RE: Start in gear mod
All Forums >> [OEM Discussions] >> Honda >> RE: Start in gear mod Page: <<   < prev  1 [2]
RE: Start in gear mod - 8/19/2008 7:23:08 PM
machineman350
http://www.highlifter.com/forum/m_2697924/mpage_1/key_/tm.htm#2697924%20
Here you go.I am pretty sure it will work on the 450 also.
2003 Rancher
28 in. mudzillas
(in reply to minitrk)
Post #: 31
RE: Start in gear mod - 8/19/2008 8:15:01 PM
Badforeman475
that is what I was looking for thanks machineman350 for the link
Blue 98 Foreman 450 DGL 14% Gear Reduction 480 BBK Delta Snorkel, Start-in-gear mod, DGL, Clutchkit, Lift Springs, Jetted, Uni filter, cherry bomb exhaust Snorkle, Custom relocated fan/oil cooler, Manual fan switch, 28" 10's and 12's S-Backs on SS112 rims
Pic of my bike http://www.myspace.com/blueforeman450 (ADD ME) For the mob
(in reply to machineman350)
Post #: 32
RE: Start in gear mod - 8/20/2008 12:26:57 AM
minitrk
thanks for the link.... looks like I got something else to do now lol.
04 foreman 450 yellow
- disk brakes
- clutch kit
- Triangle atv snorkle
- jet
- uni filter
- perfex ltk
- hl springs
- 27 bi/tri claws on type 4s
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- pod light shut off switch
- full prm armour
- reverse button override
(in reply to Badforeman475)
Post #: 33
RE: Start in gear mod - 8/20/2008 9:21:09 PM
ATVtech
ORIGINAL: bansheefan03
ORIGINAL: ATVtech
whats redneck about if it works keep things simple they always work better that way i mean if u change up where it goes into the cdi ur gonna have to ground something somewhere to get it to think its in neutral so why not do it the simple way
If I have to explain why that is an improper procedure then you obviously wouldn't understand the reason.
well enlighten me on why it will not work now i admit i dont know if it will work on the es models but i have done it to others and its worked fine so far
Of course it’ll work (on manual shift models). It doesn’t take a rocket scientist to figure out that grounding the neutral wire will allow the bike to start in gear. I mean, it’s not like you found a cure for cancer or anything. You haven’t uncovered some top secret procedure. People have been grounding the neutral wire on their Honda ATV’s since the days of the ATC250ES Big Red. Same circuit, same result.
But you see, there are two ways of doing things - the easy way and the right way. Grounding the neutral wire to allow an ATV to start in gear is the easy way.  That is why I came up with a better way... the right way. My procedure allows the bike to start in gear while keeping the neutral and reverse light functions intact.
Do you want to be known as a person who takes shortcuts and performs shoddy work? Or do you want to be known as a person who takes pride in his work and is willing to go the extra mile to do a top-notch job? Judging from your bad advice and poor mechanical ability, I’d say you are more than happy to take the easy way out and perform shoddy work, and that is your choice. In the end, people will learn to ignore members like you and they will gravitate towards brilliant, knowledgeable members like me.
ATVtech - Baddest Man on High Lifter
(in reply to bansheefan03)
Post #: 34
RE: Start in gear mod - 8/20/2008 9:51:08 PM
ATVtech
I haven't done the start-in-gear mod on a Foreman 450S in quite some time, but according to the wiring diagram(s), the procedure for the 98-01 Foreman 450S should be the same as the one for the Foreman 400 I posted in the helpful links sticky.  The same procedure should also work for the 02-04 Foreman 450S, but the diode may have to be removed on these models.
This does not apply to electric shift Foreman 450 models.
(in reply to ATVtech)
Post #: 35
RE: Start in gear mod - 8/20/2008 9:57:45 PM
bansheefan03
OK then smart a** no one said there was a right or a wrong way to do it and who are you to say what kind of work i do do you know me no u don't he asked a simple question so i gave a simple answer since no one else had anything to say did i say it was the best way no i didn't does it give the solution to his answer yes you just want to feel all high and mighty and think u know everything i guess and just want to prove someone wrong every chance u get hope it makes u feel like you fill ur britches now and believe me i don't have to worry bout people thinking i do bad work cause i have people coming to me everyday wanted me to do stuff for them I'm out this is so da*n stupid
< Message edited by bansheefan03 -- 8/20/2008 9:58:56 PM >
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ ****s ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
not really sure how much lift, ape axles,gear reduction,xl2 wheels, axle paddle,and lots more to come
Post #: 36
RE: Start in gear mod - 8/20/2008 10:09:38 PM
Badforeman475
Ok cool Thanks I will try it this weekend I didnt mean to start a war
Post #: 37
RE: Start in gear mod - 8/20/2008 10:11:44 PM
minitrk
ORIGINAL: ATVtech
Alrighty then.... what would one do for an 04 450es???? glad I didnt do any cutting of my wires yet.
- disk brakes
- clutch kit
- jet
- uni filter
- perfex ltk
- hl springs
- warn 3.0
- warn bumper
- plasma rope
- sealed pull start
- back up light
- hmf eco
- rear box/seat
- fener protectors
- f&r tow hooks
- full prm armour
Post #: 38
RE: Start in gear mod - 8/21/2008 3:34:25 PM
350rancherboy
yeah me too..lol...so i sitll dunno how to make my foreman start in gear..and still work like stock..
1995 Honda 300 Fourtrax 2x4 (Tan)
-Foreman Wheels and Tires
-Bumper
-Footrests
-Audiopipe
-Homade skidplate
-Walmart Driving Lights
-Tooter! (Horn)
1968 Chevrolet C-10 Pickup (Baby Blue)
Drum Brakes: Because being able to reliably stop your ride is for cowards!
http://s289.photobucket.com/albums/ll226/350rancherboy/
Post #: 39
0.609
