when i had one stuck bad i wraped a chain around the cv cup used a bolt to snug it down with and wraped the other end around a sledge hammer and used it like a slide hammer. works pretty good on most axles but if they are seized up it wont work nothing will. keep your diff fluid changed, best thing you can do. also when you do get them out put marine grease on the splines so they wont seize up again.
08 650H1 LE Warn 3.0 Snorkeled,Rad relocated Custom mounted gauges muffler tweaked Dynojet, slide mod, spring clipped Custom clutch kit, 4.0 gears HL springs, HL spacers "G" axles 29.5 Laws on custom LE wheels 30" MLs on Black Castle Roks 05 500m Dynojet,slide mod spring clipped muffler tweaked Hidden snorkel HL temp gauge 26" 589MTs on ITP type 6s Hard.Pack.Arctic.Cat
