RE: 850s
RE: 850s
All Forums >> [OEM Discussions] >> Polaris >> RE: 850s Page: <<   < prev  1 2 [3]
RE: 850s - 8/27/2008 10:21:38 PM
Big_T
actually, I have ridden a 550 EPS.  power steering is awesome.  much better than a grizzly in my opinion.
Split audiopipe (self built)
Heelclicker
(in reply to Jonathan680)
Post #: 61
RE: 850s - 8/27/2008 11:45:58 PM
Jonathan680
My mistake then. Sorry, maybe I was confused and it was the 850 he has not been on yet.
POLARIS 850 XP:
Pure Polaris front & Rear BrushGuards
14in ITP SS-112's
28in Zilla's
07 RED 680 RINCON:sold
95 RED HONDA 300 4x4
(in reply to Big_T)
Post #: 62
RE: 850s - 8/28/2008 7:03:44 AM
Big_T
I haven't been on an 850 EPS.
I've been on both a 550 and 850 non-EPS, and a 550 EPS.
Heelclicker
Post #: 63
RE: 850s - 8/29/2008 10:26:44 AM
GunRunner
The new850 and 550 XPs for 09 will have a new Roller Clutch, anybody know what type system this is, does it still use a belt???
2009 RZR LE Sunset Red
www.teamgunrunner.com
(in reply to Big_T)
Post #: 64
RE: 850s - 8/29/2008 11:20:39 AM
Big_T
It's the same type of clutch as the SPMN, that was a roller clutch as well.  The new clutch is redesigned to be better, but it's still the same basic design.  It does turn in the opposite direction, so if you ever find yourself needing to remove the clutch remember the bolt is left hand threaded.
Heelclicker
(in reply to GunRunner)
Post #: 65
RE: 850s - 8/29/2008 1:05:32 PM
XLCat
Does the roller setup include a wet clutch like the Yami/Zuki/Cat's?
2007 700 GRIZZLY---Outlaw MSTs: 26x9.5, 26x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI air filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars, (8) 660 weights
1986 TRX200SX parts donor
1985 ATC70---detailed, open air filter, gutted exhaust, jetted, 200sx throttle housing & cable, stripped everything that doesn't make it go!
(in reply to Big_T)
Post #: 66
RE: 850s - 8/29/2008 1:40:52 PM
Big_T
it does not have a starter clutch in it.
Heelclicker
(in reply to XLCat)
Post #: 67
RE: 850s - 8/29/2008 2:22:39 PM
XLCat
So it's still grab-n-go.  Pretty odd that Po refuses to swap to the wet clutch setup IMO.  The current setup gives them the hole shot, but kills the belt in sticky situations.  Pros n cons to both I guess.
(in reply to Big_T)
Post #: 68
RE: 850s - 8/29/2008 2:29:01 PM
So when you say "roller clutch" you are talking about the little rollers that the helix slides on VS the old style with buttons..??
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to XLCat)
Post #: 69
RE: 850s - 8/29/2008 2:29:36 PM
Big_T
with the improvement in the clutch it really doesn't damage the belt.
the starter clutch adds cost and weight to the machine.
Heelclicker
(in reply to XLCat)
Post #: 70
RE: 850s - 8/29/2008 4:51:38 PM
cc1999
ORIGINAL: Big_T
it's a 4/156 bolt pattern, like the old style.  The different thing is it uses M10 studs rather than 3/8, so you'll need new lugnuts.  The good news is this is the size of lugnut most japanese bikes run.
That is good news, having other brands and always changing wheels and tires around for differnt applications, It actually was sort of a pain to keep all differnt type lugnuts seperated just for Poalris . Its not just Japan machines, I am pretty sure Polaris was the only mfg not using M10s. To me that is good news that they are joing the crowd on that deal. Thanks for the info big T.
Do You hapen to know the widths of  the OEM rims and what offsets there runing now. They look sorta like 6/1s on the front maybe, and 7/1s on the back.
I have pretty much sorted out the wheels I am planning on going with, to try and take care of the rock issues I think the OEM 14s will have when they are bouncing off them, I am planning on going with the 14" Hypers that are a Carbon fiber material with replaceable carbon fiber beadlocks and there likely quite a bit lighter than the OEM Cast 14s.  They offer them in the 4/156 pattern and in several different widths and offsets. I think I may order the rims pretty soon just to get ready for the sp850s arival. The only hold up I have is what offset to order to keep the track width close to stock as possible and to get the right widths that I will need, I will use 26"x14" Bighorns to go with the new rims.
09 Sportsman BLACK 850 XP EPS ORDERED!!!
09 Outlander BLACK 800R XT
08 Sportsman 800 X2 LE Stealth Black
06 Outlander 840 std. Red Woods pipe and few other things
05' Rally Red
Past Quads:
08,Tcat,08'RinconWhite 680,08'PolarisRZR800,06' Outlander 800 XT, 07' Renegade ,**** 800 Twin Peaks Blue, 06' Outlander Max, 02'P650, 05' SP800 EFI, 04'TwinPeaks700, 00'SP500, 99'scrambler, 03'Trail Boss, 00'Kodiac, 96'00'Warrior, ect.ect.
