sawhead
ok...after 3 hours of just test riding today,i hit a lot of stuff and here's what it boils down to as of now... mud,mud,mud...bugs mud better than mst for sure overall...when hitting the really sticky stuff,i definitely had to stay on throttle to keep moving otherwise the mst would not clean out and ball up(in 2wd the fronts balled up very badly)...whereas the bugs i could just walk right thru it with no wheel spin and they clean themselves out...bottomless muck,the mst dropped to the bottom,i kept moving,but it was slow going and alot of work...not saying the mst will not make it thru,but no where near as easily as my bugs...in the muck that had a solid bottom when hard on the throttle,i do believe i could cut thru it alot faster with the mst than the bugs...basically if ya wanna make it thru a mudhole,it you'll need plenty of wheel spin to get thru it mst with 3.5 psi still rides stiffer on the trails than my bugs with 4 psi...they have a very stiff tread face,i need to try 3 psi and see what happens the mst handling on trails/roads is far superior to bugs...felt like i was driving a porsche,anywhere i pointed the handle bars,that's where my quad went immediately...it took very little turning of the bars to make it change direction and as posted above,very,very easy to steer...the only thing i did not like about the handling is the mst had some shimmy when over 40 mph,it was not as bad as some tires i have tried,but still there climbing ability...on the trails,mst will walk all over the bugs(i wish the bugs would climb even nearly this well,they do not),but when walking out of a mudhole the bugs take the cake bugs/mst tire heights pretty much the same wet packed sand...my bugs wil pull a wheelie,mst will not loose dry sand...both dig in it,but the mst dig deeper when wide open throttle or not,they just dig in the sand...if already moving and steady throttle is applied i think they will out accelerate bugs,not sure just how it felt...i hate sand!!! creek riding with a sand bottom...very good here for some reason beings they are not impressive in any other sandy situation,i would say better than the bugs...much easier to steer the mst when on the throttle in the water...the only time they did worse than the bugs was climbing a sand based incline in a portion of the creek where the water moves a little bit faster,i was stuck almost immediately...my bugs make it thru this spot,feels like they are about to get stuck,but they always make it...a spot like this is just hard for any tire period though rocks...i do not have any rocky areas around here to try,sorry...i am sure the mst will be better due to lug pattern over taking logs...mst have this one in the bag if their wet...bugs hate climbing wet logs sidehilling...mst wins again,that should have been obvious though tread wear...i see no way that the bugs will wear better than the mst,no way!!! i am sure i missed something,so if need be ask me if i tried it,i'm tired and i got a 2 hour drive in a few hours,so i gotta hit the sack overall,i'd say bugs still overcome in the mud as far as ease of making it thru the hole...that's neither good nor bad,just the way it is...mst are a definite winner of a trail tire...they're light in weight,killer manners,and will still get ya thru the mudhole with a little finess...am i dissappointed,not at all,it's basically what i expected,except for how easy they steer and the awesome handling,these 2 items are far beyond what i expected them to be like!!!if you're a woods racer,these would be an excellent tire if you can get past the weight issue as most of you guys want a lighter tire i will give them some more time and see if anything changes bugs 60% mud/40% trail mst 40% mud/60% trail
Nebraska woods/mud/creek rider wide open & sideways every chance i get bf650...almond & almond springs/full pro circuit/26 terra xd on black torks/dyna/penlock p700...almond & almond springs/27 vamp,bi claw on 4x4s/dyna/full muzzy kymco mxu150...22 mudlites mst/other mud trail tire review
