RE: custom stereos
RE: custom stereos
All Forums >> [Most Popular Discussions] >> ATV Accessories >> RE: custom stereos Page: <<   < prev  4 5 [6] 7 8   next >   >>
RE: custom stereos - 4/20/2008 8:48:22 PM
RUFFRYDER
another
Thumbnail Image
Attachment (1)
2008 Prowler XT, 28 Zillas on ITP 212s, AC bumpers front and rear, custom tunes. More to come...
2001 Kodiak, 26 Dirt Devils, HL bash plate, Big Gun, Jetted and K & N filter, full skids by prm.
(in reply to RUFFRYDER)
Post #: 151
RE: custom stereos - 4/22/2008 10:15:08 PM
LAswamprat
For those of you making a homemade audiopipe, check out the Pyramid 240 watt amp on ebay. I bought 2 and 2 sets of Bazooka 6.5's
for my 2 pipes. They sound very clean and put out enough power to listen while you ride. The best part about this amp is that it's only 4.75" wide and fits well in the
pipe. Check out the link for more info... (http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160230142344)
2008 Grizzly 700 FI EPS(Steel Blue)
Ricochet Aluminum A-Arm Guards
HL Outlaw 28's on Vision 159's
Uni Filter
Homemade Audiopipe & Otterbox for IPod
Sylvania Silverstars
HMF Utility & Optimizer
2005 Rhino 660 Camo
Swamplite 27's
ITP Black Type 7's
BRP CDI Box & Grizzly Sheave & Big Gun Evo
2"Moose Lift
Windshield, Roof, Overfenders
Viper Winch, Sound Wedge, Amp & Tunes
Roof Light Bar w/ Hellas
UNI CVT Filter
Rhino Bed Rails
Pro Armor Bumpers
Post #: 152
RE: custom stereos - 4/28/2008 3:43:22 PM
TREYGRIZ
does anyone have a pic of a bike with a relocated radiator and a audio pipe?
KOSCIUSKO MUD BROTHERS
07 Grizz 700 GREEN (BOUT TO BE WHITE!)
28"x12" Mudzillas
12" ITP SS112
2" lift
1 LOOSE NUT BEHIND THE WHEEL!!
SOON TO COME:
Snorkel
Relocated Radiator
Custom Paint
Custom Audiopipe
HMF and optimizer
07 Honda Rubicon (BIGGEST DISAPPOINTMENT)
27" Mud Bugs
12" Type 7 ITP
1993 Fourtrax 4x4
BROKE DOWN
BEST **** BIKE I EVER OWNED
(in reply to LAswamprat)
Post #: 153
RE: custom stereos - 4/28/2008 6:27:22 PM
Rebel64
Yup, here's a couple shots:
07 800 Stealth
(in reply to TREYGRIZ)
Post #: 154
RE: custom stereos - 4/29/2008 6:16:41 PM
BAMFBF
You guys that run two (or even three batterys) are you hooking them up to the charging system, or do you just trickle charge em when you're not ridin? Then drain em when you ride? If so wondering how long that's lasting for ya? I was thining about getting a deep cell optima and puttin it in my rear trunk to power the sound system.
(in reply to Rebel64)
Post #: 155
RE: custom stereos - 4/29/2008 6:40:27 PM
Foulplay
ORIGINAL: BAMFBF
I run mine in parallel, so the charging system does charge them. However, I do keep a trickle charger on them when I'm not riding. It seems to be holding up fine.
'06 Popo 800 EFI on 29.5" Outlaws
'05 Popo 700 carb on 29.5" Outlaws
'07 Popo 500 H.O. EFI (hers) on 27" Outlaws
'78 Jeep CJ-7 w/304 V8
http://s125.photobucket.com/albums/p44/Foulplay_photo/
This Honda's gone...
http://video.yahoo.com/watch/341841/2183512
(in reply to BAMFBF)
Post #: 156
RE: custom stereos - 4/29/2008 6:42:51 PM
BAMFBF
Good deal, thanks for the info. I'll have to give that a shot... any things to watch out for when doin that? Your second and 3rd battery the same as the stock battery?
