RE: 5.3 mods? need opinions...
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> RE: 5.3 mods? need opinions... Page: <<   < prev  1 [2]
RE: 5.3 mods? need opinions... - 10/3/2008 12:23:40 PM
Bunk650
mines an 00 with the poweraide TB spacer, underdrive pulleys, NKG ignition and wires, true dual straights w/ cats. I have a question and a slight problem.
Question:
Is it hard to switch to elec fans? how expensive?
Problem:
My truck ran hot a few weeks ago cause I have a slight leak that I cant seem to find. And that might have nothing to do with it, but seems like since then, when I crank it up cold, it has a terrible knock on the drivers side of the motor. Sometimes it will last about 10-15 secs, but sometimes it wont stop till its at 185* for a few min(new 185* thermostat). You can even hear the difference in the exhaust from drivers side to passenger side.
I've taken it to the shop for the leak and they pressure tested it and didn't find anything, said it may be my water pump.
Talked to a friend that works at the shop about the knock and they seem to think it could be a lifter. I thought these had self adjusting rocker arms.
Just need some advise/info on what I need to do. If anyone has any insight...
Thanks,
sorry for a long post
Hard Pack Arctic Cats
It all seems HardPack when you ride a CAT
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
(in reply to Dock Rocker)
Post #: 31
RE: 5.3 mods? need opinions... - 10/3/2008 1:17:33 PM
onebadrubi
Its mostly likely the chevy tic that these gen 3 chevy engines have.  Its nothing to worry about unless its very loud which then you could have a collapses lifter/valve.
2008 700h1
4" CATVOS lift
32" ****s
07 5.9l HO Cummins mega Cab w 35" toyo m/t's and one heck of a stereo!
http://community.webshots.com/user/onebadrubi
H1 for sale
(in reply to Bunk650)
Post #: 32
RE: 5.3 mods? need opinions... - 10/3/2008 1:35:59 PM
Bunk650
yeah, its LOUD. I know about the slight "tick" from chevy's but this is alot louder. I've talked to a bunch of people about it and they say,"oh, its a chevy they do that" but this is louder than the reg. tap. Had a couple people say when they got their 02 brand new it had a tap. I know about it, but this isn't right, its really loud.
If its a "collapsed" lifter or valve, how hard is it to replace/fix? I'm thinkin about doing it this weekend.
Other option is let the shop tear into it and see @ $75/hr labor...
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
(in reply to onebadrubi)
Post #: 33
RE: 5.3 mods? need opinions... - 10/3/2008 5:15:40 PM
gmcz71
The common "tick" these LS motors have is referred to as Piston Slap... It is caused by the piston being SLIGHTLY smaller than the cylinder I think.
Some say synthetic helps it but Im not about to try to find out.
Nothing to worry about tho,
Bunk650 I bet yours is more than piston slap if its that loud.
1998 Suzuki Quadrunner 500 -
A work in progress. Slowly being built.
USA EDL's for sale... http://www.highlifter.com/forum/28%22_USA_EDL's%25%25%25_checking_interest/m_3044302/tm.htm
2000 GMC Sierra Z71 - 5.3 - ecsb
- Cherrybomb Extreme
- Blackbear 87oct tune
- Vette servo's
My Pics...
http://s523.photobucket.com/albums/w358/tylerz71mud/[/cent
Post #: 34
RE: 5.3 mods? need opinions... - 10/3/2008 7:01:46 PM
sanjac
I dont mean to come off as a jerk but a 5.3 is not in the LS series of motors, its a Generation 3 small block, and physically from the outside they are identical with the exception of oil pan and intake manifold. The 5.3's RPO is actually LM7 for just the regular 5.3, the flex fuel, AFM, and all aluminum 5.3's have different RPO's
Question:
I think that the electric fans are good upgrade IMO. it varies from where you get it, but you can pick them up for like 400 to 500 dollars, and they come with everything you need, you can also run a low temp thermostat and set the fans to come on sooner. I believe that in '04 maybe '05 some Tahoe's and Suburban's came with electric fans so it wont be too bad to switch to them. Idk how far you want to go with your mods but with the electric fans you can run a low profile LS1 or LS6 intake mainfold, the only thing you gotta watch out for is the water cross over lines depeding on the year, and get the throttle body ported. Another mod you can do is run a LS6 cam its not a real radical cam and wont affect it driveability, and if you do the cam, while your there you can also get a higher flow and higher pressure oil pump, and double roller timing chain, and if you want to do somethin with the MAF you could possibly get get an SLP or GMS (I personnally prefer the SLP) which has a larger diameter and is descreened. You can do this if you want idc but it will be a pretty nice setup with all the other mods that have been listed. Im in the process of doin the same thing but ive got an actuall LS1 and I had the heads ported, and Im gonna run a Comp cam tho, Scat rods and Mahle flat top pistons, plus whole lot of other crap thats going into that engine.
