got four wheel drive?
All Forums >> [OEM Discussions] >> Arctic Cat >> got four wheel drive? Page: [1]
got four wheel drive? - 7/24/2008 1:57:44 PM
exklueziv
cuz I DONT!!
I need an acuator.  anyone have a good one laying around?
Tony's got one, but he may want to keep it as a spare.
BTW tony where you get it?
I took my cover off--  so clean; no mud- but the plastic parts are cracked
also,  can I punch that pin through and run it in 4x4 until my new one comes in?  If so what is the trick to that without damaging anything?
'06 Arctic Cat Six-Fifty H1 LE
Front and Rear bumpers
SS 112s 14inch wheels on 27 mudlites
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
Rad remounted on top
And I have a TRV
RE: got four wheel drive? - 7/24/2008 2:01:00 PM
futuremudster
Texasdawg had one but he's never on anymore. might try getting a hold of him and double check.
STEEL HORSES SUPPORTER
08 650H1
CATVOS
APE Axle
Daughter- 2008 Prowler Power Wheel
----------Hard Pack Arctic Cats------------
Want a Cat?-- Call Steel Horses!!!!
(in reply to exklueziv)
RE: got four wheel drive? - 7/24/2008 2:01:43 PM
bustedknuckles
With the gears out of the actuator  it should be in 4x4. Just pull the gears out and put the cover back on.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: got four wheel drive? - 7/24/2008 2:07:08 PM
exklueziv
ah.  so if I take the old actuator comepletly off then I will be 4x4?  Its not like I am running with any cats since travis is touring the US with his trailor I've been riding at river run with a few hondas and havnt really needed the 4x4 to show em up. where do you get your parts? I need bearings and a starter and some ujoints.  Want em cheap.  OEM is so high on atv parts.
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
And I have a TRV
(in reply to bustedknuckles)
RE: got four wheel drive? - 7/24/2008 2:14:06 PM
bustedknuckles
If you take it completely off you will need to seal up the hole that the pin sticks out of to keep water and mud out. I pretty much buy everything from Steel Horses. Its just easier for me.
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: got four wheel drive? - 7/24/2008 2:25:36 PM
exklueziv
gotcha..  he's to da#n far for me to get bearings brake pads.  I need to order all my stuff today.  its all easy stuff on my bike.  the gohillas on the polaris are stuck in the diff though got it split apart and the ends soaking in diesel.  May have to get some new cups from G-unit (that's what I'm gonna call em from now on)
we got dry trails down here BTW.  you guys need to plan to come down in the fall after a good rain.
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
And I have a TRV
RE: got four wheel drive? - 7/24/2008 3:07:50 PM
Cat Bargins on ebay has had a few of them for prety fair prices.  but if you leave it on the diff you could just do like you said and pull/pull the pin to make sure its in 4wd and then ride it like that untill you can get a new one.
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
RE: got four wheel drive? - 7/24/2008 3:41:54 PM
bustedknuckles
He's too far for me. I just have him ship it. Normally I get within 1 or 2 days. BTW, Its been raining in crosby for 2 days. Bad thing is I'm probly gonna have to work this weekend.
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
(in reply to GWC)
RE: got four wheel drive? - 7/24/2008 7:20:11 PM
exklueziv
that blows a fat one!  hey GWC!  come down here and ride!  Tell the wife there are two mud nats this year
So you say if I pull the pin back it is in 4x4? or push it through
or like alan said and take the guts out
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
And I have a TRV
RE: got four wheel drive? - 7/25/2008 7:49:55 AM
BLACKCATT
ORIGINAL: exklueziv
cuz I DONT!!
If your board is good and you just need the plastic parts, I would try my dealer 1st. They will probably give you the plastic parts from an actuator that they swapped out. The whole actuator will cost about $185 with shipping, so I would try to beg for the free parts from the dealer 1st.
Just throwin' out another option to help save some dough!!!
2005 650 H1 LE
"Original H1 Kitty!"
29.5 x 12 Laws on type 5s
4.0s
2" lift
Rad & oil cooler up top
2" snorkles & sealed
Clutch...
Drilled rollers
Secondary spring mod
Secondary cage mod
3.6 mm shim on primary (super low!)
Carb drilled & clipped
Gutted stock pipe & 2" exhaust snorkel
No more 8" lift = No more burnt boots!
RE: got four wheel drive? - 7/25/2008 3:46:50 PM
exklueziv
yea that motor spins.  just the plastic piece that slaps that pin comes apart
I might try that.  To my surprise there is no water damage.  Its just a foul part
Clutch kit
Dyno Jet kit
Snorkeled
HMF pipe
HL springs
Gaxles with 2"lift
And I have a TRV
(in reply to BLACKCATT)
RE: got four wheel drive? - 7/25/2008 9:14:13 PM
BLACKCATT
ORIGINAL: exklueziv
Yea, I bet the dealer would hook you up for that piece. They won't work on them, they only swap out the whole actuator for new, so I bet they have some used ones laying around.
BTW, have you noticed the write up I did on the secondary cage mod. You have an 06', so I know you will benefit from it.
Here's the link...
http://www.highlifter.com/forum/Secondary_Cage_Mod_for_the_700_EFIs%2c_05-06_650_H1s_%26_500s/m_2783142/tm.htm
2005 650 H1 LE
4.0s
2" lift
Clutch...
Drilled rollers
Secondary cage mod
0.688
