RE: HID headlights!!! WOW, Incredible
All Forums >> [OEM Discussions] >> Kawasaki >> RE: HID headlights!!! WOW, Incredible Page: <<   < prev  1 [2] 3 4 5   next >   >>
RE: HID headlights!!! WOW, Incredible - 3/13/2008 9:42:01 PM
azbrute
My Hid's will flat blind on coming traffic. Don't know how you are going to get around that with out turning lights off.
Where I hunt there is always traffic early morning and after sun down of hunters going to different areas.
BF750
(in reply to StockStinks)
Post #: 31
RE: HID headlights!!! WOW, Incredible - 3/13/2008 9:45:04 PM
shore
They can be adjusted down a good bit with the set screw.
06 Silver Brute Force 750
Penland/Dynatek/fully snork'd
2" SSATV lift
27" Swamplites on SS112's
(in reply to azbrute)
Post #: 32
RE: HID headlights!!! WOW, Incredible - 3/13/2008 10:03:28 PM
azbrute
HID's come in different lumens, not sure what you have. I have 4-1850 lumens @ 30 watts each. Great idea but mine are so bright I have to turn them off. They have there own ballast and self contained so mounted on brush bar.
BF750
(in reply to shore)
Post #: 33
RE: HID headlights!!! WOW, Incredible - 3/13/2008 10:08:07 PM
ricehaterboi
WOW thaaaaats BRIGHT Ive got two buddies with Kawis and I gurantee their gonna wanna do this to theirs! Plus im puttin em on the dood ole PoPo ;)
~MoMo
07 Polaris Sportsman 800 Camo (DOWN FOR REPAIRS)
RT30 Winch
Snorks!
HID's!
Ranger front/rear springs
Snorkeled vent lines, overflow bottle
sealed CVT cover
Pure Front/Rear bumper
Pure Front/Rear Rack extenders
K&N Air filter
Soon to come:
Radiator Relocate
2" RD lift
Mudslinger
programmer
Ape 30's on 108's
http://www.myspace.com/ricehaterboi
http://www.mymudspace.com/ricehaterboi
(in reply to shore)
Post #: 34
RE: HID headlights!!! WOW, Incredible - 3/14/2008 9:02:11 AM
shore
ORIGINAL: azbrute
You're set-up is totally different, no doubt you have those issues.
In a reflector headlight,which is what we are doing, you can make a cut-off for the beam.it's pretty simple.
2" SSATV lift
Post #: 35
RE: HID headlights!!! WOW, Incredible - 3/14/2008 4:29:10 PM
StockStinks
SHORE is right about the factory reflector having the blinding light cut off......You can see how it works in the picture above with it shining on my garage door.
Just for the record......I have the same HID light that AZBRUTE is talking about. It is on my sport machine and I HATE the fact that the reflector doesn't have the cutoff .
This mod is much better for general trail riding. I see NO reason for the non-cutoff type light, other than it would be cheaper to manufacture.
2005 Brute Force with Big gun power deallie-doo. And 25" Big Horns on Douglas Rattlesnake rims. K&N jet kit, Twin air filter, and a Big Gun full exhaust system.
Recently added HID lights and amber side lights.
I also modified a Polaris rapid mount plow mount to fit the Brute.
2nd bike is a 2005 Kawasaki Kfx 400 (Sport quad) Piped, filtered, jetted, Elkas, and a bunch of other stuff.
(in reply to shore)
Post #: 36
RE: HID headlights!!! WOW, Incredible - 3/15/2008 10:16:24 AM
shore
ORIGINAL: StockStinks
You have a factory cut-off in your housing?
I did my HID's yesterday and WOW.This is an impressive mod.
Things I noticed.
1...I don't see the need for a relay just yet.They fire up at the same time easily.Only one time did one not light on the 1st try.
2...The headlight housing lets a lot of light go into the fender well and radiator area.HID's just make this more noticeable.
3...These slim-ballast kits are very well made for what it costs.All weather-pack connections and sealed up nicely.Other than putting some dielelectric grease in the harness it is all good and tight.
4...The lights are so bright an clear it is apparent that I need to polish my headlights a bit.Everey small scratch and chip is amplified.
5...I'm a little concerned with the heat in the housing.It gets very warm after awhile.I doubt the lens will melt but for certain the RED RTV is needed to seal up the bulb in the socket.The regular stuff would melt fast.