2007 Grizzly 450
- 2" Lift Kit
- 1.5" Wheel Spacers
- 28'' Outlaws
(in reply to gmcz71)
Post #: 35
RE: 5.3 mods? need opinions... - 10/3/2008 9:19:32 PM
Bunk650
yeah, talked to some more guys today and they said they worked on a tahoe that had a prob similar to mine, but not as bad. they said it was a bad seal in the oil pump and a few bad valves/lifters.
So, I think Im gonna let them have it first of next week. Should I go ahead and get the higher flow/pressure oil pump? prolly gonna have to get a few new valves/lifters I guess. not sure yet....
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
(in reply to sanjac)
Post #: 36
RE: 5.3 mods? need opinions... - 10/3/2008 9:38:57 PM
Dock Rocker
the E-fans are easy.  Go to performancetrucks.net and search.  Go get a set of fans from an f body in a junkyard and then put the correct pin into your harness and have it programed in.  You can also get a fan from an 05 truck out of the junkyard.  I got mine for 30 bucks.
Post #: 37
RE: 5.3 mods? need opinions... - 10/4/2008 12:05:17 AM
sanjac
Thats up to you if you want to get the high flow/pressure oil pump, another alternative is an oil pump out of a corvette, it flows more than the truck oil pump.
2007 Grizzly 450
- 2" Lift Kit
- 28'' Outlaws
Post #: 38
RE: 5.3 mods? need opinions... - 10/4/2008 2:44:29 PM
onebadrubi
the 5.3l is often referred to as an LS series motor.  You can ver EASILY turn it into the exact motor except iron instead of aluminum with just boring.
Now whoever said you are NOT about to try synthetic in the gen 3 small block.  YOU SHOULD already be running synthetic in it!  These motors love fully synthetic.
Efans are great cost effective upgrade.
2008 700h1
4" CATVOS lift
32" ****s
H1 for sale
Post #: 39
RE: 5.3 mods? need opinions... - 10/4/2008 4:06:44 PM
gmcz71
ORIGINAL: onebadrubi
I just cant see myself spending $50+ for a oil change, right now Im running Pennzoil or Vavoline and the oil change is $40.
I know it would be cheaper if I did it myself but I really dont feel like it.
E-fans will probably be one of my nexts mods, definitely before next summer.
- Vette servo's
My Pics...
Post #: 40
RE: 5.3 mods? need opinions... - 10/4/2008 5:25:14 PM
Guest
 i know on fords theres a choke behind the safewall were the stock air intake goes..  its put there for insurance and warranty resons.. it restricts air and takes away about 3 to 4 mpg.. take that out if urs has one.. put a cold air intake, a chip, flowmasters, might could change the gearing some, and everything u mentioned and u should be doing pretty good as far as gas milage
  Post #: 41
RE: 5.3 mods? need opinions... - 10/4/2008 6:34:28 PM
Foulplay
ORIGINAL: Bunk650
I had an older Dodge truck years ago and the oil pump went out on it. I got to talking to a hot rod buddy of mine at work and he convinced me to put a high volume/pressure pump on it. So I bought the pump and had a professional install it for me. Just a few miles later, I burnt the motor up. Apparantly, the high volume/pressure pump was too much for my motor and blew the seals out of it. Atleast that's what the mechanic told me. They told me that the high flow pump was a big mistake, that they were made for hot rod motors, not stock truck motors. Maybe and hopefully you won't have the same results as I did but I will never do that again.
'06 Popo 800 EFI on 29.5" Outlaws
'05 Popo 700 carb on 29.5" Outlaws
'07 Popo 500 H.O. EFI (hers) on 27" Outlaws
'78 Jeep CJ-7 w/304 V8
http://s125.photobucket.com/albums/p44/Foulplay_photo/
This Honda's gone...
http://video.yahoo.com/watch/341841/2183512
Post #: 42
RE: 5.3 mods? need opinions... - 10/4/2008 8:43:15 PM
gmcz71
ORIGINAL: bigpoppa916
well thats a Ford thing, the only somewhat-obstruction this thing has in the air intake tract is the huge silencer (soon to be removed) and the MAF sensor screen (not messing with it).
Im not getting a CAI, the factory airbox on these trucks is sufficent, as is the factory type filter, however I plan to add either a ram air type deal (home made) or just swiss the box.
A "chip", assuming your referring to a PCM has already been done to it, helped a good bit.
"Flowmasters" (plural), are not needed as these engines need backpressure to retain low end torque... a SI/DO is more common and Im not absolutely crazy about the flowmasters sound.  Ill stick with my magnaflow w/no pipes behind it.
Im running stock size tires for now, with 3.73 gears so Im right where I need to be there.  If I go bigger (285/40/20) I might consider 4.10's if my G80 decides to let go.
- Vette servo's
My Pics...
(in reply to Guest)
Post #: 43
RE: 5.3 mods? need opinions... - 10/4/2008 8:52:25 PM
Guest
lol well looks like u got it all figured out then huh? ur grammer too..
  Post #: 44
RE: 5.3 mods? need opinions... - 10/4/2008 9:15:09 PM
gmcz71
haha guess you could say that
- Vette servo's
My Pics...
