ALMOST30S
ORIGINAL: mrrpm quote:
ORIGINAL: BAD BRUTE 650 I am right here and you are going Down  Bucky I know you know about Drag Racing but just a heads up,you do know you need to drain the system and run a race fuel back threw it to clean it out after you run each day,also when you drain the Alky Change the plugs back to some old one so you dont have to put new ones in everytime you put Alky back in it,also on the 4 stokes you need to add a 1/2 OZ of Top Lube to every Gallon of Alky/Methanol I use Uplon by Klotz very good stuff,like I said I am sure you knew this but if not you do now,but dont leave it in there no more than a day,we have electric fuel pumps it will trash the seals in them I flush when ia mdone running each day,them pump are High $$$$ also one other thing if your system has a vent for the fuel tank make sure it the vents are Open and get air faster than they have before with Race Gas and also the Colder the Alky is the Faster it Burns,Boy we are going to have some Nasty A$$ 4x4 at Bodatious I cant wait,the ATV Mud Bog may just be in the Truck Hole will you be there Friday if so me and you can go over it with Troy and get the Mud Bog Straight you more about it than me some your help would be Great,maybe we can get Clay to test the truck hole to see if he can make it threw,see you guys in September!!!!!!!!! I think badbrute is the one that's drunk with all that stuff he's sayin about methanol! You don't have to put gas back in it after it's been running. Why would you need to change plugs after it's been running? Top lube is unnecessary, and is banned in many racing organizations. Cold fuel burns faster??? yeah right!! I think your right lol i couldnt understand half the stuff he said in that paragraph lol muahahahahah
Team MUD PIMPZ! 1984 yamaha breeze brute force 500 lift-f150 torsion keys up front and 2inch blocks in the rear SCUBA GEAR 30x12x15 big horns flowmaster exhaust cookie cutter cdi APC headlights Transmission work RIMs-u wont believe it!ROUND ONES!how crazy is that? Peg leg limited slip 4wd lock smitty built brushguard Flux capacitor motor puttin out 19 rwhp!
