RE: Arctic Cat snorkel tips
All Forums >> [OEM Discussions] >> Arctic Cat >> RE: Arctic Cat snorkel tips Page: <<   < prev  5 6 7 [8] 9   next >   >>
RE: Arctic Cat snorkel tips - 4/11/2008 1:18:18 PM
redneck36049
pretty good idea but i just moved mine to the rack
2007 ARCTIC CAT 650 H1 - in rehab for a mud addiction
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
SOON TO COME: CANT SAY BUT IT WILL BE BAD
WANT A CAT CALL STEEL HORSES WISH I DID
MY PICS http://www.myspace.com/redneck36049
(in reply to drumz2129)
Post #: 211
RE: Arctic Cat snorkel tips - 4/11/2008 1:18:54 PM
drumz2129
here is the finished bike @ 11:00pm wensday night before heading to mud nationals.... it was a tough first run but everything held up great.
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Mud tires: 27" Highlifter Outlaw (27x9.5x12 front 27x12x12 rear) on ITP SS108 Black Rims
Trail tires: Stock 25" Carlisle Badlands on stock rims
LE front and rear bumpers
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Radiator Overflow Tank added and Snorkled
Differentials Snorkled
Post #: 212
RE: Arctic Cat snorkel tips - 4/11/2008 1:20:12 PM
drumz2129
that may be in the works for the future... but the guy i did it for wanted to keep the front rack open for now.
Thumbnail Image
Attachment (1)
< Message edited by drumz2129 -- 4/11/2008 1:22:32 PM >
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
(in reply to redneck36049)
Post #: 213
RE: Arctic Cat snorkel tips - 4/11/2008 1:21:53 PM
redneck36049
well if i would have seen your idea like 3 months ago i would have went that route. cause i wanted the rack room on the front
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
Post #: 214
RE: Arctic Cat snorkel tips - 4/11/2008 1:25:12 PM
drumz2129
i also had to change the rad hose up alittle to fit the 3 2" snorkels through.
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 215
RE: Arctic Cat snorkel tips - 4/11/2008 1:26:31 PM
drumz2129
here is another view
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 216
RE: Arctic Cat snorkel tips - 4/11/2008 1:30:32 PM
drumz2129
here is the belt exhaust routing.
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 217
RE: Arctic Cat snorkel tips - 4/11/2008 1:31:43 PM
drumz2129
belt exhaust going to the front
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 218
RE: Arctic Cat snorkel tips - 4/11/2008 1:32:58 PM
drumz2129
belt intake and exhuast going up behind the rad
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 219
RE: Arctic Cat snorkel tips - 4/11/2008 1:35:22 PM
drumz2129
this is what the 5 peices looked like after gluing. from left to right: belt exhaust - tube to front - belt exhust riser, belt intake, air box intake
Thumbnail Image
Attachment (1)
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
Post #: 220
RE: Arctic Cat snorkel tips - 4/11/2008 10:14:00 PM
I_PullHondasOut
Are all yall taking off the frong plastics to run your snorks???????
08' ThunderCat, HL lift springs, 3.6s, Lawed, Fully Snorked, Radiator up'd, HMF and soon to be MaD TUNED. Just waitin on more stuff to come out!!!
AND I'm still ridin with the BIG DOGS....on a BIG OLE PUSS!!!
www.BamaBoggers.com
BamaBoggers Extreme Bog Team
Powered by ARCTIC CAT
Argo Power and Equiptment
atv Direct
Y A S K Y
BIG MonkeyAxles
MaD MotorSports
Extreme Clean
Post #: 221
RE: Arctic Cat snorkel tips - 4/11/2008 10:22:09 PM
drumz2129
ORIGINAL: I_PullHondasOut
i pulled both the front and rear plastic off of the 700h1 since it was the first one i did just to check everything out and run everything the best route possible. it was possible to do it with them on, but it would have taken alot longer. i also pulled the fuel tank to take care of the belt exhaust since they moved it from the top of the belt housing to the lower rear. that was a pita.
travis
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
(in reply to I_PullHondasOut)
Post #: 222
RE: Arctic Cat snorkel tips - 4/12/2008 3:40:22 PM
I have never pulled off the plastic to run snorkels, dont take any longer IMOP and that way you know where you can run it with out the plastic hitting it.
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
Post #: 223
RE: Arctic Cat snorkel tips - 4/12/2008 5:43:16 PM
redneck36049
the only time i unbolted my plastics was when i pulled the stock snorkle box off.
