electrical problems with prarie 360
All Forums >> [OEM Discussions] >> Kawasaki >> electrical problems with prarie 360 Page: [1]
electrical problems with prarie 360 - 7/24/2008 8:11:58 AM
BIG BEAR 08
there is a white wire that comes off of the positive battery connection and runs through a fuze and into the main harness. can anyone tell me where it goes from there? that wire has a short somewhere, which is causing the speedometer to do its own thing when i start it up, and i can start it with the push button because when i turn the key to on, the battery voltage goes down to zero. also, when its running, it sputters like when in reverse but not holding the override, but it does it at a higher rpm than in reverse and is erratic. also, i have the front actuator plug disconnected, ziplocked and ziptied because the front actuator is not on, and i also disconnected the two lights for the belt and 4wd. it happened right after my friend went into a pretty deep hole on a trail. so, can anyone tell me where that white wire goes or what could be causing this?
2008 big bear, 2500lb warn winch
2005 prarie 360, 26" mudlights, comet clutch, busted front diff, finally got it moving again on april 17th
1985 yamaha tri-moto 200, not mine anymore
Quote from J_Fred
"I don't get stuck, I just lose traction and stop moving".
RE: electrical problems with prarie 360 - 7/24/2008 12:16:51 PM
jakedogg
Sounds like limp mode to me.  BELT RESET INFO   Look into that and see what you come up with.
Brute Force 650 (SRA)
27" Laws
Fully Snorkeled
Relocated Radiator
Dyna CDI
2" Lift
Custom Skids
Water Temp Gauge
Big Gun Exhaust
(in reply to BIG BEAR 08)
RE: electrical problems with prarie 360 - 7/24/2008 4:27:10 PM
boogieandbride
I agree with Jakedogg!!!
2007 Brute 750
Moose Module
HL Lift Kit
28x10 S-backs
Tellurides
2006 Prairie
Lifted
Snorkle
Big Tires
Shiney wheels
Radio
Reverse lights
And Strobes!
http://myspace.com/txboogie
http://community.webshots.com/user/txboogie_30
http://www.myspace.com/texasmudjunkies
http://mudinmyblood.proboards102
(in reply to jakedogg)
RE: electrical problems with prarie 360 - 7/24/2008 4:40:30 PM
devildog12210
did you fix it yet?
07 Brute Force 750
29.5" Laws on 7series wheels
2" lift
MIMB center snorkals
rad relocate
split audio pipe
exhaust snorkal
Viper Max4000 w/ AmSteel cable
03 Ozark 250
06 ZX6R
04 R1
06 LTR450
(in reply to boogieandbride)
RE: electrical problems with prarie 360 - 7/25/2008 11:46:47 AM
BIG BEAR 08
found out what the problem was. when my dad got a new battery for it, it was the wrong one. we got a new battery yesterday and the problem is fixed.
Quote from J_Fred
(in reply to devildog12210)
RE: electrical problems with prarie 360 - 7/25/2008 12:00:38 PM
devildog12210
glad to hear you got it back running. Not sure how the wrong battery could have caused it unless it was a 6v or the amps were way off?!
07 Brute Force 750
2" lift
rad relocate
split audio pipe
exhaust snorkal
03 Ozark 250
06 ZX6R
04 R1
06 LTR450
RE: electrical problems with prarie 360 - 7/25/2008 12:10:22 PM
phreebsd
i dont see how either since the bike, when running, is powered from the charging system and the overage goes back to the battery.
2008 Kawasaki Brute Force 750
Outlaws - 27x9.5 F, 27x12 R
1" Spacers
HL 2" Lift
Lime Green Secondary
M.I.M.B Snorkles
Viper Max 4000 with Amsteel blue synthetic
2007 Kawasaki Prairie 360
Mudbugs - 26x10 F, 26x12 R
Twin Air filter
Viper 3000lb winch
MudInMyBlood Forum
0.250
