RE: Arctic Cat snorkel tips
All Forums >> [OEM Discussions] >> Arctic Cat >> RE: Arctic Cat snorkel tips Page: <<   < prev  2 3 [4] 5 6   next >   >>
RE: Arctic Cat snorkel tips - 5/20/2007 8:17:37 PM
Mudded prairie
The set up GWC has is the same setup as Purp mt 450 has on his 03. And it works very well. It alldepends on how/whay you want.
Mark
HIS- 2007- Arctic cat H1 far from stk
HERS- 2008-500-auto,Arctic Cat Soon to be far from stk.
(in reply to GWC)
Post #: 91
RE: Arctic Cat snorkel tips - 5/21/2007 12:05:20 PM
maxrod82
Thanks guys.  That setup looks REALLY NICE too.  But I think I will just stick with keeping the airbox and running one pipe.
2006 Arctic Cat 500 manual, marsh green
27" Mud Bugs
ITP Black Type 4's
Warn XT25
Super Trapp Mud Slinger, Dyno Jet kit, 2" snorkel
Soon to come: HL lift springs, clutch kit, and 27" LAWS!!
(in reply to Mudded prairie)
Post #: 92
RE: Arctic Cat snorkel tips - 6/17/2007 7:19:28 PM
Guest
well i sure wish i had some u experts here today! when i was tryin to finish snorkeling my h1...
well i used the parts list but i guess im not good at this cuz it didnt work.
first i did the tranny top and it went well until the top where it a 90 and from there u run it as high as u want it,welll i must have messed it up cuz the 90 aims it forward so i used a 45 which worked well so i think it will work.
then i was doin the tranny bottom and i looked at the pic on the first page but where my 3-2 reducer comes off it wont go behind that bar between the bar and the front drive shaft,so went to the outside but if i turn sharp to the right the tire would catch it so im trying to find a better way to do it now.
well can anyone tell me how to get that rubber reducer to fit behind that bar?
i will post a pic of it and what im talking about in just a sec!
thanks for any help.
wide open or stopped
(in reply to GWC)
  Post #: 93
RE: Arctic Cat snorkel tips - 6/17/2007 7:21:48 PM
like this..??
Thumbnail Image
Attachment (1)
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to Guest)
Post #: 94
RE: Arctic Cat snorkel tips - 6/17/2007 7:25:06 PM
Guest
yeah i cant get the bottom tranny reducer behind that bar.
(in reply to GWC)
  Post #: 95
RE: Arctic Cat snorkel tips - 6/17/2007 7:30:13 PM
Guest
yeah i cant get it bigind this bar!!!!
how is it supposed to fit back there.?
im gonna go take pics of mine and show u were im at so someone could maybe help.
(in reply to Guest)
  Post #: 96
RE: Arctic Cat snorkel tips - 6/17/2007 7:30:26 PM
i used the stock one and stuck a 3" pipe in it then used the 3' to 2" reducer,it does hit the frame but sense its rubber it should be just fine and has been for a year...
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to Guest)
Post #: 97
RE: Arctic Cat snorkel tips - 6/17/2007 7:43:50 PM
Guest
im downloading some pics that i jut took,it will take alittle while though cuz i got dial up.lol
but i got one of the top tranny ,bottom tranny(where it wont work),where they go together goin to the top and where all three come together.
thanks for the help so far.
(in reply to GWC)
  Post #: 98
RE: Arctic Cat snorkel tips - 6/17/2007 8:04:32 PM
Guest
ok yellow is the bar i cant get it behind,blue is the stock boot and green is the 3=2 reducer.
i did what u said and connected the to by  using 3 in thin wall sewer drain,but havent figured out how to get it behind the bar.
and heres where all 3 are coming up at the moment,i no it will probably be different if i can get the tranny intake behind that bar.
(in reply to Guest)
  Post #: 99
RE: Arctic Cat snorkel tips - 6/17/2007 8:13:08 PM
you need to go behind the bar,i used a straight peice of pipe,got behind the bar then turned it. it was TIGHT but it did go..also if you put your 90*s to turn up at diffeent heights from one another it will give you more room to work with,the little lip on the pipes add up and make it to tight..
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to Guest)
Post #: 100
RE: Arctic Cat snorkel tips - 6/17/2007 8:24:14 PM
Guest
thanks for the help.
as soon as i get home tommorow ill try to make it work and let u no how it goes.
