j08BRUTEenFORCEr
ORIGINAL: Rinny650 I have pulled mine off numerous times while experimenting with weights and springs trying to get something to race with so mine comes off fairly easy that is not a good thing. the primary is a pressed tapered fit you should nerver be able to pull it off by hand. i would be afraid to ride you bike....... if that hing comes loose then someone is losing a leg
Of course I can........ ITS A BRUTE FORCE DANGIT!!!!! TEAM D SQUARED SPRING, TX 2008 Super Black brute force 750i FMOS Built Motor WARN 2.5xt winch center snorkled HID 10000k headlights custom audio-pipe speaker box HL 2inch lift 29.5's on ITP C type 7's and a cooler full of beer!!!!!!! THE LOANER 08 Kingquad 750 efi: yosh pipe, snorkled, outlawed