By far the coolest thing is when the bulbs are cold and you flick them on....3-4 seconds of the bulb getting brighter and changing color.
Don't ask me for links but if you go to Ebay you will find almost the same kits that StockStinks uses for $79 shipped.Exact same ballast.TONS of them on there just use "slim ballast" as a search term in ZENON lights.The kit is very well made.It does require some work to fit the bulb in the stock socket but a Dremel almost makes it fun.
< Message edited by shore -- 3/15/2008 10:23:18 AM >
2" SSATV lift
Post #: 37
RE: HID headlights!!! WOW, Incredible - 3/15/2008 5:56:34 PM
freak show
I must of missed in the reading did you guy's say what the user's id was that you bought the hid's from????????
I seen that painter has the guy's name in his post just want to know if it's the same guy???????????or is there another top secret dude  please post his user name from ebay.so I have some options and compar
(in reply to shore)
Post #: 38
RE: HID headlights!!! WOW, Incredible - 3/15/2008 6:30:27 PM
ALMOST30S
dude im buying some of these......um NOW LOL
(in reply to freak show)
Post #: 39
RE: HID headlights!!! WOW, Incredible - 3/15/2008 7:06:51 PM
shore
supervtec
2" SSATV lift
(in reply to ALMOST30S)
Post #: 40
RE: HID headlights!!! WOW, Incredible - 3/15/2008 8:35:31 PM
atvlvr1
Dang, those are bright !!!
08 750 Brute
2500 Warn Winch
26" ITP Terracross'
Muzzy Exhaust
Power Commander III
Vforcejohn Stage 3 Clutch
Gibson Steering Stabilizer
dei header wrap
Custom $90 Skidplates
(in reply to shore)
Post #: 41
RE: HID headlights!!! WOW, Incredible - 3/17/2008 2:55:08 PM
shore
Well yesterday was good test for them.The only thing to keep an eye on is if both light up.Out of several times I turned them on twice one light would not light on the intial try.The very next try was 100% successful.
I rode rack deep water a lot and never had a falter.They where submerged completely several times with no effect while on or off.
I also had my Audiopipeplaying for a good amount of time and they still lit right up even with the bike off.
The lens never showed any signs of heat stress.You will however notice any imperfections in the lens it shines though.I have some small scratches and I can see where it affects the light beam.
The funny part is riding with other bikes, for they look to have candles for headlights.I see no further than a good set of clean stock lights but what you see is totally different.When riding behind someone my HIDs will drown out their lights.You couldn't even tell they had their lights on.
Overall I give it a very positive experience so far.
2" SSATV lift
(in reply to atvlvr1)
Post #: 42
RE: HID headlights!!! WOW, Incredible - 3/17/2008 4:18:07 PM
StockStinks
Cool. If you hook them up with a relay like I did, you might get them to both light every time.
(in reply to shore)
Post #: 43
RE: HID headlights!!! WOW, Incredible - 3/17/2008 5:31:42 PM
shore
Mine use the stock harness.You can't tell they Are even there unless you look on top of the headlight housing or for the bulb.When I say several times I am talking about 30 or so times over the course of the night.We didn't leave down there till about 1am.Long dang day.
2" SSATV lift
Post #: 44
RE: HID headlights!!! WOW, Incredible - 3/17/2008 5:33:04 PM
shore
How about that reflector/cut-off you have in yours?
I'd like to know about that.My beam needs more direction.
2" SSATV lift
(in reply to shore)
Post #: 45
RE: HID headlights!!! WOW, Incredible - 3/18/2008 4:37:14 PM
ALMOST30S
Heck yes,I bought 2 kits just a minute ago.I got one h3 35 watt kit with 4300k and theni got another kit with the h3 55 watt kitt with the either 5000k or 6000k lighting.Cant wait to get them in and try them out,although my brute has pretty bright lights on it now when i got it fromt he other guy, maybe he had put silverstars in it or somethin...i dont know but i cant wait to watch these hids flicker on!
(in reply to shore)
Post #: 46
RE: HID headlights!!! WOW, Incredible - 3/19/2008 1:25:45 PM
shore
I'd be real careful with that 55watt kit.The 35 watt HID one is VERY hot on the lens.Hot enough to where you don't want to touch the lens after awhile.
