cat vs grizz
cat vs grizz
All Forums >> [OEM Discussions] >> Arctic Cat >> cat vs grizz Page: [1]
cat vs grizz - 9/30/2008 2:35:19 PM
660hunter09
how does the belt system hold up on the artic cats compared to the grizz 700s which is the better buy oh and the szuki king quads too
RE: cat vs grizz - 9/30/2008 3:25:01 PM
Dreggsta
what do you plan on doing w/it?
Team Southern Swamp Boyz
LIFTED, BACKED, STACKED & RACKED
'08 700 H1 SE
Nology Coil & Wire
LE Front & Rear Bumpers
Big OG Racks
Warn 3k Winch
Powermadd Hand Guards
Moose Hand Grips by O.D.I.
4.0 Gears
B & J Customs 2" Lift
ITP 14x8 SS 212's Machined Silver
Gorila Sliverbacks 30x11x14's On All Four Paw's
Rad Racked (MudTechInc)
Gorila Axles
Fully Snorked
Exhaust Mod & Snorked
Pre-Filter over intake snork
(in reply to 660hunter09)
RE: cat vs grizz - 9/30/2008 3:35:20 PM
BuLLg0d
They are both very good belt systems but I give the advantage to the cat. The grizz belt system uses greased rollers while the cat system uses dry rollers. This means if you get watter in a grizz belt case you have to take it apart and regrease the rollers. You dont have to do this with the cat because the roller dont use grease. The belt system is also tunable on the cat in stock form. The grizzley isnt tunable without buying a clutch kit.
08 ARCTIC CAT 700H-1
09 Thundercat TRV
TEAM STEEL HORSES
POWERED BY
ARCTIC CAT
Moto Sport Alloy
Ricks Racing Fuel
CATVOS
Big Monkey Axles
Speed Werx
08 c.m.r. mudfest 3rd place swamp x open class
08 springcreek mudbog series 2nd place open class
08 hlpsr mckinney 3rd place mudbog pro a class
08 c.m.r. mudstock 3rd place mudbog class 3
Fat is fast with a curve
(in reply to Dreggsta)
RE: cat vs grizz - 9/30/2008 4:01:58 PM
I do think the clutching on the 650/700H1s are more agressive then the Grizz 700s as well in stock forum, not to say the Grizz's belt system is lacking in anyway really.
I raced a Grizz 700 and he had 27 589s and i had my stock tires on, i beat him by 4 quad lenghts easy, i then got a deal on some 26"589s i blew them up to 27"s and went back and raced him again and with equal size tires he then beat me by 2 quad lenghts. so they do run good no doubt would like to see a 700H1 up agaisnt one as i think it would out run it.
If i bought a different brand of quad it would be the Grizz 700 i think. they are alot lighter then the cats are and skinny as well if you go ride both i think you will know which one you want. the weight does not bother me any but the fact they are so narrow is one thing i did not like but SRA wheels would fix that for sure..
they cats are just so easy to snorkel and to change things on, really like the way they look and how high they set and the low gearing they come with.
08 650H1 LE
Warn 3.0
Snorkeled,Rad relocated
Custom mounted gauges
muffler tweaked
Custom clutch kit, 4.0 gears
"G" axles
29.5 Laws on custom LE wheels
30" MLs on Black Castle Roks
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
26" 589MTs on ITP type 6s
Hard.Pack.Arctic.Cat
(in reply to BuLLg0d)
RE: cat vs grizz - 9/30/2008 4:15:50 PM
XLCat
Almost 6 of one and 1/2 dozen of the other.  I think the KQ guys have more ratio out there to grab by installing some shims in the primary.  There's not much to gain on the Grizz by doing that, but there is a little.  The ACs seem to be clutched more aggressive than the Grizz right off the bat.  The greased rollers in the Grizz give it a smoother shift out and longer belt life (dissipates heat better).  But it does pose a problem if you swamp it although both types need a cleanout after such.  I doubt you could quantitatively put a # on the increased belt life I mentioned.  The Grizz shares the same tranny as all the rest of Yamaha's utility lineup so you can buy a set of weights for around $30 for clutching options.
2007 700 GRIZZLY---Outlaw MSTs: 26x9.5, 26x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI air filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars, (8) 660 weights
1986 TRX200SX parts donor
1985 ATC70---detailed, open air filter, gutted exhaust, jetted, 200sx throttle housing & cable, stripped everything that doesn't make it go!
(in reply to GWC)
RE: cat vs grizz - 9/30/2008 4:34:57 PM
farmerboy700
If ur gonna play in mud and water They are both really good choices i would rule out the king quad just because i have seen that they are very Fragile!!
''TEAM DO WORK''
700 Grizzly Fi.
WID SOME EXTRAS!!
03 MONKEY LIFTED 660 GRIZZ
WID A FEW GOODIES!
