elkbow
yeah, I will be adding the relays, I was thinking of just using my panel, but that won't work, so I will be adding a single relay in the front that will drive both HID ballasts.....I'm gonna try some things, since there is a separate wire going to each headlamp, the wiring is the same, High, Low and ground, I'm going to use just one of the wires, not the other one, to drive the relay, and only use one ground on the same harness...going to see if that works first, if it does, i'll just heat shrink/seal off the other one, this way they are both driven at the same time, since power is coming directly from the battery, both will have same source at the same time, the relay will be trigger by one wire at the same time, not two relays being triggered by two different wires, even though I know those wires are tied together somewhere......this will just save me the trouble of having to wire in two relays
Dave '08 Kawasaki Brute Force 750 Camo '09 Polaris Ranger XP Camo ATV Magazine
