RE: HID headlights!!! WOW, Incredible
All Forums >> [OEM Discussions] >> Kawasaki >> RE: HID headlights!!! WOW, Incredible Page: <<   < prev  7 8 [9] 10 11   next >   >>
RE: HID headlights!!! WOW, Incredible - 5/17/2008 1:51:08 AM
dbmachine
I just installed the HID lights on my 2008 700 Grizzly yesterday...These things are so bright that they will blur your vision if you look head-on into them. Very cool and very easy to install on the grizz. Everything is plug and play. No modding of the headlight socket or the wiring. I went with the 80$ kit on ebay with the slim ballest with the 8000 series color choice. Its a nice blue tone. I wanted it more for looks than function or i would have went with the whiter 6000 series. Overall im impressed. The ballest make a humming noise for about 8 seconds then it goes away as the lights warm up..The hardest part i had with the install was finding a place to mount the ballest but managed to get it done. Took about a hour start to finish and that involved removing the front rack and plastics for the battery compartment. I dont know how reliable this setup will be for riding mud and water or how long the bulbs will last due to the vibrations etc. But it is easy enough to remove and put back stock for the grizzly. You guys with the brutes may have to purchase new light socket assemblies..
(in reply to Bry Ownz)
Post #: 241
RE: HID headlights!!! WOW, Incredible - 5/17/2008 8:58:14 AM
elkbow
i actually bought spare sockets for the brute when i started, so if i wanted to go back to stock i can and didn't cut any of the factory wiring
Dave
'08 Kawasaki Brute Force 750 Camo
26" Terracross on SS212's
Elka Sports/Racing Series Shocks
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
'07 Dodge RAM 2500 Diesel
6" Superlift, 35" Toyo MTs on Moto Metal 951B's
ATV Magazine
(in reply to dbmachine)
Post #: 242
RE: HID headlights!!! WOW, Incredible - 5/17/2008 8:59:37 AM
elkbow
ORIGINAL: kawi_rider
Ok thanks alot. what size fuse did you use for the positive battery lead(pin 30)?
I used a 25 amp i believe
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
(in reply to kawi_rider)
Post #: 243
RE: HID headlights!!! WOW, Incredible - 5/17/2008 1:05:50 PM
Bluegrass Brute
I don't see how you guys got the wiring through the hole that's drilled out unless you make it huge.
Lance
2007 BRUTE 750 (CANDY BLUE) HMF FULL, K&N, COPPERHEAD VDI, DIAL-A-JET, DYNOJET KIT, WARN 3.0 XT (RED), FULL RICOCHET SKIDS, HL BUMPER, 2" LIFT, ALMOND SEC, 27-11-14 XTR's ON VISION OUTBACKS, HID LIGHTS........
2004 RANCHER 400AT BIG GUN, K&N, LIFT, 26-12-12 ITP MUDLITES ON TYPE 4's ,WARN 2.5CE WITH MULTI MOUNT
SOME PICS AND VIDS OF ME AND MY FRIENDS
http://photobucket.com/Bluegrass
http://photobucket.com/Ridinpics
http://photobucket.com/Ridinvideos
(in reply to shore)
Post #: 244
RE: HID headlights!!! WOW, Incredible - 5/17/2008 1:12:12 PM
ALMOST30S
Yeah it takes a decent size hole to get them thru there.
(in reply to Bluegrass Brute)
Post #: 245
RE: HID headlights!!! WOW, Incredible - 5/17/2008 1:27:36 PM
ALMOST30S
Good thing i shiped them usps or You wouldnt have gotten them till monday lol.But you will be very pleased with the results after you turn them on for the first time..Gona look like day light in front of you.Make sure you have read the beginning of this thread,So you will know how deep to mount the bulbs them so your beam wont look all messed up or out of focus like mine is lol.And be sure you dont touch the bulb!
