RE: BB is leaking a seal.
All Forums >> [OEM Discussions] >> Yamaha >> RE: BB is leaking a seal. Page: <<   < prev  1 [2]
RE: BB is leaking a seal. - 8/14/2008 10:56:05 PM
o5fore
ORIGINAL: kidsoncoffee
I'm a stick with good ole diff fluid.  That way I know when my seals go bad, and when I need to change them.  Diffs are too darn expensive to take that chance.
hate to tell you this but your seals r gonna let water and mud in from day one they may not leak out right away but your rear diff is getting a good steady supply of mud and water grinding away in there. only time i had to change my diff was when i was running diff fluid by the way
Red 07' Yamaha Big Bear 400i
27" Outlaws
HL Spacers
MSA Black Torks
Custom Snorkles
DynoJet Kit
UNI
HMF Pipe W/ Snorkle
Vent Lines ReRouted
HL 2" XPATV Lift
Bed Lined Racks
Gorilllas on all 4
HL Lift Springs
EPI HL Clutch Kit
Web Cam
Hi-Comp Piston
Lift Springs
Warn Front Bumper
Warn 3,000 Winch
RIBMASTERS
TEAM BBi CoFounder
(in reply to kidsoncoffee)
Post #: 31
RE: BB is leaking a seal. - 8/14/2008 11:04:19 PM
CTownForeMan
So where is your technical support mud_dog450?  We have ran greese in differentials for along time.  It's an old trick.
Manufacturers don't do it strickly because they don't build these things for mud and water.
So riding with a bad seal letting mud and water in there every ride is better than running greese that may let the gears run dry a little bit?  Greese will keep the dirt out which will be killing your bearings.  When the bearings go out this throughs the gears off which wear out the gears more.  So, now the real question is does water and mud lub. better than greese?  As long as greese is pumped i after every ride it will be fine.  Everytime we get back to the trailer we pump some greese in there.  Yes, eventually the greese will be slung out and way from the gears but, by that time we are pumping greese back in there to work their way back in.
On my foreman I drill and tap the differential cap for the greese zerk.  This means when and if the diff. ever goes out it won't be that hard to convert it to greese.  Seals will not last with the punishment we put them through and the mud and dirt will rip apart a differential than greese will.
Also greese gets worked into the bearings for lubercation.  This is alot better for the bearings than dirt and mud is for them.  I would only recommend this for people who ride mud and water alot.  This is not required for the trail rider with little mud and water riding.
Yes greese makes a mess but when working with differentials and tearing them apart a good parts cleaner works great or some brake cleaner and normally there is nothing more to repairing a differential than pulling the cases apart and removing the nut on the yoke in the front.
Custom 1998 Foreman 400!
foreman 450 frame, custom 4 inches of lift, EDL's on douglas wheels, custom rear suspension with single rhino shock, removable paddles, welded front diff, 450 jug with HC racing piston, gear reduction!
Got Paddles?
http://community.webshots.com/user/ctownnasty400
http://s186.photobucket.com/albums/x289/ctownforeman/
(in reply to o5fore)
Post #: 32
RE: BB is leaking a seal. - 8/14/2008 11:07:28 PM
o5fore
well said clay
27" Outlaws
HL Spacers
MSA Black Torks
Custom Snorkles
DynoJet Kit
UNI
HMF Pipe W/ Snorkle
Vent Lines ReRouted
HL 2" XPATV Lift
Bed Lined Racks
Gorilllas on all 4
HL Lift Springs
EPI HL Clutch Kit
Web Cam
Hi-Comp Piston
Lift Springs
Warn Front Bumper
Warn 3,000 Winch
RIBMASTERS
TEAM BBi CoFounder
(in reply to CTownForeMan)
Post #: 33
RE: BB is leaking a seal. - 8/14/2008 11:24:52 PM
mud_dog450
ORIGINAL: P360onBugs
ORIGINAL: mud_dog450
It's one of those things where if it was better than running gear oil, then the manufactures would run it from the factory.
i tended to agree with you. thats why  i sugessted a mix.  However the logic in this part of your statement is faulty.   Surely you could agree on LOTS of instances where there was a better way and manufacters still did something else.
I completely agree with you.  Hence the reason why I stated "It's one of those things"  because, as a motorcycle/ATV mechanic, I see that sort of stuff all the time and wonder why they did it like that instead of like this.
