high lifter temp gauge ?
All Forums >> [OEM Discussions] >> Yamaha >> high lifter temp gauge ? Page: [1]
high lifter temp gauge ? - 10/5/2008 10:34:33 PM
sscard
what have yall wired your light to on a grizz 660, just got my early b day present and im trying to wire it before this weekend coming up
figured it all out except for that, did yall wire it to ignition or to the headlights?
also where did you pick up ignition wire from?
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
Pink Dipped Plastics
RE: high lifter temp gauge ? - 10/6/2008 8:57:07 AM
sscard
ttt
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to sscard)
RE: high lifter temp gauge ? - 10/6/2008 1:48:21 PM
benitslu
headlights.
05 Red Grizz 660
blk SS 212's
28" Gators
Mudslinger tranny snorkels
Homemade 2" lift, rear hubs flipped
Temp Guage
RAM cupholder
2500 Warn winch
Rcvr hitch
milk crate on da back rack!
RE: high lifter temp gauge ? - 10/6/2008 2:27:50 PM
Swamp Star
i wish i had a answer for as many times as you have helped me and everybody else but im lost on this one
GOOD LUCK
02 Grizz 660
28" Mudzillas
ITP type 4 wheels
HL 2" front lift
Fliped Spindels rear
HL belt
HL Super Duty Outlaw clutch kit
FMF Powerline (want a HMF you got one?)
DynaJet jet kit
Pro Flow
K&N
Bayou Snorkels trans and air box
4 easily broken Monkey's
Radiator Relocated
Shes always down but never OUT
03 YZ250F
FMF Titanium 4 full
Triple clamps
Renthal bars
01 Dodge 3500 6x6
Cummins
6-speed
450 rwhp but still not enough
(in reply to benitslu)
RE: high lifter temp gauge ? - 10/6/2008 2:31:18 PM
Get a test light and find the wire coming out of your ignition wires that is Hot when your lightes are on or when your key is on either way does not matter.
I have mine hooked up so the lights come on with the key just like my gauge lights do..
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
HL springs, HL spacers
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to Swamp Star)
RE: high lifter temp gauge ? - 10/6/2008 2:37:29 PM
Mud lawdawg
I would wire it to the hot wire going to the head light switch. That way if something should short out, then its only the headlights you loose if the gauge shorts out.  If you do it to the ignition then we risk shorting that out and not being able to start the bike. anyways, I dont think you have a 4wheeler anymore. The last time I checked its sitting in MY garage. And since possession is 9/10's law, that makes it mine...LOL
2008 Grizzly 700FI Camo (mine for now, but will be my fiance's when I get a new one for me)
ITP SS212
Mud lite 27 inch X T R'S on 14 inch rims
2 inch HL lift
Custom snorkels
http://www.myspace.com/repoeman
RE: high lifter temp gauge ? - 10/6/2008 3:44:56 PM
Yeah wire it in right after the ingition, the wires are easy to find and tap into.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
(in reply to Mud lawdawg)
RE: high lifter temp gauge ? - 10/6/2008 6:17:55 PM
sscard
thanks guys, ill finish this one after this weekend, already dropped the bike off at stevens for this weekends trip
ill let you know how it turns out next week
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to GWC)
RE: high lifter temp gauge ? - 10/6/2008 9:27:25 PM
drew7693
wire it into the hot side of the 12v adapter. it is only hot when the key is on???... thats an idea and i'm sure easy to get to!
2008 yamaha Grizzly 700
ss108 wheels, aftermarket tires, 2.5 warn winch, DynaFS ignition, Tunes,.....more to come
06 500 FOREMAN S SOLD!,,,, I'll miss you!
