gains from milling a head worth it
All Forums >> [Most Popular Discussions] >> Tech Questions >> gains from milling a head worth it Page: [1]
gains from milling a head worth it - 9/27/2008 9:49:37 AM
Landrew
 I have my head out on my 07 Rancher 420. I'm getting it bored as it got sunk and there is some piston/ring/cylinder wear. Since it was out I took the head over to the shop as well as the cylinder.  I was wondering if it is worth milling the head 10 to 20 thousands and increasing the compression? I know the timing will be retarded becasue of this.
Am I going to make gains with this or will the change in timing hold it back.
RE: gains from milling a head worth it - 9/28/2008 9:30:40 AM
kleinwild
Very large gains if done right!
TEAM BAD COMPANY
08 CATVOS Custom RZR
05 RPM/AMR Prairie
AMRacing ..... when being second is not an option, AMR is the only option
http://www.flickr.com/photos/21905386@N08/
(in reply to Landrew)
RE: gains from milling a head worth it - 9/29/2008 1:07:09 PM
Landrew
The shop doing it does a lot of the performance mods around here. What can I expect or what should I look for in doing it?
(in reply to kleinwild)
RE: gains from milling a head worth it - 9/29/2008 1:39:40 PM
engie
The rancher engine is still a pushrod engine, correct?
You can achieve virtually unlimited compression out of doing this to a pushrod engine because the valves open straight up and down, whereas they come in at an "angle" on overhead cam engines.  It has nothing at all to do with timing on your engine, since you don't have overhead cams and thus no timing chain.  You'd just have to adjust your valves to work with the pushrods which will now essentially be "longer" in comparison to head height.  Worst case scenario, the pushrods may need to be shortened...
Compression is essentially a linear gain.  If you have 10:1 compression and increase it to 12:1, and then match timing and fuel to it, you stand to gain 12/10, or 20% more power....
Currently building 4 race motors and awaiting the class breakdowns to start on the rest!!!
A second place trophy is only useful as a doorstop!
RE: gains from milling a head worth it - 9/29/2008 1:41:02 PM
VT_Grizzly
To do this correctly - you should measure you piston to valve clearance.  In order to do this, you need to put some putty (form an auto store made for this application) on your piston and re-install everything torqued properly.  Turn the motor over and check how thick the putty is where the valve comes down near the piston.  Then you know how much you can shave without hitting a valve on the top of your piston.  When I bored mine out, I had them take off 10-15 thousanths, just to gain a little and have a clean head surface.  I don't think 10-20 thousanths would pose an issue, and it should gain a little compression.
RE: gains from milling a head worth it - 9/29/2008 4:59:38 PM
Landrew
Thanks for the help. I'll go ahead and get it done.
Cant wait to see how it runs after a new HMF pipe, Optimizer, porting and milling the head along with a 25 thou bore job.
(in reply to VT_Grizzly)
RE: gains from milling a head worth it - 10/5/2008 11:57:31 PM
longdude17
i dont think the rancher 420 is a push rod engine.....
05 kodiak 450 4x4 Camo....currently puking smoke...Up for trade
26" ITP Mudlites
homemade snorkels
CnC Machined Muffler Power tip
K&N air filter
12 point deer horns on the front rack
Lookin for a good Mechanic to rebuild
92 blue kawasaki bayou 220 (the blue beast)
UNI filter
Super Swampers
12 point deer horns strapped to front rack
08 Honda Rancher-Lil Red
Stick Stoppers and Basket Racks
27" ITP Mudlites
soon to come: PCIII, HMF, Springs
RE: gains from milling a head worth it - 10/6/2008 8:10:35 AM
Landrew
It is. When I took it apart I was surprised to see pushrods on a vehicle from 2007. Sure makes it easy to do the cylinder as I dont have to worry about a timing chain etc. Though with the milled head the valves shoudl be re-adjusted.
(in reply to longdude17)
RE: gains from milling a head worth it - 10/6/2008 7:50:13 PM
toyazman76
Just a question. Why wouldn't you just go with a high compression piston?
2003 Grizzly 660, Snorkeled, Mudbuster cam, Wiseco piston, DIY split audio Tube, 27" laws, EPI clutch Kit, Relocated radiator, Temp-gauge, Custom cooler rack.
1992 Banshee-SOLD
RE: gains from milling a head worth it - 10/6/2008 11:01:53 PM
Landrew
They dont make one. At least after a day or searching the web. I suppose Wiseco could custom make one for hundred of $ or more but that is to much for the return on investment.
(in reply to toyazman76)
RE: gains from milling a head worth it - 10/7/2008 7:51:59 PM
longdude17
well ill be danged....it is a push rod engine....i just looked at a parts fitche and man that is surprising! talk about making it easier to rebuild!
< Message edited by longdude17 -- 10/7/2008 7:58:07 PM >
26" ITP Mudlites
homemade snorkels
K&N air filter
UNI filter
Super Swampers
27" ITP Mudlites
0.609