(in reply to Big_T)
Post #: 71
RE: 850s - 8/30/2008 2:50:45 PM
HIGHOCTANE
ORIGINAL: Big_T
Big-T-I'm hearing a rumor that the non-EPS is alot easier to steer that the old Sportsman. I do alot of riding on slow trails where steering effort comes more into play. I am about to have shoulder surgery and have a deposit down on an 850 EPS but they won't be in until Dec. My main excuse for buying a XP is for the EPS because I will have a 6 month recovery from the surgery and can't go that long without riding, and I don't want to re-injure my shoulder. BUT I am considering a non-EPS if they are alot easier to steer than the current Sportsman. I read your post where you said it was like steering a 90 but I assume that was the EPS machine. What is your opinion on how much easier the non-EPS than say an 08 800?
Sorry for the long post.
Thanks
< Message edited by HIGHOCTANE -- 8/30/2008 2:57:22 PM >
2009 Sage Green 850 XP
2008 Stealth Black Sportsman 800 SOLD
(in reply to Big_T)
Post #: 72
RE: 850s - 8/30/2008 9:57:27 PM
Big_T
hard to quantify, but I feel that the XP is easier to steer than the SPMN.  maybe 25% easier or so by my feeling.
Heelclicker
(in reply to HIGHOCTANE)
Post #: 73
RE: 850s - 8/31/2008 9:52:26 AM
HIGHOCTANE
Thanks. My dealer is going to call me when he gets the first XP so I can ride it. Hopefully I'll find it easy enough to steer so I don't have to wait until Dec.
(in reply to Big_T)
Post #: 74
RE: 850s - 8/31/2008 9:58:26 PM
Slicksp500
Who exactly built the motor in the 850. Was it all polaris, or did ktm or weber pitch in? Any of these are great engines. i was just wondering. I have a msx 110 jet ski, loads of power and is tough, no problems so far. It was the weber. I couldn't imagine it in a 4-wheeler frame. The 550 is still the fuji right? later.
Polaris Sportsman 500 1999 (Green) 17,200 Miles
1982 ATC 200 Honda (Restored whole machine.)
2008 Raptor 250 (Gray) Guess 2500 miles.
1990 Chevy 1500 4x4 (5.7 TBI) 174,000
1981 Chevy C20 Utility truck 292 (I-6) 483,000
"Run it till it tears up. Fix it or buy a new one."
Post #: 75
RE: 850s - 9/1/2008 9:13:27 AM
Big_T
ktm had nothing to do with it.  KTM and polaris aren't the best of friends right now.
Most of the engine development was done right in Polaris's shop.
Heelclicker
(in reply to Slicksp500)
Post #: 76
RE: 850s - 9/1/2008 11:27:39 AM
viol8r
The only thing steering me away from this machine is weight, I want to see what it actually is on a scale full of fuel ready to ride, an how that number compares to the can am.
06 Rincon 680 camo, 26" ACT XLR's
08 KingQuad 750axi camo, 26" terracross R/T, Dalton, TwinAir
(in reply to Big_T)
Post #: 77
RE: 850s - 9/1/2008 5:23:22 PM
Hornvictory
Here is why from a distance I like the popo more than the Can Am.  The can am just now started putting skid protection and it does not look that sturdy which I would not trust because of the flat frame can not take direct hits from a rock or stump.  The frame is weak and needs to be shored up.  The light weight with all of that power makes it really want to jump up in the front unless you are on a Max.  You need to upgrade the front shocks.  Not to mention the price is high considering the shocks, and skids needed. The 4x4 system is superior to Can Am.  And the Lock in Ride is awesome.  Other than that, The Can am is Awesome.  Great Ride.  I have researched the **** out of Can Am.  If Popo did not come out with this, I would have gotten a Razr.  I would like to see a 2-up though.
(in reply to viol8r)
Post #: 78
RE: 850s - 9/1/2008 5:25:06 PM
Hornvictory
H E L L gets censored?  What is this, Nazi Germany?
(in reply to Hornvictory)
Post #: 79
RE: 850s - 9/1/2008 6:29:44 PM
cc1999
None of the big bores are real light, The japanese models are lighter, but once you get decent tires and rims on them, they gain quite a bit of weight too. That said I am sure without a doubt the Polaris will be one of the heaviest if not the heaviest bog bore out there. But they will all hurt if they roll over on top of ya, best to try and keep the shinny side up on any of them. LOL
I am sure this polaris will be a top contender this year for best big bore on the market. If given a choice of what is out there on the lots today, I would have to say Can-am all the way. The jury is still out on the new 850 IMO till they hit the showrooms and start making it out into the publics hands. So far on paper the 850 is a pretty darn impressive machine. Can't wait to try one out later this year.
05' Rally Red
Past Quads:
Post #: 80
RE: 850s - 9/13/2008 8:49:09 AM
sweat800
My dealer called and said they would have 850's & 550 w/o eps next week & with next month.
09 red sportsman 850xp EPS orderd
05 sportsman 800 SOLD
ranger front springs
pure polaris front & rear bumpers
26" BIGHORNS ON SS108
2500# warn winch
k&n
04 yamaha kodiak 400
2500# warn winch
(in reply to cc1999)
Post #: 81
