lileigerthatcan!
well, your eiger has a keihin carb with a 122 main jet stock, if you ran your snorkel with 1.5 pipe then your probably running rich( less air/more fuel) so you might want o jet down. But if your gonna get an HMF your bike will breathe better so you'l have to jet up some to compensate, the HMF should come with three keihin jets: 130, 135, and 140. I'm running a 130 in mine right now and it runs great. You'll just have to mess with it till you get it where you like it. As far as changing jets, its real easy, just loosen the clamps on either side of the carb and rotate it till you can get a screwdriver to the four screws on the bowl and once yoyu get the bowl off the main jet is the one that sticks down the farthest. you can pop it off witha small adjustable wrench or flathead and then put your new one in and reassemble and tighten. For the needle you should run the second notch and you can get to it by removing the seat
07 Eiger 4x4 Manual 27" Vampires 2" Highlifter lift Warn front bumper and lights 2000Lb Warn Winch HMF Utility slip on Custom snorkel UNI filter Deathgrip grips