2" SSATV lift
Post #: 47
RE: HID headlights!!! WOW, Incredible - 3/19/2008 1:59:08 PM
ALMOST30S
Ok man ill watch out for that,I think im going to buy some off road light housing and mount themin there and have 4 hids
(in reply to shore)
Post #: 48
RE: HID headlights!!! WOW, Incredible - 3/19/2008 4:31:28 PM
StockStinks
I promise you won't need more than 2 HID's
Very inportant..... You must get the little round glowing part of your new HID light bulb in the EXACT same spot as your old halogen filament was. If you don't, Your light pattern will be distorted.
I played around with the bulb placement before I glued it in place and the factory spot was right on!
Post #: 49
RE: HID headlights!!! WOW, Incredible - 3/19/2008 4:50:41 PM
ALMOST30S
ok ill keep that in mind too.I might just install the other ones on my backup bike or something lol
Post #: 50
RE: HID headlights!!! WOW, Incredible - 3/19/2008 5:16:26 PM
shore
Yup, very true.The depth and position of the HID need to be spot-on for the beam pattern to work properly.
I'm learning this lesson right now...lolz.
2" SSATV lift
Post #: 51
RE: HID headlights!!! WOW, Incredible - 3/19/2008 5:30:54 PM
ALMOST30S
I can see shore sittin on his brute in the middle of the street with his lights on scratching his head wondering why one light is shining at the ground and the other one is shining at the mailbox and trees lol
(in reply to shore)
Post #: 52
RE: HID headlights!!! WOW, Incredible - 3/19/2008 5:57:18 PM
shore
ORIGINAL: ALMOST30S
Lol, not quite.
You can adjust them up/down to be even with each other.The problem arises when the reflector is throwing the beam all around.I positioned the bulbs identicaly to each other but there was something off about it.
It would shine everywhere basically.Even so in the bulbs incorrect postion,it is an impressive amount of light output.
2" SSATV lift
Post #: 53
RE: HID headlights!!! WOW, Incredible - 3/19/2008 6:19:40 PM
ALMOST30S
man i cant wait to get mine in so i can blind some people  there gonna be looking like this and then like this then llike this and ima be like this hahah it was just a joke
(in reply to shore)
Post #: 54
RE: HID headlights!!! WOW, Incredible - 3/20/2008 7:43:01 PM
shore
Well, I got the bulbs repositioned and aligned.Resealed the socket and waited till dark.
Wow, what a difference.There is a sharp cut-off now which means no upper and side glare.
The new HID bulb base needs to sit about 1/4" down into the original socket and the igniter tube needs to be on the bottom.
Minor detail that needs 100% of your attention.I was only 1/4" outside the socket with the HID bulb base and there was no beam pattern or cut-off.
It also feels as if the lens is running cooler now.
2" SSATV lift
Post #: 55
RE: HID headlights!!! WOW, Incredible - 3/20/2008 9:52:47 PM
canadabf750
you dont need a relay the hid draw less power
07 brute 750
27x14 itp mudlite xtr radial
moose module
dalton clutch kit (big tire)
(in reply to shore)
Post #: 56
RE: HID headlights!!! WOW, Incredible - 3/21/2008 12:26:02 AM
ALMOST30S
JUst waiting on them to come in now.Man they cant get here fast enough
(in reply to canadabf750)
Post #: 57
RE: HID headlights!!! WOW, Incredible - 3/21/2008 8:38:51 AM
shore
ORIGINAL: canadabf750
That's a yes and no answer to a question you might not understand yet.
HID ballasts use MORE amperage to start/ignite the bulbs than the stock halogen.After that initial hit then yes,they use less.It lights gas in the bulb versus a filament.The intial hit to fire the gas is a bit more than filament bulbs.
The issue you get into is if both igniters fire at the EXACT same time.Most of the time one will fire before the other.A portion of a second difference and they both fire up.They might be on the same wire harness but you have to remember these ballasts operate at 20k volts.The intial will most often vary.Not to say they don't appear to fire identical.
2" SSATV lift
Post #: 58
RE: HID headlights!!! WOW, Incredible - 3/21/2008 11:06:16 AM
ALMOST30S
That sounded like a real edjucated  explanation lol.As long as they turn on and dont melt my lenses ill be happy
(in reply to shore)
Post #: 59
RE: HID headlights!!! WOW, Incredible - 3/25/2008 11:56:06 PM
ALMOST30S
I started on my HIDS tonight,Got the lights taken apart and  the hids set in the old light housings about 1/4 of an inch or maybe just a hair less.Gona start back on them in the morning and get them finished up,hopefully these 55 watts wont melt my lenses
Post #: 60
New M
