diff lock goes in and out......?
All Forums >> [OEM Discussions] >> Arctic Cat >> diff lock goes in and out......? Page: [1]
diff lock goes in and out......? - 7/25/2008 7:49:45 AM
outdrsmn82
i went riding and hit a deep hole and when i was trying to climb  out i locked the diff and it was a while b 4 it started spinning the tire. as long as i was on the throtle it was fine but when i let off it didnt engage when i hit the gas again. what could this be a need to change the diff fluid?
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
VIPER 3000# W/AMSTEEL
55W HID LIGHTS
1 1/2" SPRING SPACERS
CUSTOM SNORKEL
AUDIOPIPE IN WORKS
THE ONLY REASON YOU DONT OWN A CAT IS CUZ UR SCARED OF HEIGHTS. ITS OK I GET IT.
Hard Pack Arctic Cats
Cause everything is like hardpack on a CAT.
RE: diff lock goes in and out......? - 7/25/2008 7:54:27 AM
BLACKCATT
No, you might need to adjust your cable.
Sounds like it pulls it just enough to stay on the gear with power applied, then slips off when backing off power. Just make a small adjustment on the cable and you should be back in business!
2005 650 H1 LE
"Original H1 Kitty!"
29.5 x 12 Laws on type 5s
4.0s
2" lift
Rad & oil cooler up top
2" snorkles & sealed
Clutch...
Drilled rollers
Secondary spring mod
Secondary cage mod
3.6 mm shim on primary (super low!)
Carb drilled & clipped
Gutted stock pipe & 2" exhaust snorkel
No more 8" lift = No more burnt boots!
(in reply to outdrsmn82)
RE: diff lock goes in and out......? - 7/25/2008 12:59:34 PM
yeap.
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
(in reply to BLACKCATT)
RE: diff lock goes in and out......? - 7/25/2008 2:19:46 PM
outdrsmn82
thanks very much guys. i got a manual offline and was jus looking at how to do it.
06 AC 400M
BRUSH GUARD
FRONT BASKET
REAR SEAT
GUN RACK
LIQUID CADDY
VAMPS
55W HID LIGHTS
CUSTOM SNORKEL
AUDIOPIPE IN WORKS
(in reply to GWC)
RE: diff lock goes in and out......? - 7/25/2008 3:01:32 PM
bustedknuckles
You can adjust it at the lever or at the diff. I adjust at the diff.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: diff lock goes in and out......? - 7/25/2008 7:15:12 PM
1badkittykat
hmmmmm did not know u could adjust at the diff..... i adjusted mine at the cable i thought that was how
07 Kitty Kat 650 H1
Rigged Out'
http://www.myspace.com/itsajeepthing699
http://youtube.com/user/maddmatt469
Matt
'the orignal'
(in reply to bustedknuckles)
0.219