ORIGINAL:05fore
as for tech info if your diff is packed full with greae explain to me in technical terms where the grease is going. oh just so you know i have tooken 2 diffs apart both looked brand new and both with grease and not a drop of water or mud in them the bearings especially last alot longer its really quite simple mud and water that will get in your diff and it will will eat your bearings up quicker than anything. however if its packed with grease they will last for eons.
Let's look at it another way.  Let's say that a car windshield is one gear surface, the windshield wiper is the other gear surface, and rain is the grease.  When the wiper comes and swipes away the rain, it leaves the windshield bare.
Unless you are literally pressurizing the differential with grease (which wouldn't work because then diff is vented and you would also pop the seals out), then there is nothing in my opinion that guarantees that grease will run between the gear teeth to recoat the gear mating surfaces for their next contact with each other.  I understand that the diff is packed full of grease, but there is nothing inside the differential that is reapplying the grease to the gear teeth mating surfaces.
I agree that the bearings and seals will last a lot longer because the use of grease will help keep mud, water, dirt, whathaveyou out of the diff therefore out of the bearings.
But based on what I'm aware of and the properties of grease and how a differential works,  I do not see how packing a differential with grease will keep the gear teeth properly lubed at all times.
The Mud Brothers
Goin' Deep Since 2004!
02 Grizz
Everything Snorkeled
Clutch Work
29.5 Laws on Vision Buckshots
Muddin Videos
(in reply to P360onBugs)
Post #: 34
RE: BB is leaking a seal. - 8/14/2008 11:27:10 PM
htownmudder
Well, I do ride lots of mud and water.Nasty mud and deep water.
Should I pack it with grease?I dont want to constantly change seals.
08 BIG BEAR
27-12,27-9.5 INCH LAWS
HLP SPACERS
WARN WINCH
HIGHLIFTER 2 INCH LIFT KIT
SNORKEL
(in reply to mud_dog450)
Post #: 35
RE: BB is leaking a seal. - 8/14/2008 11:34:34 PM
o5fore
ORIGINAL:05fore
i see what your saying but it does work it has always worked for me.i dont know how else to explain it other than it lubes the bearings great and my ring and pinion r holding up great
27" Outlaws
HL Spacers
MSA Black Torks
Custom Snorkles
DynoJet Kit
UNI
HMF Pipe W/ Snorkle
Vent Lines ReRouted
HL 2" XPATV Lift
Bed Lined Racks
Gorilllas on all 4
HL Lift Springs
EPI HL Clutch Kit
Web Cam
Hi-Comp Piston
Lift Springs
Warn Front Bumper
Warn 3,000 Winch
RIBMASTERS
TEAM BBi CoFounder
Post #: 36
RE: BB is leaking a seal. - 8/14/2008 11:38:15 PM
CTownForeMan
As I said keeping the bearings and eals cleana nd lubed with not havng the gears coated with greese at all times but still having greese inthere will last longer than mud and water.  When the bearings go out because of mud and water the gears lose backlash and just bounce around in there.  Causing horrible wear on the gears.
Got Paddles?
(in reply to htownmudder)
Post #: 37
RE: BB is leaking a seal. - 8/14/2008 11:49:54 PM
mud_dog450
ORIGINAL: CTownForeMan
Nowhere did I say that, or imply it.  Obviously if you have a seal going bad it is wise to replace it.  If damage is done to your diff because you neglected to replace seals, then it is your fault and yours alone.  I am simply stating that it seems much more sensible to replace seals rather than "let the gears run dry a little bit" like I have been trying to explain, and you just stated they do.
I do agree that grease will keep the dirt out.  But so does a good seal.  Mud will obviously act as an abrasive between the gears and accelerate wear.  Metal to metal contact will accelerate wear as well, which will happen not long after you start driving once the grease is either squeezed out or slung out from the gear teeth.  Does it not worry you that you have to pump more grease into your diff after every ride?  That means that there are voids in your diff and that leaves space for the grease that comes off of the gear teeth to go.  I can assure you that the grease will be removed from the gear teeth and not be replaced the first time the gears go round and round.
I do agree that mud and dirt will ruin a diff, but I'm not so sure about which will ruin it first.  Once the grease film is wiped away from the gear teeth, heat can quickly build up in the gears because it does not have the gear oil to help cool it down.  Between the heat and the bare metal to metal contact between the teeth, I'm not sure which would ruin a diff quicker.  All of this can be prevented by properly maintaining the diff by making sure it has fresh gear oil before every ride as well as making sure the seals are in good order and are not leaking.  I'm not saying that just because they don't leak they won't let stuff in.  I know they will let mud and water in even if they are brand new, but making sure it has fresh gear oil prior to each ride will remove most of the stuff the seals may have let in.
