homemade brake pads???
All Forums >> [Most Popular Discussions] >> Tech Questions >> homemade brake pads??? Page: [1] 2   next >   >>
homemade brake pads??? - 1/31/2005 8:57:17 PM
mattmanstroked
Hey does anyone know how to make some homemade brake pads?? What i mean is to use the old brake pads backing plate as the new backing plate for the new brake pad material.What i need to know is where to get brake pad material at. Do you use expoxy to bond pad material to backing plate or what??? ""
Thanks for the info. I am looking for a cheap way to keep my brakes from being so costly because of the mudridding I can not do without. ""
Re: homemade brake pads??? - 1/31/2005 9:13:20 PM
Herbiegrizz
I ordered my brake lining from McMaster carr and then used JB weld and a c clamp overnight
(in reply to mattmanstroked)
Re: homemade brake pads??? - 1/31/2005 10:08:20 PM
simple_honda
herbie has it goin on
what i used was clutch and brake lining, I think that would be the best stuff to use. go ahead and order like 3 feet of it. so you don't have to pay shipping more than you need to.
(in reply to Herbiegrizz)
Re: homemade brake pads??? - 1/31/2005 10:20:40 PM
thehickfarmer
makin ur own brake pads!!! that is just to redneck .lol good job bud. seriously. ever buck you save is just more gas money in ur pocket.
(in reply to simple_honda)
Re: homemade brake pads??? - 2/1/2005 7:13:09 AM
Herbiegrizz
Where else can you get brake pads for 75 cents per side.Heres the kicker-I ran stock set 600 miles and replaced with EBC heavy duty.they lasted less than 200 miles.Homemade have almost 400 miles on them and still going strong.I bought 5 feet so I have extra sets made up when i need them.Dollar saved can go towards another purchase
(in reply to thehickfarmer)
Re: homemade brake pads??? - 2/1/2005 10:35:03 AM
truegrit
How does the brake pad material cut? Do you use a cut-off wheel. Do you just trace the old pad area and cut it out?
This is pure genious.
Re: homemade brake pads??? - 2/1/2005 10:46:45 AM
zedex
I have drum brakes so my shoes last a LONG time. But if i had disks i would make my own as well. My only concern would be cutting them and dust. If they have asbestos in them which i bet they do, you will need the proper mask and ventilation . Asbestos dust will guaranteed kill you in the long run.
(in reply to truegrit)
Re: homemade brake pads??? - 2/1/2005 12:02:39 PM
Robb
Are you guys making the pads for the HL Disc Brakes? If so, what exact material are you using from McMaster, thickness etc? This is a great idea!! Also, how are you cutting this stuff?
(in reply to zedex)
Re: homemade brake pads??? - 2/1/2005 7:04:59 PM
Mudbum
Please include more info on the homemade McMaster replacement pads, ordering info - phone number, material & thickness, I am willing to try it.
(in reply to Robb)
Re: homemade brake pads??? - 2/3/2005 2:13:27 PM
Robb
anymore info here??
(in reply to Mudbum)
Re: homemade brake pads??? - 2/3/2005 3:47:50 PM
simple_honda
i used 1 1/4" wide, and 3/16 inch thick semi metallic brake lining.
it is easy to cut, the stuff you get is like a woven material type of stuff. you can cut it with some wire cutters in like 2 snips.
all you do is make sure there is no pad left remaining on the original plate. clean the surface really well. then cut and trim the lining to fit just perfectly. when you get it right, make up some JB weld, and slap that sucker on there. use a C-clamp to hold it in place. probably best to hold over night. when dry install brake pads on ATV
easy-breezy-lemon-squeezy!
(in reply to Robb)
Re: homemade brake pads??? - 2/3/2005 4:24:30 PM
Daniel Bruton
Would this work for the brake shoes in drum brakes, or only for discs? If it works for drums, I could afford to have rear brakes most of the time.
Re: homemade brake pads??? - 2/3/2005 9:45:53 PM
REBELRIDER
i dont understand why HL disc brake pads are so high!?
(in reply to Daniel Bruton)
Re: homemade brake pads??? - 2/18/2005 11:08:36 PM
OD_450S
thanks
for the info.
This place is great and with McMaster I get my stuff next day ground!!
(in reply to REBELRIDER)
Re: homemade brake pads??? - 2/19/2005 2:08:18 AM
Silveradols
I bought 3feet of brake material for $16 and I have enough for at least 3 complete sets of pads for my Grizzly. jb weld and let them sit overnight. they work as good as regular brake pads. they last longer than my factory ones did.