(in reply to Foulplay)
Post #: 157
RE: custom stereos - 4/29/2008 7:16:41 PM
Foulplay
ORIGINAL: BAMFBF
No, I'm running the stock battery along with two electric wheelchair batteries that are much larger than a stock ATV battery. Make sure that you hook your batteries up in parallel, not in series. By doing this you are basically increasing the size of your battery but you're not increasing the voltage. Run positive to positive and negative to negative. Otherwise you will have 24 volts with two batteries or 36 volts with 3 batteries and you will fry your electrical system.
Post #: 158
RE: custom stereos - 5/2/2008 10:26:05 PM
bf7527
500 Quad Runner, you have a pm
1994 Honda 300 Fourtrax 4x4
K&N Filter and Prefilter
Dynojet Jet Kit
Supertrapp ISD2
Snorkel
24(frt), 25(rr) Super Swamper Vampire
Warn Winch
Custom Audiopipe
Highlifter Lift Springs
Post #: 159
RE: custom stereos - 5/3/2008 2:46:18 PM
matprice
ORIGINAL: CrosbyAnGel
Here is my box!! It's almost done!! Thanks again Andy!!
It's going to match my bumpers.. Metallic Silver fiberglass
It will have 2-8" and 6-6.5" Speakers.. 4-200 watt amps!!!
Thumbnail Image
i am not being a jerk but thats 800 watts the amp draw on that is going to upwards of 60 amps how are you going to keep your battery alive? i just saying that cause i have been in mobile audio for many years and there are many autos with muh larger and better charging systems tha would have trouble keeping up with a "TRUE" 800 watts even peak not rms, most of the inexpensive brands of audio equipment are wayyyyyyyyyyyyyyyyyyyyyyyyyy over rated for example a 200 watt jenson amp may only put out 12 true watts .... if it says 500 watt output and omes with a 20 amp fuse... well you do the math the flip side of that is high quality audio is often underrated or rated at some realy high ohm load but stable down to .5 ohms the old bulletproff autotek amps are monsters and rated @ 44wats rms @ 16 ohms run it down to .5 ohms and they are putting out an easy 400 of real power... reason its always nie ot run a 400 watt amp in the 100 watt and under class at IASCA comps
< Message edited by matprice -- 5/3/2008 2:57:40 PM >
Mat Price
BitMore Performance Race Team
mine BITMORE TUNED
2007 Can Am 800 Outlander
2007 outlander 800 xt
(in reply to CrosbyAnGel)
Post #: 160
RE: custom stereos - 5/4/2008 9:59:51 PM
arbus83
any of you all want to build me a custom stereo with some flashing strobes and  speakers and i pod hookup for the front of 07 rancher..? toggle switch activated!!
(in reply to matprice)
Post #: 161
RE: custom stereos - 5/5/2008 4:35:13 PM
TJ10EC
Always looking to upgrade I just finished this over the weekend. It sounds awesome. Loads of bass and clear as a bell. 600 watt amp, 2 Kicker 6x9s, it's own power supply, and a lift out tray for my 10/22, in a custom powder coated aluminum storage box.
< Message edited by TJ10EC -- 5/5/2008 7:12:38 PM >
05 Grizzly Blue
27" ITP mud-lite XTR's on 14" c-series type-7 wheels
2" lift kit, HL Lift springs
Warn XT30
Warn front bumper (Rhinolined) with trail lights
Monster Powersports Snorkel Kit
Noss Flange with Uni filter & Exhaust power tip
600 watt sound system up front
CSRAMudders.com
If you can still see the seat...
Then the hole ain't too deep!!!
TEAM STINKY HOLE MUDDERS!
AVERA, GA.
http://community.webshots.com/user/tj10ec
(in reply to arbus83)
Post #: 162
RE: custom stereos - 5/5/2008 6:46:11 PM
Cracksrubi
ok  I have a pioneer avnic-1 flip out deck lying around and want to build a fiberglass box but what are yall doing about keeping the water out cause this radio was expensive and i dont want to ruin it but the way i ride i stay mostley in water and if some says its to deep I usally find out if theyre right or not
(in reply to TJ10EC)
Post #: 163
RE: custom stereos - 5/6/2008 1:55:39 PM
TREYGRIZ
DAMM!T boy!!! that is one NICE box. Does are those kickers waterproff?
