RE: john deere front diff parts work
All Forums >> [OEM Discussions] >> Polaris >> RE: john deere front diff parts work Page: <<   < prev  1 2 [3]
RE: john deere front diff parts work - 5/9/2008 8:52:57 PM
vanillagorilla
that is what i am afraid that i am gonna find in mne this weekend.  i got JD parts in today and gonna try to start tomorrow.  i can hear the front diff grind and pop like pieces of the cage breaking.
GO DEEP OR GO HOME
500 RANGER "HITECH REDNECK EDITION"
ARCTIC CAT 500M
http://creekbottomtrailrides.com/
mypics
DIRTY DICK'S SWAMP CATS
SOUTHERN WILDLIFE TAXIDERMY
http://seanknights.com/
(in reply to OffRoader31)
Post #: 61
RE: john deere front diff parts work - 5/10/2008 9:47:43 PM
OffRoader31
Took me less than an hour to take the bike down and the diff appart.  I just unbolted my whole front end and took the rad out for space...just had to take one wheel off so i could tap the spring pin out  of the prop shaft yoke.  Nevermind taking the struts and all of that off..! lol..
Parts will be in by tuesday...will let you know how that goes.
As far as lenght of the cage..if it looks like it can be an issue...ill just shave off a bit on the end that doesnt come in contact with the armature side.
Thumbnail Image
Attachment (1)
2003 Sportsman 700
Kenda Executioner 27's on Itp Ss108's
K&n Filter + Prefilter + Dynojet
Modded intake
HL Outlaw clutch kit
Front Lift Springs
Supertrapp Mudslinger(First on a 700 Popo*custom fit*)
(in reply to vanillagorilla)
Post #: 62
RE: john deere front diff parts work - 7/13/2008 10:15:25 AM
Waveslider330
That looks just like my front diff in my magnum 330. Can any one confirm this?
This is a great thread, alot of good info.
Is the out-put cover (left side of gearcase which has the coil in it) on the Deere the same as the sportsman?
I need a new out-put cover, and if the Deere is the same as the Sportsmans, they are prob. cheaper??
A stick or something got flung up I guess and ripped the harness right out of the side of the gearcase cover. Never did find the loom, or the stick or anything, all of a sudden its gone. And there wasn't any wire hanging out so i couldn't splice a new harness. Very puzzling how something got in there, and didn't do any other damage. Ripped it right out of the connector up under the handle bar too.
05 Polaris Magnum330 4x4
2in. HL Lift
27in. outlaws
Fully snorkeled
Waterproof marine stereo
1.5in wheel spacers
Post #: 63
RE: john deere front diff parts work - 8/29/2008 7:23:05 AM
Boogyman
Just put new rollers,cage and seals in mine and it works great and 1/2 the price.
2006 700 polaris sportsman
6" Go ril la lift
32x10 $ILVERBACK$
Highlifter Radiator
(in reply to Waveslider330)
Post #: 64
RE: john deere front diff parts work - 9/1/2008 7:18:46 PM
wisconsin rider
 Ive been reading any and all posts on this subject as I am experiencing the same symptoms and am ready to order the parts from my local JD dealer. My question is, how difficult is it to do the install. I noticed that some folks were having problems removing the axles from the housing . Are there any tricks for removing the half shafts? Does the radiator/ fan have to come out? Any other tips anyone can offer?
Gotta git'r done
(in reply to Boogyman)
Post #: 65
RE: john deere front diff parts work - 9/3/2008 10:10:31 PM
alwaysbroke
ORIGINAL: wisconsin rider
Gotta git'r done
Lokimak posted this in a thread:
Sounds like you have pitted rollers or a magnetized Armature plate, you can replace the A-plate with John Deer P/N MIA 10656 for $17 and the roller kit is John Deer P/N MIA 10666 for $24. The minor repair kit has all the seals and O-ring you need, P/N MIA 10654.
The factory spec for resistance is between 22.8 ohms to 25.2 ohms.
The way I get the diff out:
Remove tires, remove the brake caliper and hang it by a wire, remove axle nut, remove the hub/brake assembly, remove A-arm from ball joint stud, pull axle out of strut tower/hub, soak axle with penetrating oil (might want to do this prior to starting to get a head start), jerk axle out of diff, move to other side and repeat. unplug the fan wire under the front storage box and unbolt and remove fan from radiator, unplug diff wire from under the pod and tie a piece of wire to it, then tie the other end of the wire to the handle bars, pull the diff wire down ( carefully so it does not hang) and untie the piece of wire and leave it hanging, this way all you have to do is re-tie the diff wire to it and pull the wires up instead of fighting the wires and trying to snake it through there. Use a punch and knock out the prop shaft roll pin, soak prop shaft and diff input shaft with penetrating oil, now unbolt diff from frame. Use a pry bar or LARGE screw driver and pry between the end of the input shaft and the prop shaft u-joint to get the diff out. You will have to wiggle the diff and turn it some to get it to clear the radiator and the frame support.
To test the A-plate you will need to crack the diff and then plug the coil back into the wires under the pod, or supply 12 volts another way, and engage your AWD, be sure bike is in H or L gear, then try to turn your A-plate by hand. It should be very difficult to turn the A-plate by hand when the coil is energized. Now switch off your AWD and try turning the A-plate. It should turn freely with no feelings of reistance or snagging. If it does not turn easily then it is magnetized. All you NEED to replace is the A-plate if it is the culprit; however you may want to go ahead and due a full rebuild while you have it apart.
I would change my fluid first to see if that helps any if you have not already done that. Remeber it only takes 5oz of Demand Drive Fluid for non-ADC bikes and 5.2oz for ADC equipped bikes. Good Luck.
Here is the thread he posted that in:
http://www.highlifter.com/forum/Stays_in_AWD_mode_slightly_when_in_2X4/m_2894351/tm.htm
'05 Sportsman 500 H.O., 27" mud bugs, mobile jukebox, backrest, and a cooler!
My Wheeler
Ride Pics
My Vids
(in reply to wisconsin rider)
Post #: 66
0.797
