LiveForMud
(continued) but the simple gear swap won't work. the black gear in the picture below, which is the low range driven gear (part# 2), is what turns the gear and shaft that's attached to the bevel gear. so we can't swap these because the high range gear set won't mesh with that larger gear. also in the picture below, notice something? the shift fork is engaging the low range driven gear (part# 2)... look at that shift cam and how it has the shift fork and dog gear situated during this time... the grooves in the collar (shift cam) are what move the shift fork to the left or right as the shift cam rotates (when you move the shift lever back and forth from L to R).// (see attached picture below to follow along, had to butcher it a little so it would upload) i can see some simple welding and a little milling on that shift cam pushing that shift fork/dog gear back onto the low reduction gears when you shift into reverse. just repeat the pattern for low range on the other side of the "high range part" of the shift cam and voila, you've just gained yourself low range reverse. the "shift fork groove" in the shift cam would have to be modified to look like a symmetrical Vee... if you catch my drift... with the shifter in "L", the fork rides in the shift cam groove and pushes the dog gear to the left, locking onto the low range reduction set. with the shifter in "H", the fork ride in the shift cam groove in the other direction and pushes the dog gear to the right, locking onto the high range reduction set. now to get low range reverse, the pattern on the shift cam has to go back the other way as you rotate it so that it engages the low range reduction gear set. making a Vee pattern. that shift cam (part #8 on the 06 subtrans shifting assembly diagram) isn't an expensive part, $35 at mr cycles. this is where it's going to take a guinea pig to buy this piece, modify it, and install it. i played the guinea pig on the tachometer and spent $70, and it worked out for me. now someone will have to give the "shift cam mod" a try. if (WHEN) it works, that's what it's going to be called. it involves some metal working, but this HAS to work. also, i believe one of the vendors who post on here HAS to be able to do this mod to the shift cam. if i had a lathe and a 400M i would try it, but i can't put myself in that position right now. Thumbnail Image
Attachment (1)
2005 RED AC 500M Remote mounted g.o.r.i.l.l.a. 3k lb winch PC680 battery iEquus 8068 3 3/8" tach Reloc'd radiator 26-in XTRs some other stuff !seals, !brakes, !traction, !BEVEL GEARS, !money, !sanity... Dad's ride- 06 Foreman S 4WD Bro's ride- 07 King Quad 450
