bocephus660
Yes. New OEM crank and rod assembly, .20 over OEM piston, cylinder,rockers,valves,valve,springs,cam,timing chain,oil pump chain,ect..Like I said I rebuilt the top end 3 times and each time it would last 5 min and start smoiking.Got tired of that and had it totally redone.New bolts on everything on the topend,they are allen heads and got stripped from taking it apart so had all them replaced. Axles are from an 07 model. I traded klienwild my gorillllwa lift for his stock suspension of a 07 grizzly that had 200 miles on it. No leaky seals that I know of. All electronics work perfect. All indicators for 4x4,diff lock,hrs,miles,clock,trip,gear position indicator,headlights,ect all work perfect. Doesnt have any lift on it, all stock suspension. Only thing I noticed when I rode it is it needs new brake pads on the rear, kinda makes a lil grindin noise when you apply them but work great.Guess it was from sittin up so long.Also I took the guts out of the pull rope starter and plugged it off, so it doesnt have that.Has the 2 holes in the plastic where the snorkels were.Thats the only negative things I can think of.
TBC RACE TEAM ODB/FCP Brute,08 Teryx,02 Eiger "Good things come to those who wait..BUT..Only the things left behind by those who hustle" http://www.flickr.com/people/bocephus1/