(in reply to ALMOST30S)
Post #: 246
RE: HID headlights!!! WOW, Incredible - 5/17/2008 3:50:13 PM
elkbow
ORIGINAL: Bluegrass Brute
its impossible, so i don't know how anyone does either, at least not from the front, you can push the bulb in from the rear once you get the receptacle hollowed out....but the connectors on the 9006 will not fit through the receptacle..... maybe the h3 is different, i wouldn't think so
and you don't want to do it other than push the bulb in from the back, no reason to and could damage them if you went the other way
< Message edited by elkbow -- 5/17/2008 6:16:31 PM >
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 247
RE: HID headlights!!! WOW, Incredible - 5/17/2008 6:01:13 PM
Bluegrass Brute
Elkbow what did you hook your power wires coming off the relay into? Do I just tap into the factory harness for the high beams or the bigger wires of the hid kit itself?
Lance
Post #: 248
RE: HID headlights!!! WOW, Incredible - 5/17/2008 6:20:19 PM
elkbow
there is a power in to the relay, that is the fused wire from the battery, then there is a power out to the positive (red) wire on the ballast
the trigger wire for the relay is what comes from the red striped wire on the harness that was removed from the main bulb....since there are 3 connections on it, the outer one is red with some stripe color the other outer one is black with a stripe, the inside one is the low beam, don't need it.....
if you want me to draw it up for you i will, i will do it here shortly and show you how to wire it up, you don't need to cut anything other than the connector off of the ballast, you can use male and female spade connectors to connect everything together....
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 249
RE: HID headlights!!! WOW, Incredible - 5/17/2008 6:30:33 PM
Bluegrass Brute
So since I've got mine hooked up on the high beam I run a fused wire to the bat then a ground to the chasis. Then I need a power going to the ballast power and a separate power going to the high beam wire? Is that right? How do I get it to both sides? Do you just splice of the two power wire then run separate wires to each light? I'm only running one relay.
Lance
(in reply to elkbow)
Post #: 250
RE: HID headlights!!! WOW, Incredible - 5/17/2008 7:19:55 PM
elkbow
no....
if you are running only one relay to power both sides, you do not need the harness you removed on the one side out of the main bulb
you will need the harness on one side you pick, there are 3 connections on that harness, the middle wire is the low beam, will not be used.....the two outside wires are the high beam and the ground....
so, take the high beam wire on the harness and run it to the trigger connection on the relay
take the ground wire on the harness and make a connector that connects to it and has 3 connections on the other end, make your own little harness, one wire goes to the relay ground, one to each black wire on each ballast connector on each side....
then you need a wire, fused, from the battery, it goes to the power input on the relay, pin 30
then the power output from the relay goes to each postive (red) connector on the ballast
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 251
RE: HID headlights!!! WOW, Incredible - 5/17/2008 7:33:27 PM
Bluegrass Brute
Got it thanks! I still will have to keep the other side factory harness connected to the small outer light though right?
Lance
Post #: 252
RE: HID headlights!!! WOW, Incredible - 5/17/2008 7:36:15 PM
elkbow
yes, on both sides you need to keep the smaller light harness connected
i'll draw up your connections tonight and post it up so you can see it, will also draw up a two relay connection for those that want them on both sides
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 253
RE: HID headlights!!! WOW, Incredible - 5/17/2008 7:42:17 PM
Bluegrass Brute
That would help out tons. I've pretty much got mine now but others will use it. I haven't had any trouble out of mine both not coming on except when I didn't have the bike running. It runs the bat dead pretty quick without being started. After I let it run awhile and charge up they both come on perfect. I guess these batteries are just enough to run these lights.
Lance
Post #: 254
RE: HID headlights!!! WOW, Incredible - 5/17/2008 8:23:17 PM
elkbow
yeah, the batteries are too small, Polaris puts big honkin' batteries in their machines and you can get an Odyssey Dry Cell that drops right in, 925 Cold Cranking Amps....will run anything
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 255
RE: HID headlights!!! WOW, Incredible - 5/17/2008 11:02:43 PM
Bluegrass Brute
I'm pretty sure somebody already said it but if you use the H3 bulbs you have to glue to the very edge if you want your beam to look like STOCKSTINKS is on his garage door.