28"x12" Mudzillas
12" ITP SS112
2" lift
SOON TO COME:
Snorkel
Relocated Radiator
Custom Paint
Custom Audiopipe
HMF and optimizer
27" Mud Bugs
12" Type 7 ITP
1993 Fourtrax 4x4
BROKE DOWN
(in reply to Cracksrubi)
Post #: 164
RE: custom stereos - 5/6/2008 3:47:34 PM
sscard
ORIGINAL: TJ10EC
sweet I like that good job
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
Pink Dipped Plastics
Post #: 165
RE: custom stereos - 5/6/2008 7:40:29 PM
TJ10EC
Thanks for the comments. They are Kicker Marine speakers and they are supposed to be waterproof. I'll find out on the 17th.
05 Grizzly Blue
Warn XT30
CSRAMudders.com
AVERA, GA.
(in reply to sscard)
Post #: 166
RE: custom stereos - 5/6/2008 8:06:42 PM
mazdaboy873
Can anyone point me in the right direction?  I'm really familiar with audio stuff...
On my 2007 Brute 750, I want to mount 2 6x9's or something of that nature, in the plastic pieces on the front fenderes.  I want to be able to control it from an mp3 player/ipod & I want to be able to control the volume with a knob. Not sure if I need an amp or not.  Can someone help me out!!!!!  Thanks in advance!
Brenton
2007 Brute Force 750-black
2" HL lift / 2" temp gauge / relocated radiator / snorks / 29.5's
*Coming soon, SS212's, and other goodies.
Sold the Ranger, now driving a '97 Mustang GT with a few goodies. muahahaha
ORIGINAL: Polaris425
who knows. but you dont need it.
(in reply to gsbuick65)
Post #: 167
RE: custom stereos - 5/7/2008 8:57:24 PM
TREYGRIZ
You will need one unless u got one bad A$$ mp3.
28"x12" Mudzillas
12" ITP SS112
2" lift
SOON TO COME:
Snorkel
Relocated Radiator
Custom Paint
Custom Audiopipe
HMF and optimizer
27" Mud Bugs
12" Type 7 ITP
1993 Fourtrax 4x4
BROKE DOWN
(in reply to mazdaboy873)
Post #: 168
RE: custom stereos - 5/10/2008 1:23:44 AM
Guest
hey man you've got one of the nicest polarises ive ever seen in my life.. one question.. why do u have the relocated rad.. what does it do??
  Post #: 169
RE: custom stereos - 5/10/2008 10:15:03 AM
Rinny650
I guess you are talking about Rebel64? When you relocate your radiator it keeps it from getting full of mud and junk when you ride whcih lets the bike run cooler.
Team C.I.C.
2004 F-150
1984 Ranger 5.0
302ci bored .60 over with 12:1 comp
T4 Tranny
Ford 9" Rearend w/ Detroit Locker
5.71 gears
6" superlift
33x12.50x15 TSL's
15x10 Weld Racing
Headache Rack
2 KC Hi-Lights
102" whip
Galaxy 33
Texas Star 500
Custom SS diamond plate dog box
Pioneer Headunit
(in reply to Guest)
Post #: 170
RE: custom stereos - 5/12/2008 1:43:16 PM
silverfox
Heres mine but not finished yet.