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
(in reply to GWC)
Post #: 224
RE: Arctic Cat snorkel tips - 4/18/2008 1:56:13 PM
h town h1
ive done snorkels on three different bikes one being my 08 650 h1 and i took both front and rear plastics off because it was the first one i ever did if i had to do it again wouldn't take them off its so much easier to get them all lined up when your done if you leave them on cause i did my cousins suzuki and a honda and both i left the plastics on them so much easier when it comes to the end....drumz those where some fancy bends on that belt snorkel looks very clean fine was a little less bendy but that belt exhaust was definately the hardest one on the bike it was a pain in the @$$ what kinda rubber hose is that you are running off of the exhaust it looks real thin and easy to work i had to fabricate a connector out of a 2" to inch and a half reducer with tadpole tape that hooked up to the factory rubber grommet but i used a hose clamp and some silicone and it works perfect but i might change it for extra security if i can get a hold of that rubber hose you used it looks really plyable oh yeah and i bet you spent probably close to twenty bucks just on those brass 90's for radiator hose i bought a plastic one and it was like $6 rip off
Post #: 225
RE: Arctic Cat snorkel tips - 4/18/2008 2:49:59 PM
drumz2129
ORIGINAL: h town h1
thanks h-town,
the rubber hose was the factory boot on the rear exhaust that i cut in half and slid the 2" street 90 into. i tried several things but it just seemed to work the best. thse brass 90s were 5 bucks each at lowes. i figured that way i dont have to worry about them getting brittle and breaking later on.
Thumbnail Image
Attachment (1)
< Message edited by drumz2129 -- 4/18/2008 2:51:37 PM >
2006 Red 500 Manual
Stealth Snorkle
Fan Switch Mod
Dynojet Kit
Carb Slide Mod
(in reply to h town h1)
Post #: 226
RE: Arctic Cat snorkel tips - 4/18/2008 4:28:34 PM
I_PullHondasOut
Allright, so no instructions or pics for a tcat??   I would like to know if most people are relocating their oil cooler or leaving it in its stock locations.  Doesnt it need to be behind the fan??  What all do I need to extend?  Are yall leaving thoes vents on your diffs or replacing them with hose?  I dont trust them but have never had one.  Also, are yall leaving the gas vent like it is witht he check vent???  I dont know if I like thoes either, how do you route the gas vent up?  all the way under then up? lol  Sorry just want to make sure I do it RIGHT the first time.  I probably had 1000$ easy in snorkels in my kodi.  dont wantto do that here!!!  Thanks to all!!!
www.BamaBoggers.com
atv Direct
Y A S K Y
BIG MonkeyAxles
MaD MotorSports
Extreme Clean
Post #: 227
RE: Arctic Cat snorkel tips - 4/18/2008 4:31:20 PM
I have never had a isssue with the vents on the diffs or waht ever there called.
I would run the gas tank vent up to your snorkels its not one way like you would think it it..
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 228
RE: Arctic Cat snorkel tips - 4/19/2008 1:48:44 AM
redneck36049
i would put the oil coolier up top cause when i took mine off it was packed with mud cause i couldnt get to it  with a water hose to wash it good.
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
(in reply to GWC)
Post #: 229
RE: Arctic Cat snorkel tips - 4/19/2008 5:49:01 AM
WILD CHILD01
Hi all i have some ?s i have a Thundercat that i want to do this with as well do you leave the air cleaner in the stock location and the plastick box that is under the seat that has a black hose going to it...this is all new to me sorry if its a dumb ? i want to get all the info i can before i start this project...thanks.
2008 Thunderpuss
Post #: 230
RE: Arctic Cat snorkel tips - 4/22/2008 5:55:07 PM
I_PullHondasOut
Are there any pics of the new AC belt snork?? From what I can tell the old belt exhause came out of the top, well now there down in the back of the housing. like the yamahas... Any pics of how people have snorkeled them from the newer models? GWC. You take any pics when you did DMRs???
www.BamaBoggers.com
atv Direct
Y A S K Y
BIG MonkeyAxles
MaD MotorSports
Extreme Clean
(in reply to WILD CHILD01)
Post #: 231
RE: Arctic Cat snorkel tips - 4/22/2008 9:18:51 PM
My 08 650 has the rear exit snorkel, my pic or on pg 6 in this post. Its not hard just real tight..lol
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
Post #: 232
RE: Arctic Cat snorkel tips - 4/23/2008 5:19:44 PM
RED01AC500
I still ride Old School, and have just recently got into muddin.  I already snorkeled my exhaust, but need ideas on the air.  I have a 2001 AC 500 Manual.  Has anyone ever snorkeled a bike like this one.  I want to but need some ideas on getting started.  The air intake comes up right under the seat all the way to the gas tank.  There's not much room.
Thanks for the help/suggestions in advance.
