RE: Crankcase snerk
RE: Crankcase snerk
All Forums >> [OEM Discussions] >> Can-Am BRP >> RE: Crankcase snerk Page: <<   < prev  1 [2]
RE: Crankcase snerk - 7/11/2008 7:52:14 AM
greenhead
yeah the crank doesnt like sand and water. IF you dont have a filter on it, orielly's has them for 12.99 for the stainless steel one. i would put it on there.
Team Gander Mountain Racing
and powered by HIGHLIFTER
Hensley #88
MUD NATS 08 MuddaCross 2nd Place
TEXAS MUD JAM 08 Open Bog 2nd Place
TEXAS MUDFEST 08 Fri-Pro Series B 1st
TEXAS MUDFEST 08 Fri-Open 3rd
TEXAS MUDFEST 08 Sat-Pro Series B 1st
TEXAS MUDFEST 08 Sat-Open 2nd
CANAM NATIONALS 08 Swamp Cross Open 2nd
CANAM NATIONALS 08 Open Bog 1st
RURAL SHADE C.M.R 08 Pro class 3-1st
RURAL SHADE C.M.R 08 Open 2nd
http://www.myspace.com/1mallard
(in reply to pbradley)
Post #: 31
RE: Crankcase snerk - 7/11/2008 8:36:52 AM
tdawg
Got mine up top with filter (Greenhead special) so I don't get mud in it, lol
Thumbnail Image
Attachment (1)
2008 Can Am 800 LTD. 28x9.5 all around, snorkels, 4" CATVOS lift
(in reply to greenhead)
Post #: 32
RE: Crankcase snerk - 7/11/2008 8:56:31 AM
chrisgrizzly660
ORIGINAL: tdawg
Thumbnail Image
Are you sure there is no mud in it?    Same place I got mine
Its real nice how some poeple turn there back on you.. Be carefull who you trust and Be even more carefull Who you bend over backwards for!!!!!!!!!!!! You never know who you can trust!!!!!!!!
07 CanAm outlander 800 XT, ITP C7, 26" Mudlites, Snorked, Skids, Tamarack Boxes, Warn 2500 Winch,
Garmin GPS HMF, UNI, Symtec grips, Renegade Pegs, PT Frame Mod
CumberLand ATV Riders
[url=http://www.windrockatv2.com/phpBB/index.php]Windrock AT
(in reply to tdawg)
Post #: 33
RE: Crankcase snerk - 7/11/2008 3:54:32 PM
biggbowls
hey tommy.......i remember that hole.....pearland right?
'07 MAXIMUM 650
Sum a dis and a lidl a dat
(in reply to chrisgrizzly660)
Post #: 34
RE: Crankcase snerk - 7/11/2008 4:44:20 PM
tdawg
ya, we call it elanor...  I have made it through it a few times, not so much that time.
There is a video of me going through it on you tube before I got stuck on the third time through.
(in reply to biggbowls)
Post #: 35
RE: Crankcase snerk - 7/15/2008 6:30:43 AM
pbradley
Another thing I did was install a rubber snap tite drain plug from a boat on the bottom of my air box so I can quickly drain any water that get in if need be.
Post #: 36
RE: Crankcase snerk - 7/23/2008 10:46:14 PM
Eric_Dinelle
so I am wondering, what is the best way to keep the water out ???
I've got my snorkels coming out of the little compartement behinde my speedometer, would it be better to run it in ther with a filter or is ther a better place? and loops how many loops should I run in the hose?
Post #: 37
RE: Crankcase snerk - 7/25/2008 9:33:48 AM
tdawg
one loop will do, run it up on the console like mine in the picture above.  You want it out of the box.  Read above ^
(in reply to Eric_Dinelle)
Post #: 38
RE: Crankcase snerk - 7/28/2008 11:17:23 AM
sgt_grinch
How big of a loop and should the loop be high or low?
07 CAN-AM 800
HMF OPTIMIZER
*new* 28 sbacks/12"TORK WHEELS
relocated radiator
HMF UTILITY SERIES
2"LIFT
FULL SNORKS
07 Kingquad(hers)
27" swamplites/14"itp
snorkeled
(in reply to tdawg)
Post #: 39
RE: Crankcase snerk - 7/28/2008 5:22:00 PM
tdawg
Put the loose loop just under the console.
(in reply to sgt_grinch)
Post #: 40
RE: Crankcase snerk - 7/28/2008 5:43:56 PM
biggbowls
Even though mine is in the airbox, I have clear hose with two loops in it.  I just cable tied loops in the hose.
'07 MAXIMUM 650
(in reply to tdawg)
Post #: 41
RE: Crankcase snerk - 7/28/2008 6:05:59 PM
sgt_grinch
Thanks
07 CAN-AM 800
HMF OPTIMIZER
relocated radiator
HMF UTILITY SERIES
2"LIFT
FULL SNORKS
07 Kingquad(hers)
snorkeled
Post #: 42
RE: Crankcase snerk - 7/28/2008 7:57:32 PM
jeremy175
How do the loops keep water out if the filter was to go under? Do the loops only work when the filter is outside of the airbox?
07 Outlander 800, 29.5's, SS wheels, pipe lift, 2 in. lift, snorkled, clutch kit, uni, mud slinger, pc, dyno tuned
Post #: 43
0.344
