Wheel Bearings
Wheel Bearings
All Forums >> [OEM Discussions] >> Arctic Cat >> Wheel Bearings Page: [1]
Wheel Bearings - 7/24/2008 8:18:04 AM
silverfox
Where's the best place to find these bearings 55mm X 30mm X 30mm
06 Sportsman 800 LE
2" lift
29.5 " Outlaws
Rattle Snake Rims
Custom Cooler Rack
with tunes
K&N Air Filter
TEAM STINKY HOLE MUDDERS
RE: Wheel Bearings - 7/24/2008 10:43:52 AM
silverfox
this is the arctic cat wheel bearing. Anyone no
06 Sportsman 800 LE
2" lift
29.5 " Outlaws
Rattle Snake Rims
Custom Cooler Rack
with tunes
K&N Air Filter
(in reply to silverfox)
RE: Wheel Bearings - 7/24/2008 10:47:37 AM
bustedknuckles
Ebay has them, Cat Bargains, or the dealer.
TEAM STEELHORSES Supporter
CATVOS
"APE" Axle
08 ThunderCat
08 650H1
RE: Wheel Bearings - 7/24/2008 12:47:17 PM
XLCat
Also, I just flipped thru the Timken catalog.  Looks like the 9106K is 30x55x13.  You might could stack 2 together with a spacer to make up the extra 4mm.  I'm sure it's no cheaper, but they may last longer.  Extra Light 9100K Series bearing for small housing diameters and relatively large shafts.  Static load rating is 1800lbs, but that stuff is extremely subjective and takes some serious engineering calculations to accurately predict the life of the bearing.
2007 700 GRIZZLY---Outlaw MSTs: 26x9.5, 26x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI air filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars, (8) 660 weights
1986 TRX200SX parts donor
1985 ATC70---detailed, open air filter, gutted exhaust, jetted, 200sx throttle housing & cable, stripped everything that doesn't make it go!
(in reply to bustedknuckles)
0.219