David
(in reply to GWC)
Post #: 233
RE: Arctic Cat snorkel tips - 4/30/2008 1:24:49 AM
bonsecourfire
Hey Fellas I Need A material List for the Arctic Cat 700 Efi, I Can Build It With a Little Guidance Some One Please Help ! I cant afford 299 for submarine snorkels i have to spend cash on axles and i want to say i did it i know someone understands Thanks and
ARCTIC CAT 700
4'' Catvos Lift
Front and Rear Monkeys
29.5 Swamplites
Radiator Relocator
Swamp Series HMF
SS108's
2008 420 Rancher 2wd (MY SPARE)
MODS SOON
(in reply to RED01AC500)
Post #: 234
RE: Arctic Cat snorkel tips - 4/30/2008 3:38:53 PM
I_PullHondasOut
ORIGINAL: WILD CHILD01
http://www.bamaboggers.com/forums/showthread.php?t=2819
www.BamaBoggers.com
atv Direct
Y A S K Y
BIG MonkeyAxles
MaD MotorSports
Extreme Clean
Post #: 235
RE: Arctic Cat snorkel tips - 5/2/2008 10:17:54 AM
I_PullHondasOut
Materials for SNORKEL AND WATERPROOFING:
12 ft. sch 40 PVC 2"
one small piece of 3" pvc
one reducer 3" to 2"
A BUNCH OF STREET 90s, 45s, and 60s
A BUNCH OF regular 90s, 45s, and 60s
PVC Primer and GLUE.
Plumbers GOOP
Magic Seal TAPE
RTV SILICONE
Tranny INTAKE:
Remove stock snorkel. leave the first rubber fitting on the tranny.
Slide 3" into stock cuppler. Then reduce it to 2"
Manuver with the bends up to where you want.
TRANNY EXHAUST:
Loosen the stock snork. Place a piece of straight up to it and see where you want to cut. I cut probably 3 inches off my stock snork. Insert the straight, clamp it and start runnin up to the front. I started here
AND FINISHED LIKE THIS
AIR BOX:
SIMPLE!!!!!! 2 street 45s and a straight!
REMEMBER WITH Your RADIATOR UP, you have 7 1/2 inches to work with inbetween the oil cooler lines! AND thats all the room you have comming up threw the hood. Take your time and get it how you like!!
If you have any questions feel free to ask, also I've got a ton more pics here. Just hit next.
http://s257.photobucket.com/albums/h...t=IMG_5767.jpg
WATPROFFING YOUR TCAT
Di Electric grease ALL YOUR PLUGS!!!!! and fuses.
The Airbox has 2 drains. They can be eaisly pluged with the 5/8s piece
then use plumbers GOOP and seal them in.
STATOR COVER. Take a flat head. and pry out the rubber stator cover
Silicone around the entire thing and replace it. ALSO, TAPE IT. lol I used some nascar heat tape. Just put an X over it to make sure it doesnt come out.
Crank Breather.
THIS THING NEEDS SMALLER HOSES.
I pulled the little black airbox that has two hoses goin into it and one into the airbox. RTV SILICONE it real good and replace them. When I pulled my plastics, they were all disconnected. I hope the silicone works...
4x4 actualtor
THIS IS BAD TO LEAK. Pull it off and run a bead of RTV around it and put it back together!
__________________
BAMABOGGERS
OG EXTREME BOG TEAM
www.BamaBoggers.com
atv Direct
Y A S K Y
BIG MonkeyAxles
MaD MotorSports
Extreme Clean
Post #: 236
RE: Arctic Cat snorkel tips - 5/6/2008 7:12:15 PM
redneck36049
nice pics helps alot
LE BUMPERS
2.5 WARN WINCH
RAD. RELOCATED
SNORKLED
HMF
DYNOJET
CLUTCHED
4.0S
29.5 LAWS ON TORKS
6" MONKEY LIFT
AUDIO PIPE
Post #: 237
RE: Arctic Cat snorkel tips - 7/15/2008 12:45:14 PM
outdrsmn82
i have looked all thru here for pics or info on how to snorkle an 06 400m but nothing. can anyone help. i think its easy, but have never done it and i want to get the right info onit. is it the same as the 500m? if so then this is going to be an easy fix. looking forward to all the info thanks guys.
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
VIPER 3000# W/AMSTEEL
55W HID LIGHTS
1 1/2" SPRING SPACERS
CUSTOM SNORKEL
CUSTOM POLK AUDIOPIPE
THE ONLY REASON YOU DONT OWN A CAT IS CUZ UR SCARED OF HEIGHTS. ITS OK I GET IT.
It all seems like hardpack on a ARCTIC CAT.
Post #: 238
