SNORKELS, DYNATEK, K&N, 8000K HID's
THE LOANER/HUNT BIKE
06 Honda Foreman 500
ALL STOCK
05 DODGE RAM 3500 5.9 CUMMINS
WITH SOME GOODIES ON IT : )
AND BLACKED OUT
I-6 CUMMINS GUYS ARE KEEPIN' IT STRAIGHT. THOSE OTHER BOYS SWING BOTH WAYS
http://www.myspace.com/argentineexc
(in reply to burglett)
Post #: 63
RE: mimb snorkel ? - 9/5/2008 10:56:57 AM
Blue Falcon
i just took it all apart and for some i reason i have a third hole, it has about a half inch opening and connects to a small rubber piece only about 2 inches long that flattens on the other end and has a small slit opening.....im guessing for water to drain ???
Moose module
Warn - 2500 lb
(in reply to outlawbro)
Post #: 64
RE: mimb snorkel ? - 9/5/2008 10:58:57 AM
outlawbro
yea thats the airbox drain where are the other ones at?
ALL STOCK
AND BLACKED OUT
(in reply to Blue Falcon)
Post #: 65
RE: mimb snorkel ? - 9/5/2008 10:59:28 AM
burglett
put silicone in that or buy some 5/8 hosr bout 12" and put one ot those plactic drain valves on it
07 650i
LRD Torc exhaust
MIMB Snorkels
Post #: 66
RE: mimb snorkel ? - 9/5/2008 11:05:58 AM
Blue Falcon
the carb vent is obviouse, it is under the filter in the inner part of the box.
the drain tube is noticeable also, its the long skinny tube that runns down past the frame by the right tire and has a little plastic drain cap on it...right?
this third one is driving me crazy, it is in the very front right corner of the box and has a 2 inch rubber hose coming out that flattens compelted and has a slit in it...but it's still open at the slit...
Moose module
Warn - 2500 lb
Post #: 67
RE: mimb snorkel ? - 9/5/2008 11:45:44 AM
burglett
they call that the duckbill. it lets water out but also lets water in, so fill it with silicone.
07 650i
LRD Torc exhaust
MIMB Snorkels
Post #: 68
RE: mimb snorkel ? - 9/5/2008 1:38:08 PM
Blue Falcon
ok done that..
did you silocone the connections to the air box from the carberator??? the small rubber fitings with the metal strap clamps??
Moose module
Warn - 2500 lb
Post #: 69
RE: mimb snorkel ? - 9/5/2008 4:05:02 PM
burglett
no just make sure their tight
07 650i
LRD Torc exhaust
MIMB Snorkels
Post #: 70