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
Post #: 38
RE: BB is leaking a seal. - 8/15/2008 12:06:00 AM
CTownForeMan
Buying a $10 seal after every ride becomes costly and and labor of replacing it becomes tiring.  From what I have seen the seal goes out after every ride.  Lets say you ride every weekend.  Thats $40 to $50 dollars right now.
Does it accure to you that there is a problem with having to replace a seal after every ride?  That there is something wrong?  I would rather greese my differentials that have held up for years now rather than tearapart a bike every week.  As much as I work on things they last thing I want to work on is my bike because of a seal.  Just because the greese gets slung out don't mean it's completly dry.
Preventative maintanance is a good thing.  I do it all the time.  The same seal going out all the time is not preventative maintanance.  It's a problem that needs a solution.  You can only band aid something so long till you get tired of it.  I watched a Big bear diff blow after just having a seal replaced because it kept going out on a new big bear.  There is a problem there.  I run greese in my differentials.  I have had great luck in running greese in my differentials.
Have you ever ran greese in a differential?
Got Paddles?
Post #: 39
RE: BB is leaking a seal. - 8/15/2008 12:29:26 AM
mud_dog450
If you've had good luck with running grease, then I hope you continue to have good luck from here on out as luck is the only thing that's keeping it from wearing out.
I do not run grease, and I will not run grease because I do not believe it is the proper way to maintain an ATV.
Good discussion though.  This is the first I've heard of anyone doing this.
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
Post #: 40
RE: BB is leaking a seal. - 8/15/2008 12:31:04 AM
o5fore
people been doing it for years..
27" Outlaws
HL Spacers
MSA Black Torks
Custom Snorkles
DynoJet Kit
UNI
HMF Pipe W/ Snorkle
Vent Lines ReRouted
HL 2" XPATV Lift
Bed Lined Racks
Gorilllas on all 4
HL Lift Springs
EPI HL Clutch Kit
Web Cam
Hi-Comp Piston
Lift Springs
Warn Front Bumper
Warn 3,000 Winch
RIBMASTERS
TEAM BBi CoFounder
Post #: 41
RE: BB is leaking a seal. - 8/15/2008 8:28:02 AM
CTownForeMan
It's been used for awhile.  Old trick.
I'm not saying that greese is a great replacement of oil and is for everybody.  It's not good maintanance but it does keep mud and water out.  I don't see it as a good way to maintain an atv.  I do see this as a fix for an atv under mud and water all the time and I mean ALL THE TIME.  My trail foreman runs oil, our polaris ranger runs oil, and my mud truck runs oil.  It's the mudding atv that I run greese in because I have found it better for that application.
Luck being the only thing holdin it together?  Maybe so, but eventually it will wear like anything will.  Even with oil gears will wear and strip out.  With my experience the bearings going out will wear the diff gears out horribly.  Yes the gears will get hot but as often as we stay in mud and water the water will keep the case and everything inside cool enough.
Yes a great discussion, I am not saying this is the best for everybody again, it's worked best for me for my foreman in deep mud and water constantly.
< Message edited by CTownForeMan -- 8/15/2008 8:31:17 AM >
Got Paddles?
Post #: 42
RE: BB is leaking a seal. - 8/15/2008 8:52:12 PM
htownmudder
hey is there anyway to stop a leaking seal?
I am gonna do one more ride and then I will change the seal.I was just wondering though...
Also, Like I said before, should I run grease?I do mud ride and water ride about 80%of the time..
08 BIG BEAR
HLP SPACERS
WARN WINCH
SNORKEL
Post #: 43
RE: BB is leaking a seal. - 8/15/2008 9:29:06 PM
mud_dog450
Sometimes if you take a very thing feeler guage and slip it between the axle and the seal, you can break up a little of the dirt and mud that's causing the seal to leak.  Sometimes this will stop it from leaking.
However, if the seal is worn out and the rubber seal lips are damaged, then using a needle-tipped grease gun to squirt some grease between the axle and the seal lips might stop the leak.
As far as whether or not to run grease in your differential, it's up to you.  There's plenty of info in this thread alone from both sides of the line to help you decide.
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
Post #: 44
RE: BB is leaking a seal. - 8/16/2008 12:01:43 AM
htownmudder
Thanks Mud_Dog.
08 BIG BEAR
HLP SPACERS
WARN WINCH
SNORKEL
Post #: 45