K&n Air filter, with outerwear prefilter
HMF Utility
Jet Kit
High Lifter lift springs
EPI clutch kit
2.5 Warn
Tiangle Snorkel
27" LAWS
Turner Gear Reduction
2" lift
RE: high lifter temp gauge ? - 10/6/2008 9:43:14 PM
sscard
i dont want the light on all the time though, and didnt want to splice into the headlight wires,
I really wish there was a terminal that was easy to tap into instead
i might just add a switch, i hate tapping into the factory harnesses, I hated cutting off the factory plug for the triple flow fan
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to drew7693)
RE: high lifter temp gauge ? - 10/6/2008 10:18:54 PM
Mudder_N_Hell
The only thing about wiring into your headlights is when it is in the dim position, one wire is hot and when in the bright, the other is hot so just keep that in mind.   I have both of mine wired to to a keyed wire that is only hot when the key is on.  I have a JT temp  gauge on the 660 and an Autometer Cobalt full sweep on the 700.
04 Real Tree Hardwoods Grizz Headhunter Edition; Mods: All of them
08 SE Midnight Armor Grizz (New)
99 Wolverine 350
05 Raptor 80
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves.
" Ronald Reagan
http://community.webshots.com/user/toddlaird
RE: high lifter temp gauge ? - 10/6/2008 11:59:12 PM
sscard
ill check your 660 out this weekend
thanks mudder
what temp does your 660 run, and it has a 686 bbk right?
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to Mudder_N_Hell)
RE: high lifter temp gauge ? - 10/7/2008 12:27:26 AM
redGrizz
I wired mine into the key switch...had it for 6 months, not a problem yet. The gauge kit should come with all the wires you were askin about, to complete the install...
TEAM N2DEEP
07 Grizz 660
31x9.5 LAWS
HL xl2 wheels
HL Triple Flow Radiator
HL Temp Gauge
HL 2" lift
HL Lift Springs
Gor!la Axles
Bayou Snorkels
Lots On The Way!!
RE: high lifter temp gauge ? - 10/7/2008 1:09:47 AM
sscard
its got the wires just wondering on the light really, i can make it work, just wanting a clean install
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
(in reply to redGrizz)
RE: high lifter temp gauge ? - 10/7/2008 1:25:49 AM
redGrizz
put it behind the shifter...that would be a CLEAN install...I'm just scared to cut my plastic.  Hook the light to the key/ignition switch like stated above and the red backlight will come on when you turn the key And nothin when the keys off
TEAM N2DEEP
07 Grizz 660
31x9.5 LAWS
HL xl2 wheels
HL Temp Gauge
HL 2" lift
HL Lift Springs
Gor!la Axles
Bayou Snorkels
Lots On The Way!!
RE: high lifter temp gauge ? - 10/7/2008 7:39:45 AM
bcom
I hope i can help for as many times as youve helped me in the past.I wired mine to the headlight low beam wires.I did it this way because i didnt want the light in the guage on all the time.I remember a long time ago when i wired a tach up in my truck that i wired the light for the tach up just to an igniton hot wire.The bulb for the tach blew within a few months since it was on all the time.I didnt want this to happen to the guage for my quad.the light for the guage is only on when the low beams are on but heck thats what i use most of the time anyway.Check my video on the ceramic exhast.It has video of the guage in it.If you need any more specifics about this guage just let me know and i can run out and look to see how i did it in the past since its been a few years since i put it in.
By the way,i have an extra one of those radiator hose adapters for this guage laying on my work table.I never used mine since i have the Highlifter radiator with the adpater already in it for the guage.Cant remember if it comes with the guage or not.
< Message edited by bcom -- 10/7/2008 7:50:41 AM >
03' Yamaha Grizzly 660
Fixx Powersport clutch kit
Highlifter radiator/fan kit
26" Mud Lite XL
full ceramic exhaust
1" billet aluminum front wheel spacers
Dayco belt explodes in Grizz video
Grizz full ceramic exhaust temp video
RE: high lifter temp gauge ? - 10/7/2008 9:23:59 AM
sscard
ORIGINAL: redGrizz
Im thinking of fabbing a bracket to the loop on the rear of the front rack so it is directly above the pod and in between the belt snorkles
and im cutting in a 700 storage box there, just gotta find the hole saw to fit it
and thanks bcom, it still comes with it but i have a triple flow as well
ill shoot you a message when im actually starting the install for wire color and such, that sounds like what i want to do
04 Grizzly 660 camo
TRIPLE Flow
The Wifes
02 Rancher 350 4x4