(in reply to OD_450S)
RE: Re: homemade brake pads??? - 7/23/2008 11:41:01 AM
justgiver
I know this is an old thread, but
I was looking at the different types of linings and is the semimetallic stuff good for high speed stops?
(in reply to Silveradols)
RE: Re: homemade brake pads??? - 7/23/2008 1:04:33 PM
gordo
I did a little run thru on making pads a while back,,,,
http://www.highlifter.com/forum/m_2628445/mpage_1/key_/tm.htm#2628445
And I use the woven brass,,,, works great,,, high speed or low speed stops. I use the 1" x 3/16" and cut it with snips.
2000 Honda Fourtrax
Warn 424/G o r i l l a XT 3000 Winch
HL Front Disk Brake Kit/Snorkeled
1997 Honda Fourtrax
Warn 424/Masterlock 1500 Winch
1996 Honda Fourtrax
HL Disk Brakes/Warn 424
G o r i l l a XT2500 Winch/Snorkeled
1990 Honda Fourtrax
Warn 424/Warn 2500 Winch
HL Disk Brakes
PM me for info on good cheap trailers!
(in reply to justgiver)
RE: Re: homemade brake pads??? - 7/23/2008 1:51:33 PM
kscowboy
I made 3 or 4 sets for my cat back a couple of years ago and used the 3/16's brass.  Its not worth the time and hastle!! They dont stop you as good as the factory pads (They do stop you just not as abrupt as the factory made ones) and they dont last longer than factory made ones.  Not worth it.
TEAM GANDER MOUNTAIN RACING
TEAM GET YOU SOME RIDING
TEAM ABS PARTYING
#44 REGAN
08 800 outlander max xt
BUILT FOR SPEED
TEAM GET YOU SOME (PRESIDENT)
CUSTOM LIFT BUILT BY CATVOS
www.myspace.com/kscowboy13
(in reply to gordo)
RE: Re: homemade brake pads??? - 7/23/2008 1:57:52 PM
gordo
ORIGINAL: kscowboy
Hmmmmmm,,,,,????? Not worth it? May be a hassle using solid brass,,, never tried that. Using the woven brass is a snap. Takes about 20 minutes to get everything together and into the vise to sit over night. And the cost factor actually makes it more than worth the effort,,,, compare about $50-$60 for a set of factory front pads to about $25 for after market front set to less than $3 for a homemade set of pads. The math speaks for itself,,,
And the ones I've been making seem to stop my bikes great,,,, don't understand the problem you had except maybe the solid brass,,, and like I said, I never tried the solid.
2000 Honda Fourtrax
1997 Honda Fourtrax
1996 Honda Fourtrax
1990 Honda Fourtrax
HL Disk Brakes
(in reply to kscowboy)
RE: Re: homemade brake pads??? - 7/23/2008 2:10:17 PM
I made the same solid brass pads and they dont last as long as EBC pads and dont stop you near as well.
what is this "woven brass" you talk of..??
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
(in reply to gordo)
RE: Re: homemade brake pads??? - 7/23/2008 2:13:41 PM
gordo
McMaster Carr has it on their site,,,,, under brake and clutch linings,,,, called semi-metallic woven strips,,,, works great.
2000 Honda Fourtrax
1997 Honda Fourtrax
1996 Honda Fourtrax
1990 Honda Fourtrax
HL Disk Brakes
(in reply to GWC)
RE: Re: homemade brake pads??? - 7/23/2008 2:17:45 PM
So is this really brake lining material.? what i was useing was just brass stock and it just dont work real well.
I read your post and it sonds like this stuff must be alot better then just brass.
guess i wil have to get some and try it out iam getting close to needing pads again.
TeAm GeT YoU SoMe
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
MY PIX
(in reply to gordo)
Post #: 22
RE: Re: homemade brake pads??? - 7/23/2008 2:23:22 PM
gordo
YEP,,,, actual brake and clutch material,,,, the clutch stuff is softer than the brake material,,, got some of it by accident and it don't work at all. But the 'green' woven brass is perfect,,,, get the 3/16 x 1" and get several feet of it. Bout $3.80/lf,,,, I got 6' and made a pile of them,,,,, the 1" wide is perfect to fit on the HL pad blanks,,,, see my other thread for specifics on assembly,,,, and just give a holler if you have any questions at all.
2000 Honda Fourtrax
1997 Honda Fourtrax
1996 Honda Fourtrax
1990 Honda Fourtrax
HL Disk Brakes
(in reply to GWC)
Post #: 23
RE: Re: homemade brake pads??? - 7/23/2008 2:32:49 PM
Thanks, it sounded like you built them just like i did the brass ones i made. there plenty easy to do for sure
TeAm GeT YoU SoMe
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
MY PIX
(in reply to gordo)
Post #: 24
RE: Re: homemade brake pads??? - 7/23/2008 3:09:41 PM
HESS
can i get a part number on which one to use?