(in reply to GWC)
  Post #: 101
RE: Arctic Cat snorkel tips - 6/17/2007 9:19:35 PM
sasquatche
geuss i was luck mine fell into place    but at times i just kinda did my own thing     my intake is all the way left?   i dunno
the elusive creature
2007 ARCTIC CAT 650 H-1
it all seems like hard pack when you ride a cat
special thanks to:
JEFF AND STEEL HORSES
the best cat dealer period.
(in reply to Guest)
Post #: 102
RE: Arctic Cat snorkel tips - 6/17/2007 9:30:09 PM
mr_wright08
if i put a 3" engine intake snorkel on it....will it be too much air flow?
because if i put a 3" i would get one of those K&N knockoff filters from autozone and put on there
call me HOTDAWG
07 AC 500
BECAUSE GOING AROUND ISNT AN OPTION
28 Sliverbacks
radiator relocated
snorkeled
~more to come~
STOLEN at 07' NATIONALS
2007 Camo Big Bear 400i
27LAWS on Rattlesnakes
HMF~JetKit~UNI~Snork
2" lift made by Gumbo03...blah blah blah....etc.
2005 Rancher ES ~blown motor~
(in reply to sasquatche)
Post #: 103
RE: Arctic Cat snorkel tips - 6/17/2007 9:36:56 PM
sasquatche
its still a 2" hole in the air box shoulnt make a difference........   but why?   if you are talkin bout the end i dont see a problem.....   but why?     lol
special thanks to:
(in reply to mr_wright08)
Post #: 104
RE: Arctic Cat snorkel tips - 6/20/2007 12:44:00 PM
Guest
well guys i finished it,and it turned out pretty good.
id post pics but the phone i sent them from didny work so ill try to get them later,but i must say it aint bad for a 16 year old kid to do it by himself.
oh i cut that bar that goes across right in fromt o;f the pod,did any else have to do that?
  Post #: 105
RE: Arctic Cat snorkel tips - 6/20/2007 2:12:49 PM
sasquatche
alot of people do but i made it a point not to (just because) but all the other cats i ride w/ cut it........ its just a little more room
special thanks to:
(in reply to Guest)
Post #: 106
RE: Arctic Cat snorkel tips - 6/20/2007 7:23:02 PM
Guest
thats cool the worst thing about it is it left little metal peices melted into my plastic
oh well it works,well i wont find out till saturday when i go to 90,oh i wanted to ask if i do wheelies outta the water onto the beach and stuff will my laws hit the snorkel under there?
  Post #: 107
RE: Arctic Cat snorkel tips - 6/20/2007 7:29:31 PM
sasquatche
flood the belt w/ the hose and look for leaks........ cause if you check it now it wont be a bad day on the trail !!!!!!    trust me!!!
special thanks to:
(in reply to Guest)
Post #: 108
RE: Arctic Cat snorkel tips - 6/20/2007 7:36:57 PM
Guest
thanks
that sounds like a good idea.
would just water outta the water hose work or should it be sumthin different?
oh and have u had a problem with ur tires hittin ur snorkel?
  Post #: 109
RE: Arctic Cat snorkel tips - 6/20/2007 7:44:43 PM
sasquatche
put the inner fender well back on    and yes hose water works ive had all kinds of water in my belt housing.......... try not to spill alot of water makes it hard to distinguish spilt or leakin water.......    k
special thanks to:
(in reply to Guest)
Post #: 110
RE: Arctic Cat snorkel tips - 6/20/2007 7:48:15 PM
Guest
cool,man i liked not having my fender wells
  Post #: 111
RE: Arctic Cat snorkel tips - 6/20/2007 7:51:13 PM
sasquatche
well really keeps that nasty stuff off you motor   easier to clean  imo    you do what you want if it just rubs   itll be fine but if its a hit you might have problems ......
special thanks to:
(in reply to Guest)
Post #: 112
RE: Arctic Cat snorkel tips - 6/20/2007 8:34:35 PM
Guest
i just looked at the pics up there and realized that mine goes in side that bar and then back out on the other side and then up to the top so it might get hit by the tire and now that i think about it i dont think the fender well will go on it
  Post #: 113
RE: Arctic Cat snorkel tips - 6/25/2007 12:31:49 PM
Josh_i_Baddarcticcat
Ok I am doing my center snorkels on my 650 V2 and my thermostat housing is in the way from making them perfectly center in my bike do i move the thermostat housing or what??