(in reply to XLCat)
RE: cat vs grizz - 9/30/2008 6:41:35 PM
700CAMOGRIZZ
I think that they are both great bikes the grizz is just more modern with the efi. but the arctic cats are so freakin cheap i am thinkin about buying a used 650 to have for a second bike. but with that said they dont seem to hold their resale if you plan on buying a new bike. either way you cant go wrong both are good bikes, dont know much about the kingquad except they will outrun a stock 700 on flat ground but the grizz will smoke going up a hill dont know why that is probly something to do with clutching.
07 CAMO 700
30" $ILVERB@CK$
SS112 WHEELS
FPS CLUTCH KIT
2" EXTREME LIFT
TWIN AIR, SNORKED
HMF UTILITY & OPTIMIZER
http://s368.photobucket.com/albums/oo121/700camogrizz/700%20Grizz/
(in reply to farmerboy700)
RE: cat vs grizz - 9/30/2008 6:48:18 PM
farmerboy700
 Its called torque!!! I love the artic cat for mudboggin and water ridin just as much as the grizzly i just wish they made 4.o gears for the grizz it does good wid what is got but it would be a BEAST wid 4.0s
''TEAM DO WORK''
700 Grizzly Fi.
WID SOME EXTRAS!!
WID A FEW GOODIES!
(in reply to 700CAMOGRIZZ)
RE: cat vs grizz - 9/30/2008 6:48:54 PM
LiveForMud
just the belt drives themselves? pretty much a wash between the cat, king quad, and grizzlys.
considering the whole drivetrain? cat by a mile... the much lower gearing that the cat has takes a lot of stress off of the belt. from the experience of many: it's dang near impossible to slip a dry belt in a cat... it'll rip transmission parts out before that belt slips.
AC/Vinson 500A, AC650 H1
Primary (V-belt): 2.876 - 0.703
Secondary: 2.562 (41/16)
Final:  3.6 (36/10)
Range Reduction                     (Overall)
High:  1.200 (30/25)             (31.831 - 7.781)
Low:   2.500 (40/16)             (66.315 - 16.210)
Rev:   2.000 (28/16x32/28)    (53.052 - 12.968)
With 3.1s (700 H1)
High:  1.200 (30/25)              (27.410 - 6.700)
Low:   2.500 (40/16)             (57.104 - 13.958)
Rev:   2.000 (28/16x32/28)    (45.684 - 11.167)
With 4.0s (stock in Mud Pro)
High:  1.200 (30/25)             (35.368 - 8.646)
Low:   2.500 (40/16)             (73.683 - 18.011)
Rev:   2.000 (28/16x32/28)    (58.947 - 14.409)
King Quad 700/750
Primary (V-belt): 2.763 - 0.78
Secondary: 1.904 (40/21)
Final: 3.6 (36/10)
Range Reduction           [Overall]
High: 1.240 (31/25)    [23.484 - 6.630]
Low:  2.563 (41/16)    [48.540 - 13.703]
Rev:   1.882 (32/17)    [35.643 - 10.062]
Grizzly 660/700
Primary (V-belt):  2.380 - 0.700
Secondary reduction: 2.603 (41/21 x 24/18)
Final Drive: 3.67 (33/9)
Range Reductions (Overall)
High:  1.16   (26.349 - 7.750)
Low:   1.938  (44.021 - 12.947)
Rev:   2.000  (45.429 - 13.362)
cat's belt has a lot more leverage on the rest of the drivetrain, which is what you want for the most part. the taller the gearing after the belt, the harder the belt has to work to keep grip.
2005 RED AC 500M
Remote mounted g.o.r.i.l.l.a. 3k lb winch
PC680 battery
iEquus 8068 3 3/8" tach
Reloc'd radiator
26-in XTRs
some other stuff
!seals, !brakes, !traction, !BEVEL GEARS, !money, !sanity...
Dad's ride- 06 Foreman S 4WD
Bro's ride- 07 King Quad 450
RE: cat vs grizz - 9/30/2008 6:59:30 PM
farmerboy700
True dat man, but what do u think about the 700 grizz if it had 4.0s?
Sorry not tryin to steal a tread!
''TEAM DO WORK''
700 Grizzly Fi.
WID SOME EXTRAS!!
WID A FEW GOODIES!
(in reply to LiveForMud)
RE: cat vs grizz - 9/30/2008 9:20:35 PM
i think allmost all the Arctic cats have EFI now  glad i like what i got so i dont have to have it, i like as less computor and electronics as i can get away with.
cost me $50 for a Dyno jet kit to tune my quad after the pipe and snorkel and its easy to do. for me there is no reason to have EFI at all.
if i could get the parts cheap i would make my 4wd like the old ones with a push pull rod as well, and allthough the speedo looks cool a cable ran one would last much longer when in water all the time.
08 650H1 LE
Warn 3.0
muffler tweaked
"G" axles
05 500m
muffler tweaked
Hidden snorkel
HL temp gauge
RE: cat vs grizz - 9/30/2008 9:46:40 PM
BATTLE_CAT
^^Agreed...I've wanted to convert my 4wd switch to the old style for a while now.
Arctic Cat....nuff said.
http://www.myspace.com/team_lunatics_4x4
(in reply to GWC)
1.016
