RE: broke bevel gears
All Forums >> [OEM Discussions] >> Arctic Cat >> RE: broke bevel gears Page: <<   < prev  1 [2]
RE: broke bevel gears - 8/26/2008 4:25:15 PM
KTLuther
Add another busted rearend to the pile.
07 H1 Cat
Only Slightly Modified ;)
TiTTi DeeP MuD CluB
(in reply to GWC)
Post #: 31
RE: broke bevel gears - 8/26/2008 5:00:33 PM
dang it what are you guys busten on them..??  case or gears.?
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to KTLuther)
Post #: 32
RE: broke bevel gears - 8/26/2008 5:42:28 PM
KTLuther
Im not sure if the gear was what let go first but the front half of the case is pushed out. I "think" that J had the gear bust a tooth or two, not sure though.  I will tear mine apart when the replacement arrives.
07 H1 Cat
TiTTi DeeP MuD CluB
(in reply to GWC)
Post #: 33
RE: broke bevel gears - 8/26/2008 5:44:10 PM
NBM
So the cat guys are the only machines turning 29.5 tires or bigger?
Post #: 34
RE: broke bevel gears - 8/26/2008 10:10:52 PM
  huh..
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to NBM)
Post #: 35
RE: broke bevel gears - 8/28/2008 6:40:46 PM
KTLuther
I lost two teeth off of the ring gear and the main case is all torn up.  It basically tried to rip the pinion part of the case off.
07 H1 Cat
TiTTi DeeP MuD CluB
(in reply to GWC)
Post #: 36
RE: broke bevel gears - 8/28/2008 7:10:18 PM
SMATHEWS
I WON'T TELL ANY BODY ABOUT THE STUCK 1/2 TON CHEVY TRUCK
YA PULLED OUT THE DITCH IF YOU DON'T
2006 650 H1 SE ARCTIC CAT
2008 THUNDERCAT
SPEEDRACKS BRUSHGRARD REAR BUMPER
2004 400 STD LIME ARCTIC CAT
2004 400 STD RED ARCTIC CAT
NAPA AUTO PARTS @ ARCTIC CAT ATV'S
TiTTi DeeP MUD CL
Post #: 37
RE: broke bevel gears - 8/28/2008 7:14:21 PM
KTLuther
Ok that will do, we can keep that hush hush.  Atleast it broke after quite a bit more riding.  If it would have broken right after pulling the truck out or while, that would have been worse!!
07 H1 Cat
TiTTi DeeP MuD CluB
(in reply to SMATHEWS)
Post #: 38
RE: broke bevel gears - 8/28/2008 9:37:03 PM
MUDTECHinc
what i have found is that the gears go just a few miles after lugging them in reverse. basically if you are in really thick mud and having a hard time turning the tires and you are useing reverse you are working the gears apart from each other. Thus causing more play in the gear set and causing it to put more stress on the gears and within a few miles the teeth are droping off the pinion gear and whammy you have a big problem on your hands. If you are moving fast when this happens or don't catch that it is happening you can easily tear up the cases. if you are in a situation where you are going easy and aware of odd noises that your machine is making then you can catch the bevel gear failure before it tears everything to pieces. just my conclusions that i have gathered from the 2 gear sets that i have seen go first hand.
MUDTECHinc Custom ATV Fabrication Bog Team
2005 ARCTIC CAT 650:
29.5" Laws on Beadlocks
Web cam
2008 Arctic Cat 1000 H2
Carb slide mod
http://s226.photobucket.com/albums/dd185/MUDTECHinc/
Post #: 39
RE: broke bevel gears - 8/29/2008 12:25:21 PM
tncincws1
ORIGINAL: GWC
http://www.highlifter.com/forum/700_grizz_broke_middle_drive/m_2572333/tm.htm
we are not alone.. think maybe tires are just getting too big for what the machines where made for..
oh and some thumbs are to big as well..lol
yamaha is covering mine under warenty,  how about you guys, will cat warenty theses parts
07' 750 GRIZZLY!
30X11X14 MUDZILLAS
ITP 212 BLACK
EPI CLUCH KIT
BISON BUMPERS
2 INCH HL LIFT (not installed)
TBR m7 slip-on & juice box
734 trinty BBK
(in reply to GWC)
Post #: 40
RE: broke bevel gears - 8/29/2008 12:52:31 PM
Yes sir they will.  AC put a whole new motor in my 500m instead of just fixing it thought that was real good of them.
We just have to learn to be alittle easyer on things with these great big huge tires..lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to tncincws1)
Post #: 41
RE: broke bevel gears - 8/29/2008 1:38:33 PM
KTLuther
yea, take it easy....  Right
07 H1 Cat
TiTTi DeeP MuD CluB
(in reply to GWC)
Post #: 42
RE: broke bevel gears - 8/29/2008 1:40:24 PM
KTLuther
< Message edited by KTLuther -- 8/29/2008 1:42:50 PM >
07 H1 Cat
TiTTi DeeP MuD CluB
Post #: 43