MONEY WELL WASTED OFFROAD
The dealer to call STEEL HORSES
CATVOS The BEST there ever was and the BEST there ever will be!!!!
06 Brute Force 750
Lots of work to be done!!
06 Dodge Diesel
Juice w/attitude stackin a diablo
gauges
04 Dodge 4X4 Diesel
35's
Smarty
IF IT AINT SMOKIN....IT MUST BE BROKIN!!!!
(in reply to Guest)
Post #: 114
RE: Arctic Cat snorkel tips - 6/25/2007 5:27:32 PM
boggin650
needing some advice on snorkeling my h1...do yall completely take off the front rack and plastic to make it easier to get all the snorkels put together?
(in reply to Josh_i_Baddarcticcat)
Post #: 115
RE: Arctic Cat snorkel tips - 6/25/2007 5:44:39 PM
sasquatche
yes.  if you are coming in behind the radiator in the middle, i put tape on the rack where the opening is, so i didnt have to cut the plastic, and put just the rack back on as a guide. also you dont have to cut the bar on the rack, imo doesnt give any more room and looks much cleaner. I tried to do GWCs thing, couldn't make it work, so kinda did my own thing, looks good. so GWCs instuctions are more like guidlines cause everybodys different.   also i used flex pvc on my belt intake cause it was easy.    MAKE SURE YOU HAVE CLEARANCE ON EVERY THING! also zip ties are your friend ohh and glue lots-o-glue......    and since you are that far in it might as well relocate the radiator......also makes snorklin easier.....  really easy to do as well........        1 day casually w/ some beer drinkin........       just add weldin mosheen and some 1.5" angle.
special thanks to:
(in reply to boggin650)
Post #: 116
RE: Arctic Cat snorkel tips - 6/26/2007 11:00:37 AM
Guest
well i jsut resnorkeled my belt intake cuz my ty rod was hitin it...
but now it works perfect but i also couldnt get the directions too work
so i did my own thing and when i was talkin to my grandpa he thought about flex hose but i told him everyone couldnt find(atleast everyone i talked to,in 2' that is)and he went and looked in the barn and found a old water pump and the intake hose was 2' flex hose so i used it on my belt intake and im done and water proof finally!!!
  Post #: 117
RE: Arctic Cat snorkel tips - 6/29/2007 7:37:13 PM
BrokenKitty
ok ive ben thinking about this for sometime and i askd my dad if we can snorkel it and he said yes !! and i hate my belt slipping but it seems to happen more and more now and i lookd around for all the belt snorkels and noticed my front belt snorkel looks like it comes right up under my back of my rack on the right im guess ?? and i hate that the fact that my rear is right above my storage box  ( never noticed it  ) and im worrying on how do i snorkel that  and the air box seems fine i think i just dont know what to use to plug the bottom of it and the thing that makes me mad is on the lid of my air box is like flat piece of plastice sort of like a mini snorkel the goes up to the top of my seat and its like and 1.5" wide or a lil more ITS AN 03 arcticcat not a brand new ...can i have some help here can any1 answer my questions please thanks alot
PINNEN AINT EASY....
_07 650 h-1_
- 32 " Sbacks waiting to be mounted
- Tall snorkels
- Rad up top
- 26 " itps
- 2 " lift kit
- Highlifter springs
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Front and rear brush guards
- 3000 lb monkey winch
- Handle guards
- Camo seat cover
- Honda people please stop posting pic threads we've had enough ....
http://s218.photobucket.com/albums/cc75/Gwar918/32s/
(in reply to Guest)
Post #: 118
RE: Arctic Cat snorkel tips - 6/29/2007 9:05:56 PM
sasquatche
if i were yo id pull all that stock junk out and start over w/ pvc..... but id find GWC and ask him he is Mr. 500.....
special thanks to:
(in reply to BrokenKitty)
Post #: 119
RE: Arctic Cat snorkel tips - 6/30/2007 7:38:07 AM
BrokenKitty
yes sir i will
_07 650 h-1_
- Tall snorkels
- Rad up top
- 26 " itps
- 2 " lift kit
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Handle guards
- Camo seat cover
Post #: 120
1.188
