clutch problems
clutch problems
All Forums >> [OEM Discussions] >> Arctic Cat >> clutch problems Page: [1]
clutch problems - 7/24/2008 1:40:33 AM
greenkitty650
was playin in a mud hole and got mud into the clutch so i cleaned it with soap and water. Now the problem is that it wont go into gear with killing the engine and when try to start in gear is inches forward.
RE: clutch problems - 7/24/2008 11:12:30 AM
greenkitty650
please help suppose to go up north this weekend thanks
(in reply to greenkitty650)
RE: clutch problems - 7/24/2008 11:43:20 AM
bustedknuckles
Sounds like there may still be some mud in there. Pull the belt cover and clean it real good. May have to pull the cvt's and clean them with brake cleaner or something.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: clutch problems - 7/24/2008 1:19:08 PM
it really sounds like your wet clutch springs are sticking and keeping the wet clutch engauged, but this would not have anything to do with your primary and secondary clutches.
only thihng i can say is take them apart and make sure there is no mud in anything
maybe the oneway bearing went out..??  maybe pm engie and see if he knows.
TeAm GeT YoU SoMe
Arctic Cat 08 650H1 LE
Arctic Cat 05 500m
To much to list
{MoKan, chapter}
"H.ard P.ack A.rctic C.ats"
It all seems HardPack when you ride a Cat.
MY PIX
(in reply to bustedknuckles)
RE: clutch problems - 7/24/2008 1:19:17 PM
greenkitty650
I took the cover off and cleaned primary and secondary but i will do it again tonight after work to make sure it clean since still have the cover off.
< Message edited by greenkitty650 -- 7/24/2008 1:33:35 PM >
0.172
