RE: 400 eiger snorkel
All Forums >> [OEM Discussions] >> Suzuki >> RE: 400 eiger snorkel Page: <<   < prev  1 [2]
RE: 400 eiger snorkel - 7/24/2008 4:54:05 PM
smracing
another, hope this helps, do you need one from the airbox?
Thumbnail Image
Attachment (1)
His 2005 Eiger auto. snorkled, 27" swampfox, jetted, 14g weights. Hers 2006 Eiger auto, snorkled, 27" Mudlights, winch, pink.
(in reply to smracing)
Post #: 31
RE: 400 eiger snorkel - 7/24/2008 5:10:24 PM
coolcloo1019
A pic from the airbox would be sweet.
So that box in the front is the CVT intake...did you put the 2 holes on the top or were those there? I haven't had the front plastic off.
Where did you run your CVT exhaust?
If you've got 2 holes in the front CVT box, 1 from the air intake and 1 from the CVT exhaust, that'd be 4 snorkels. I thought there were only 3?
Sorry for all the questions, I just want to get it right the first time. lol.
2007 Suzuki Eiger 4x4 Auto
- Uni Filter
- DynoJet Kit
"Do work!"
Post #: 32
RE: 400 eiger snorkel - 7/24/2008 5:23:18 PM
mudder32
yea i need to know every thing so like coolcloo1019 said i want to get right the first time.
04 suzuki eiger 400
-27" mudlites/ITP 589
-2500 warn winch
(in reply to coolcloo1019)
Post #: 33
RE: 400 eiger snorkel - 7/24/2008 7:34:29 PM
smracing
the airbox
Thumbnail Image
Attachment (1)
(in reply to mudder32)
Post #: 34
RE: 400 eiger snorkel - 7/24/2008 7:35:35 PM
smracing
side view
Thumbnail Image
Attachment (1)
Post #: 35
RE: 400 eiger snorkel - 7/24/2008 7:36:53 PM
smracing
top with snorkles on
Thumbnail Image
Attachment (1)
Post #: 36
RE: 400 eiger snorkel - 7/24/2008 7:38:47 PM
smracing
another pic  of mine
Thumbnail Image
Attachment (1)
Post #: 37
RE: 400 eiger snorkel - 7/24/2008 7:46:51 PM
smracing
for the cvt vent box i sealed up the stock holes in front and ran 2 snorkles to ensure enough air gets to the carb and tranny. for the rear cvt vent hose that comes up under the rear fender behind the  batt box i just sealed it up (I know riding on long hard rides could overheat the belt but so far short rides in deep water has worked well!) i also ran all the other vent lines (carb, fuel tank, fan, rear brake) with plastic line and compression fittings to the vent box, make sure you run the carb as a seperate vent or it could run like crap.
Post #: 38
RE: 400 eiger snorkel - 7/24/2008 7:59:25 PM
coolcloo1019
What if for the rear vent for the CVT instead of completely plugging it off could you plug off the big hole and then put like a 1/2" vent line ran to the front with all the other vent lines. it's not like actual exhaust comes out of there, its just warm air...
Just a thought I had. Im outside now with everything taken apart trying to figure out exactly how I want to run everything. If I didn't have to run an exhaust to the front as well as the air intake it would make my life a lot easier.
So that's why I came up with the thought I just wrote above.
- Uni Filter
- DynoJet Kit
"Do work!"
Post #: 39
RE: 400 eiger snorkel - 7/24/2008 8:03:23 PM
heath42
I have the spa hose on as my snorkel. It hasn't leaked yet, and will make your snorkel job a lottttt easier!  You wont have big bends like PVC and all you need is to cut once for one piece, instead of cutting 3 or 4 times and making numerous bends.  Also, with the less bends, your bike will run better than when you have more bends (until you jet it).
2004 Eiger manual 4x4, snorkled, HMF Utility, Warn 2500 winch, Uni air filter, Dynojet jet kit, carb slide mod, EPI Clutch Kit & 27" Executioner
2006 Yamaha TTR125L
2004 Chevrolet Silverado 1500 4x4, 6" Fabtech lift on 35" BFG Mud Terrains, throttle body, intake, Magnaflow exhaust
TEAM SWAMP DONKEY
Post #: 40
RE: 400 eiger snorkel - 7/24/2008 8:25:31 PM
smracing
like the idea of 1/2 or maybe even 1". I seem to remember another guy running his cvt exhaust along the left side as well as the carb air hose, down along next to the skid plate. good luck and let us know how she turns out!
Post #: 41
RE: 400 eiger snorkel - 7/24/2008 8:41:23 PM
lileigerthatcan!
here are some pics of how mine is ran.
Thumbnail Image
Attachment (1)
07 Eiger 4x4 Manual
27" Vampires
Warn front bumper and lights
2000Lb Warn Winch
HMF Utility slip on
Custom snorkel
UNI filter
Deathgrip grips
Post #: 42
RE: 400 eiger snorkel - 7/24/2008 8:47:41 PM
lileigerthatcan!
here are a few more
Thumbnail Image
Attachment (1)
07 Eiger 4x4 Manual
27" Vampires
2000Lb Warn Winch
HMF Utility slip on
Custom snorkel
UNI filter
Deathgrip grips
(in reply to lileigerthatcan!)
Post #: 43
RE: 400 eiger snorkel - 7/24/2008 8:51:16 PM
lileigerthatcan!
this is where it turns from the left side of the bike under the front fender to come up to the middle
Thumbnail Image
Attachment (1)
07 Eiger 4x4 Manual
27" Vampires
2000Lb Warn Winch
HMF Utility slip on
Custom snorkel
UNI filter
Deathgrip grips
Post #: 44
RE: 400 eiger snorkel - 7/25/2008 7:11:02 AM
mudder32
do you have any pics of how you ran the belt exhaust?
04 suzuki eiger 400
-2500 warn winch
Post #: 45
RE: 400 eiger snorkel - 7/25/2008 7:25:29 AM
lileigerthatcan!
mine is a manual so i didnt have any belt exhaust to deal with, made it alot easier! SMRACING could probably help out with that....
07 Eiger 4x4 Manual
27" Vampires
2000Lb Warn Winch
HMF Utility slip on
Custom snorkel
UNI filter
Deathgrip grips
Post #: 46
RE: 400 eiger snorkel - 7/25/2008 7:34:11 PM
coolcloo1019
smracing, you have a PM
- Uni Filter
- DynoJet Kit
"Do work!"
Post #: 47
0.547