Thumbnail Image
Attachment (1)
< Message edited by silverfox -- 5/12/2008 1:45:52 PM >
06 Sportsman 800 LE
2" lift
29.5 " Outlaws
Rattle Snake Rims
Custom Cooler Rack
with tunes
K&N Air Filter
(in reply to Rinny650)
Post #: 171
RE: custom stereos - 5/13/2008 2:29:12 PM
bjl777
heres one of mine
(in reply to waterboy_700)
Post #: 172
RE: custom stereos - 8/12/2008 10:17:31 AM
RUZY
6 MEMPHIS 6X9'S CMD4 CD PLAYER AND SNORKELS N THE BOX 500 WATT 4 CHANNEL AMP
TRIANGLE ATV
RIDE-N-DIRTY ATV CLUB
07 700 GRIZZ
29.5 12'S ALL 4
BLINKY BLINKY LIGHTS
WET BAR
STEREO 6 - MEMPHIS 6X9'S
http://www.myspace.com/rudypoo16
(in reply to bjl777)
Post #: 173
RE: custom stereos - 8/12/2008 10:40:06 AM
MuddinMaynard
RUZY that looks nice! Ya running a second battery to power all that?
Founder of www.MudMobsters.com
www.myspace.com/mudmobsters
Previous Rides: 2008 Outlander 800, 2006 Brute Force 750, Arctic Cat 500, TRX450R
(in reply to RUZY)
Post #: 174
RE: custom stereos - 8/12/2008 10:46:17 AM
RUZY
not yet but i got a stinger on the way i run stereo, lights and fan off the same ole batt. i bring cables when i ride hahaha
TRIANGLE ATV
07 700 GRIZZ
29.5 12'S ALL 4
WET BAR
(in reply to MuddinMaynard)
Post #: 175
RE: custom stereos - 8/12/2008 2:23:22 PM
blue91wrangler
Ok, if I were to build a box with self contained batteries, let's say 2 wheelchair batteries since they have been mentioned, how long would they power a cd reciever and 2 6x9's?? Would they last through the day and just put a trickle charger on them at nite or a day or so before I plan on riding???
1999 Honda 300 4x4 Green - 25" Mudlites, alum rims, custombeverage holder, 2 drystorage(ammo boxes), customsnorkle, oxlitecvbootguards, warn424, winch.
1993 Honda 300 2x4 Red - Buckshot Mudders(rear), 100% straight stock
1992 Honda 300 4x4 Blue, Lawed, snorked, lifted, FO-4 pipe, jet kit
http://www.myspace.com/tacomakid01
(in reply to RUZY)
Post #: 176
RE: custom stereos - 8/12/2008 3:11:09 PM
outdrsmn82
ORIGINAL: TJ10EC
this is just what i wanna do but on a smaller scale though. would hinder my field of vision. but i like this idea. is it sealed or do you have a leak rim on it. how does it sound? is it u-bolted down?
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
VIPER 3000# W/AMSTEEL
55W HID LIGHTS
1 1/2" SPRING SPACERS
CUSTOM SNORKEL
CUSTOM POLK AUDIOPIPE
THE ONLY REASON YOU DONT OWN A CAT IS CUZ UR SCARED OF HEIGHTS. ITS OK I GET IT.
Hard Pack Arctic Cats
It all seems like hardpack on a ARCTIC CAT.
Post #: 177
RE: custom stereos - 8/14/2008 8:39:18 AM
BAYOU REGULATER
Heres one that we built for sscard
Thumbnail Image
Attachment (1)
TBR RACING #3
JTM Custom Atv's
Bayou Mud Racing
JTMCATV Foreman 500 bog bike 3'' lift 28 laws
JTMCATV Outty 800 bog bike 7" lift 29.5s laws
JTMCATV Brute Force 750 bog bike 6" lift
JTMCATV 660 Grizzly show bike 14" lift 29.5s
JTMCATV 660 Rhino one of a kind!
JTMCATV 660 Grizzly parting out PM me if interested!
"looking for a few project bikes PM me if interested"
!!!JTM Custom ATV's
(in reply to outdrsmn82)
Post #: 178
RE: custom stereos - 8/14/2008 10:10:47 AM
outdrsmn82
i need some tunes.
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
55W HID LIGHTS
CUSTOM SNORKEL
(in reply to BAYOU REGULATER)
Post #: 179
RE: custom stereos - 8/14/2008 12:13:46 PM
outdrsmn82
hey if i run a pyramid 240 amp off of a cig plug will that be sufficient? i am going to go with either 2 6x9s or 2- 6.5s. i think it would be enough.
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
55W HID LIGHTS
CUSTOM SNORKEL
Post #: 180