Lance
Post #: 256
RE: HID headlights!!! WOW, Incredible - 5/17/2008 11:29:27 PM
elkbow
here is the connection using just one relay, you only have to use the harness that you removed from the main bulbs from one side, just tape off the other one, it isn't required, whatever side you use will provide the ground and the trigger
This is the schematic to use one relay:
This is the schematic if you want to use a relay on each side, for each HID, you need this on each side:
< Message edited by elkbow -- 5/18/2008 9:46:06 AM >
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 257
RE: HID headlights!!! WOW, Incredible - 5/18/2008 12:41:38 AM
Bluegrass Brute
Very helpful Dave! Anybody should be able to understand that.
Lance
Post #: 258
RE: HID headlights!!! WOW, Incredible - 5/18/2008 8:26:47 AM
shore
I've left my HID's on for 30 minutes at a time with the engine off and the stereo playing and it cranks right up no problem.
If the HID's are pulling your battery down at all you have another problem.Either a bad ground somewhere or a weak battery.The HID's don't use nearly as much current as the stock halogen when lit.
06 Silver Brute Force 750
Penland/Dynatek/fully snork'd
2" SSATV lift
27" Swamplites on SS112's
Post #: 259
RE: HID headlights!!! WOW, Incredible - 5/18/2008 9:07:32 AM
elkbow
actually the HIDs draw about 3.6 amps at 12V, but the stock halogen draw as much as 8 amps...
if your voltage drops below 9v, the ballast will shut off, it has the same thing if the voltage gets too high, it will shut off....
there are alot factors that come in to play here, but realistically the HID is easier on your system, but I would still suggest running relays to make sure they run optimum.
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
(in reply to shore)
Post #: 260
RE: HID headlights!!! WOW, Incredible - 5/18/2008 10:19:25 AM
ALMOST30S
Yeah i think you have a weak battery man ive never had any  problems either.But i do have some kind of aftermarket battery in mine,like a yifutsa or something lol
Post #: 261
RE: HID headlights!!! WOW, Incredible - 5/18/2008 10:40:59 AM
elkbow
the Yuasa is the stock battery and only one size fits, the KMX14-BS which comes stock or the YTX14-BS which is mainly put in motorcycles, both have 12AH rating on them
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 262
RE: HID headlights!!! WOW, Incredible - 5/18/2008 11:15:26 AM
ALMOST30S
Ugh nothing like getting lied too.I got an idea for a battery to go in there neways.
Post #: 263
RE: HID headlights!!! WOW, Incredible - 5/18/2008 11:56:19 AM
elkbow
i ordered a different battery of a different type, 14AH, but place hasn't shipped it yet.....also, Deka makes an AGM battery, but not sure its any better than stock.....there is a possibility to get a bigger battery, but would have to change mounting, don't think its worth it
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 264
RE: HID headlights!!! WOW, Incredible - 5/18/2008 12:01:42 PM
ALMOST30S
Im about to go measure an idea i have right this second.Ill let you know
Post #: 265
RE: HID headlights!!! WOW, Incredible - 5/18/2008 6:26:08 PM
Bluegrass Brute
Yeah I know my batteries are really weak and probably close to destroyed. Last week when it turned over in the creek I ran them dead over and over again trying to get it started. I still haven't been on a ride yet since fixing it so maybe once I ride it awhile it'll charge back up.
Lance
Post #: 266
RE: HID headlights!!! WOW, Incredible - 5/18/2008 6:37:43 PM
ALMOST30S
I think the batcap 800 willl fit with some slight mods to the battery tray.
Post #: 267
RE: HID headlights!!! WOW, Incredible - 5/19/2008 9:38:30 PM
elkbow
whats the ratings on the batcap?
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 268
RE: HID headlights!!! WOW, Incredible - 5/19/2008 9:45:54 PM
elkbow
i found the dimensions on the batcap 7"W x 3"D x 6-1/2"H
won't fit, but will fit if you get the CVT snorkel out of the way and get a different mount, hence my next project, but i'm gonna look at the dimensions on the Odyssey drycell
Dave
HMF Penland ECO
Power Commander
VFJ Stage 3 Clutch
ATV Magazine
Post #: 269
RE: HID headlights!!! WOW, Incredible - 5/19/2008 10:24:31 PM
ALMOST30S
well i have snorkels on mine so my belt exhaust isnt in the way theres just a big open area there just waiting on that batcap 800
Post #: 270
Page:   <<   < prev
