ford f 150
ford f 150
All Forums >> [Off-Road Vehicles] >> Truck Discussions >> ford f 150 Page: [1]
ford f 150 - 10/9/2008 8:54:33 PM
lunchebox
i have an 2007 f150 4x4 and was wondering if anyone has one with a leveling kit and pics just wanna see how they look before i buy one thanks
PULLING OUT IS NOT AN OPTION!!!!!!!!!!
RE: ford f 150 - 10/9/2008 9:06:40 PM
muddmachine#1
mine is a 06 with a 2.5 leveling kit
FOR SALE
05 Yahmaha Rhino
29.5 outlaws
ss alloy 112 rims
2in highlifter lift
cdi module
07 Prowler XT Arctic Cat
27 ITP Mudlites
3000 Warn Winch
Snorkel Kit
FOR SALE
03 500i Arctic Cat
26 ITP mudlites
2500 Warn Winch
(in reply to lunchebox)
RE: ford f 150 - 10/9/2008 9:28:32 PM
lunchebox
that really does make em look alot better. for sure gonna have to get one do you know what brand it is that is on your truck
(in reply to muddmachine#1)
RE: ford f 150 - 10/9/2008 9:36:24 PM
muddmachine#1
it is a top cun customz lift bought it off ebay $89 bucks the website is www.topguncustomz.com  do u know how to measure how much lift u need in the front  u measure from the top of the back wheel to the top of the fender opening and do the same on the front and subtract  oh yeah dont try to put it on ur self u need a coil spring compressor
FOR SALE
05 Yahmaha Rhino
29.5 outlaws
ss alloy 112 rims
2in highlifter lift
cdi module
27 ITP Mudlites
3000 Warn Winch
Snorkel Kit
FOR SALE
03 500i Arctic Cat
26 ITP mudlites
2500 Warn Winch
RE: ford f 150 - 10/9/2008 9:38:44 PM
lunchebox
yeah i been looking at them on e bay and some say you need a compressor and some say you dont but if so i have access to one but just not sure what kind would be the best to go with
RE: ford f 150 - 10/9/2008 9:43:25 PM
muddmachine#1
well there is 2 types of leveling kits  yeah i wouldnt pay more than 100 bucks for one i have not had any problems with mine
FOR SALE
05 Yahmaha Rhino
29.5 outlaws
ss alloy 112 rims
2in highlifter lift
cdi module
27 ITP Mudlites
3000 Warn Winch
Snorkel Kit
FOR SALE
03 500i Arctic Cat
26 ITP mudlites
2500 Warn Winch
RE: ford f 150 - 10/9/2008 9:53:27 PM
lunchebox
cool thanks for the help
RE: ford f 150 - 10/9/2008 9:57:30 PM
muddmachine#1
ur welcome are u putting bigger tires on there after the leveling kit
FOR SALE
05 Yahmaha Rhino
29.5 outlaws
ss alloy 112 rims
2in highlifter lift
cdi module
27 ITP Mudlites
3000 Warn Winch
Snorkel Kit
FOR SALE
03 500i Arctic Cat
26 ITP mudlites
2500 Warn Winch
RE: ford f 150 - 10/9/2008 10:08:35 PM
lunchebox
well i just got it a few months ago it only had 4500 miles on it so not right now gonna wear the original tires out then i wanna do bigger probably do a six inch with some 35s
RE: ford f 150 - 10/10/2008 12:52:38 AM
Jimmy Vickers
With a 6" and a leveling kit, 37's will be a much better fit.  However, with 37's you'll want to do a gear swap as well, (I did with 35's).  I guess you could always remove the leveling kit before installing the 6".  The 6" will only raise the rear about 4" to compensate for the factory nose-down stance.  Without a taller block, block and add a leaf, or 6" springs, the leveling kit combined with a 6" kit will have your front end sitting much higher than the rear.
RE: ford f 150 - 10/13/2008 1:17:17 PM
ryanlt
04 f150 4x4 2.5'' leveling kit 33x12.50 mud grapplers on 18x10 rims.  i got my leveling kit from topguncustoms.
05 Brute 750
Lime green
29.5 laws
SuperGrip sra wheels
HL 2'' lift
HL relocated radiator kit
HL outlaw clutch kit
HMF
K&N
Rejetted
Snorkeled- twin air snorkels
Moose CDI
Custom tunes
(in reply to Jimmy Vickers)
RE: ford f 150 - 10/13/2008 2:40:28 PM
pur pony
here is my F150 leveled with stock tires (Leveling kit is an Original 2.5" AutoSprings spacer. They have since redesigned there spacer to eliminate the upper a-arm from hitting the coil spring.) I put 60,000 miles on this leveling kit without any issues. Its what most of the F-150 guys use and is pretty simple to install. It bolts on the top of your coil over so you do not need to compress the spring.
here is is leveled with 325x60x18 Nitto Terras (33x13.00x18) on a 18x9 wheel with 5" backspacing. (very minor trimming on the inside of my lower fender- 5 mins with a demel)
RE: ford f 150 - 10/13/2008 2:45:03 PM
pur pony
and here is my F-150 as it sits today with a 6" Fabtech (5" rear blocks w/ ProComp long AAL) and 35x12.5x20 Toyo M/T on 20x9 Wheels with a 5" backspace.
I attemped to stack a 2" Autosprings leveling kit ontop of the 6" and didnt like how it totally maxed out the suspension and I could not get anything to compress (although many people have done it).... My truck was sitting at 10" of lift! I ended up removing the spacer and staying at 6"s.....
I felt little to no affect in ride quality with the leveling... and it made a world of difference in looks!
(in reply to pur pony)
RE: ford f 150 - 10/13/2008 9:18:46 PM
lunchebox
thanks for the info! those are some good looking fords!!!!! ryanlt do your 33's rub very much with just a leveling kit?
RE: ford f 150 - 10/16/2008 1:26:28 PM
ryanlt
they rubbed a little when i first put them on because of the offset of the wheels. they stick out from under the truck a good bit. after a little bit of trimming they don't scrub.
05 Brute 750
Lime green
29.5 laws
HL 2'' lift
HMF
K&N
Rejetted
Moose CDI
Custom tunes
RE: ford f 150 - 10/16/2008 2:58:18 PM
bigbear400r4x4
33x12.50 on 17s with leveling kit
(in reply to ryanlt)
0.563