(in reply to Guest)
Post #: 45
RE: 5.3 mods? need opinions... - 10/5/2008 11:02:13 AM
Bunk650
I've got 4.10's in mine...
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
Post #: 46
RE: 5.3 mods? need opinions... - 10/5/2008 11:49:47 AM
gmcz71
ORIGINAL: Bunk650
what size tires?
- Vette servo's
My Pics...
Post #: 47
RE: 5.3 mods? need opinions... - 10/5/2008 12:03:11 PM
onebadrubi
ive got 4.10's in my silverado with 28" tires.  :)
2008 700h1
4" CATVOS lift
32" ****s
H1 for sale
Post #: 48
RE: 5.3 mods? need opinions... - 10/5/2008 12:09:27 PM
gmcz71
haha dang, I take it you dont go interstate much?
I bet that thing will jump off the line!
- Vette servo's
My Pics...
Post #: 49
RE: 5.3 mods? need opinions... - 10/5/2008 8:51:41 PM
Bunk650
yeah, mine are stock tires... it launches!!! still at 65mph Im turnin about 21-2200 rpms...
BUT IT KNOCKS LIKE CRAZY WHEN ITS COLD!!!!
Im thinking this week Im gonna replace the oil pump and the water pump and hopefully that will solve it...
'04 650 V2 LE
Dynatek CDI
Drilled N Clipped
28" Gators
2.5 Warn
Myspace
Post #: 50
RE: 5.3 mods? need opinions... - 10/15/2008 2:30:58 AM
nonnieselman
ORIGINAL: sanjac
Question:
My LT1 EFans cost me $80..
No way i would pay 400-500 for Electric fans, thats crazy!
The tahoes and burbs have the 34" radiator... so your goin to need it to run those fans.. most trucks have the smaller 28" radiator like mine.
The Aftermarket MAF is a waste of $$, you could go Speed Density tuned and ditch the MAF, just get a IAT Sensor and wire it in. Weight Reduction is what i call it  . Dont need no silly MAF..
You could just live with the "Tick" and save up for another engine? haha It would be funner!
You can get 5.3s for fairly cheap, and if you wanted to you could do a subtle heads/cam setup before you do the swap?
Just throwing ideas out there.
Did we just have somebody else say "CHIP"?? OH my!!
My 5.3 was ticking extremely loud, i just drove it.. I even tried to blow it up but it didnt work.. It was making some strange noises and throwing all kinds of Knock Retard at strange times.
A 2004 LQ4 sovled alot of problems and created more like rear tires wearing extremely fast, broken transmissions.. ya know the fun stuff?
< Message edited by nonnieselman -- 10/15/2008 2:33:08 AM >
2005 Red Foreman 4x4 S
-Rubi Rims w/ 26" MST
2000 Silverado ECSB
LQ4 4L80E STS Nitrous
Post #: 51
RE: 5.3 mods? need opinions... - 10/19/2008 9:39:30 PM
jeremy175
How much does it help to take out the screen at the MAF sensor? What do ya'll think about a Diablosport Predator programmer? By the way I have a 05' z71.
07 Outlander 800, 29.5's, SS wheels, pipe lift, 2 in. lift, snorkled, clutch kit, uni, mud slinger, pc III, dyno tuned, ricochet skids... FOR SALE...
(in reply to nonnieselman)
Post #: 52
RE: 5.3 mods? need opinions... - 10/19/2008 9:42:25 PM
nonnieselman
ORIGINAL: jeremy175
It doesnt do anything to descreen the MAF.. most of the times it just turns into a problem..
Get a custom tune and dont worry about the Handheld..
2000 Silverado ECSB
(in reply to jeremy175)
Post #: 53
RE: 5.3 mods? need opinions... - 10/19/2008 9:47:09 PM
jeremy175
I thought to get a custom tune I'd have to have a programmer anyways. Are ya'll getting the stock computer tuned?
Post #: 54
RE: 5.3 mods? need opinions... - 10/19/2008 9:55:45 PM
gmcz71
ORIGINAL: jeremy175
I say dont touch the MAF... instead of restricting air like most think it does, the screen actually evens the airflow out.  with it removed the airflow may get screwed up.
Just what I heard.
- Vette servo's
My Pics...
Post #: 55
RE: 5.3 mods? need opinions... - 10/19/2008 10:38:32 PM
nonnieselman
ORIGINAL: jeremy175
NO NO NO
The programmer flashes  the exact same as the Custom tune..
All you have to do is send Justin@blackbearperformance.com a email and he will send you a PCM thats already tuned and you just swap the PCM out of the truck and VOLA!!!
2000 Silverado ECSB
Post #: 56
RE: 5.3 mods? need opinions... - 10/19/2008 10:39:42 PM
nonnieselman
ORIGINAL: gmcz71
ORIGINAL: jeremy175
Just what I heard.
The screen "Straightens"  the air out so that its more consistant reading over the sensors..
2000 Silverado ECSB
Post #: 57