07 Arctic Cat 650 H1 LE
Center Mounted Snorkels,28x9.5 Outlaws,LE Rims,Relocated Radiator,Speedwerx Pipe,Temp/Volt Gauges,Dalton Clutch Kit,DynoJet Kit,2" HL Lift,Slide Mod
(in reply to GWC)
Post #: 25
RE: Re: homemade brake pads??? - 7/23/2008 3:16:27 PM
gordo
6224K115 AND NO, IT DOES NOT CLICK BACK TO THE WEBPAGE,,, BUT THIS IS THE PART NUMBER,,,
$3.15/LF
2000 Honda Fourtrax
1997 Honda Fourtrax
1996 Honda Fourtrax
1990 Honda Fourtrax
HL Disk Brakes
(in reply to HESS)
Post #: 26
RE: Re: homemade brake pads??? - 7/23/2008 4:03:06 PM
Big_T
I don't believe any pads today are made with asbestos anymore.
There are three basic types of pad material:
organic.  This is made from an assortment of things like nut shells, cork, and other non-metallic materials.  They are very cheap and very quiet, but wear out quickly, especially in mud.  They are ok but will stop working if the brake gets too hot, for instance going down a big hill.
Sintered metallic:  This is pretty much entirely made from metallic materials, largely copper, brass, zinc, graphite, nickel, and whatever else they decide to put in.  These are a much better wearing brake pad, last longer, stop better, but are more expensive and noisier.  There are hundreds of different "types" of brake lining material which are different mixtures, all of which are proprietary.
Semi-metallic.  This type is made from a mix of both, and it gives you a mix of performance.  mediocre longevity, mediocre sound, mediocre brake stops, mediocre pricing.  This is what nearly all cars have, because of price.
For high speed stops, the best material is sintered metallic.  In fact, sintered metallic is the best pad material for nearly every aspect except for noise and price.  semi-metallic will give acceptable performance though.
Pure brass pads will usually wear longer, but are bad for the rotor and usually noisy.
Split audiopipe (self built)
Heelclicker
(in reply to gordo)
Post #: 27
RE: Re: homemade brake pads??? - 7/23/2008 9:39:51 PM
redneckrincon
make me a set lol i need them bad to dang cheap to buy em ha   they make a skin crawlin sound
BEER HELPING UGLY PEOPLE REPRODUCE SINCE 1886"
03 rincon
3"lift
27" outlaws on SS112's
Clipped carb spring
Custom snorkel
Superwinch 3000# with synthetic rope
More to come
http://www.mymudspace.com/redneckrincon
http://www.myspace.com/digman78
http://entertainment.webshots.com/album/563720900sIStWG
http://www.youtube.com/user/redneckrincon
RUN! Hes off his meds
(in reply to Big_T)
Post #: 28
RE: Re: homemade brake pads??? - 7/23/2008 10:06:45 PM
Texasmudslinger
looks like i have me some home made brake pads to make, will let you know how it turns out.....
08 Rhino 700
midnight armor edition
(SS212's with 27" mudlights)
4500# Viper Max winch and snorkeled
05 Rancher 350
lifted, lawed, HMFexhaust,
snorkeled
04 Kodiak
lifted, lawed,HMF exhaust,
relocated radiator,snorkeled
98 honda 300
(slightly modified)
(in reply to redneckrincon)
Post #: 29
RE: Re: homemade brake pads??? - 7/23/2008 10:16:34 PM
lonegunman
at my former employer we used to reline brake pads, brake shoes,brake bands, clutches,elevator brake shoes,you name it.we stocked woven lining and shoe and pad stock from organic on up to full metallic lining.
i just go back there and get my lining material and the bonding agent. get it all stuck together and clamp it with a c clamp and then bake it in an old oven. the bonding agent needs heat to be activated and fully cure.
lonegunman
TEAM TOXIC MOTORSPORTS
WWW.TEXARKANAMUDHOS.BLOGSPOT.COM
www.myspace.com/lonegunman0717
2001 arctic cat 300 4x4
lift kit
26" dirt devils
rokstar wheels
snorkeled
jetted
ion halogen driving lights
2500 warn winch
2007 a/c 650 H1-RED
LE wheels
front brush guard
LE rear bumper
28 mudlites
warn winch
H.P.A.C.
It all seems hardpack when you ride a cat
(in reply to Texasmudslinger)
Post #: 30
0.969
