Warn grease question?
All Forums >> [Most Popular Discussions] >> Tech Questions >> Warn grease question? Page: [1]
Warn grease question? - 9/4/2008 8:14:53 AM
knighthawk
I have had to take my Warn apart and clean out some "excess" mud that has made it inside the housing And I was just getting suggestions on what kind of grease to use inside of it.
Thanks
'07 Grizzly 700 Hunter EFI,EPS,2500lb Warn,Probox "Redneck rider",Strobes(front and rear),27" Swamplites on 14" ITP T7s
RE: Warn grease question? - 9/4/2008 8:26:35 AM
sportHO
Any grease is better than none.  I think some good high temp grease will be perfect.
2005 Camo Sportsman 500 HO
2009 Green RZR
(in reply to knighthawk)
RE: Warn grease question? - 9/4/2008 8:42:51 AM
mud_dog450
White Lithium from a tube, not the spray.
The Mud Brothers
Goin' Deep Since 2004!
02 Grizz
Everything Snorkeled
Clutch Work
29.5 Laws on Vision Buckshots
Muddin Videos
(in reply to sportHO)
RE: Warn grease question? - 9/4/2008 8:58:25 AM
jakedogg
I use Marine grease.
Brute Force 650 (SRA)
27" Laws
Fully Snorkeled
Relocated Radiator
Dyna CDI
2" Lift
Custom Skids
Water Temp Gauge
Big Gun Exhaust
(in reply to mud_dog450)
RE: Warn grease question? - 9/4/2008 10:05:09 AM
devildog12210
dido on the marine grease!
(in reply to jakedogg)
RE: Warn grease question? - 9/4/2008 11:53:39 AM
knighthawk
I think I will try the marine grade stuff.  Thanks yall
(in reply to devildog12210)
RE: Warn grease question? - 9/4/2008 2:05:31 PM
JeffinTD
The shear load on those gears is pretty extreme, and may require something that exceeds the typical chassis/wheelbearing stuff.
I think when I have to do mine, I'll actually spring for some of the Warn grease...
680 Rincon camo, warn XT30, Foreman headlight
500 Foreman FM, warn 2.5
Rides in PatioHauler 5th wheel, towed by Ram 3500
RE: Warn grease question? - 9/4/2008 5:15:34 PM
Jake450s
It really isn't that extreme of a load relatively speaking.  I wouldn't want to stick my finger between the gears while they were running, but EP addatives and ratings aren't required.  I used to be pretty fussy about what I'd put in.  White lithium (from a tube) would be the most "correct" I've seen mentioned so far, but plain old low temperature non EP marine trailer bearing grease (Valvoline in my case) seems to be staying well, and not holding dirt and shmutz as much as many others I've used.  Not that it doesn't hold stuff, it does, just not so much as many others with far better laboratory condition statistics.  I can't give you exact usage hours, but it stays as well as any, the gears don't dry up, and it prevents wear as well as anything, better than some.
.02
(in reply to JeffinTD)
RE: Warn grease question? - 9/4/2008 6:40:42 PM
Dezz
Totally agree with Jake450s. He is completely correct. You don't need an EP grease in there. There is not that much pressure being exerted on the gears.
Any good Low temperature grease should be just fine.
If you do not have it available to use, then like someone else already stated, any grease is better than no grease.
Dezz
1998 Grizzly 600
ITP Delta Black Chrome Rims
Uni Air Filter
Warn A2000 Winch
Detroit Gearless Locker
Oxlite CV joint protectors
(in reply to Jake450s)
RE: Warn grease question? - 9/7/2008 11:58:26 AM
05BlueGrizzly
i used marine grease grade also. now that i know how easily mud gets in i will be routinely cleaning from now on.
05 Grizzly, Blue, 25" MST's
AMSOIL 10w40
Purolator Pure One PL 14610 oil filter
AMSOIL 75/80W90 in Diffs
www.myspace.com/gbspitstop
(in reply to Dezz)
RE: Warn grease question? - 9/8/2008 9:17:35 PM
flfirepig911
Is it a pain to pull the winch, take it apart, and clean it?
Rest In Peace Okaloosa County Sheriff's Deputy Anthony "Tony" Forgione End Of Watch 07-22-08 You are my hero brother.
2007 Grizzly 700 EFI w/ Power Steering
Dalton Clutch Weights & Orange EPI Secondary Spring, Snorks, 29.5 Outlaws, Warn RT 2.5, Silverstar Headlights
President Southern Ridge ATV Club
TEAM SOUTHERN RIDGE- Doin It Deeper In The South
http://www.southernridgeatvtrails.com/
http://www.myspace.com/southernridge_atvclub
(in reply to 05BlueGrizzly)
RE: Warn grease question? - 9/8/2008 9:27:01 PM
mud_dog450
If you have an RT or XT winch, you shouldn't have to clean it as it is fully sealed.  With the older style A2000 or A2500 winches (I think the ci series as well), they are not sealed and be contaminated.
The Mud Brothers
02 Grizz
Clutch Work
Muddin Videos
(in reply to flfirepig911)
RE: Warn grease question? - 9/8/2008 9:47:56 PM
flfirepig911
Cool, mines the RT and has certainly earned its' keep!! LOL
0.500
