THE BASKET BALL TRICK
All Forums >> [OEM Discussions] >> Honda >> THE BASKET BALL TRICK Page: [1]
THE BASKET BALL TRICK - 8/21/2008 9:00:14 AM
foreman2000
DOSE ANYBODY HAVE ISSUES WITH THEIR 98 - 04 FOREMAN FLOATING THE FRONT TIRES OR (WATER WHELIE)
I HEARD YOU CAN PUT A BASKET BALL BEHIND THE FRONT BASH PLATE AND IT WILL ADD 13 POUNDS OF BUOYANCY
HAS ANYBODY DONE THIS OR SOMETHING SIMILAR?
2000 honda foreman es
custom snorkle
hl lift kit & springs
27 x 9 laws
hl clutch kit
ebc primary clutches
hmf pipe & uni filter
dynojet 126 and needle
hl spool locker
hl un locker
3000 lb warn
reverse button mod
AND ONE EVIL MONKEY!
*new* 2006 yamaha rhino
upgraded to lcd display
yamaha roof and windsheild
alum stick stops and skids
brp cdi
RE: THE BASKET BALL TRICK - 8/21/2008 10:36:28 AM
mac102004
I remember a few years back you would see that being done quite a bit. You don't see it so much now. It works, no doubt about it, and basketball's are cheap anyway. You'll need a basketball and a pump for it.
2005 Rincon 650 4x4
http://community.webshots.com/user/mac102004
(in reply to foreman2000)
RE: THE BASKET BALL TRICK - 8/21/2008 10:44:01 AM
RedRum410
I havent never tried it but im runnin 12 wide in the front and it tends to float up the front end real easy
07 Foreman 500
Rerouted Vent Lines
2"lift
26x12x12rear 26x9.5x12front TSL Swampers
27x12x12 all 4 Outlaws
sealed Pullrope Housing
(in reply to mac102004)
RE: THE BASKET BALL TRICK - 8/21/2008 12:40:02 PM
Gordon Fabrications
with good size tires you won't have any problems matter of fact mine floats a little too much so i would try it with out the ball before you put one in there.
04 foreman S
dyno jet kit
3 in G-fab lift
different exhaust every week
K&N filter
Snorkeled up
Warn rt 2500
29.5in laws
ITP SS212's
audio pipe
clutch kit
(in reply to RedRum410)
RE: THE BASKET BALL TRICK - 8/21/2008 3:15:36 PM
ARK_SWAMP_RIDER
Ive done it, works well.  You just have to be careful not to tip over, it is easy to do.  I just did it for fun, not sure what it would do if you were trying to compete.
2005 Honda Foreman 500 S 4x4 with 4 26x12x12 bear claws on itp c series type 6
93 Honda 300 4x4-Mostly stock
90 GMC-6" superlift, 315 buckshot mudders (sold)
96 Ford Mustang Mystic Cobra
My Pics
RE: THE BASKET BALL TRICK - 8/21/2008 6:13:43 PM
06HondaRubicon
Maybe you should ask this guy...
http://www.youtube.com/watch?v=LWQWwNyp0nI
2006 Honda Rubicon
-Custom Fiberglass Stereo System
1982 Honda ATC 200E "Big Red"
1995 Red Honda 300 4x4 ("The Tank")
-355 BBK, 459 Cam, HL clutch kit, Spool Locker, Vesrah valves and springs, D.I.D heavy duty timing chain, Thrush exhaust, Fully Snorkeled, K&N Filter, Dynojet kit, metal cage floorboards, Foreman 450 shocks on front and back, 2" lift and 1.5" Spacers on the rear, All rear offset ITP Black Delta Wheels, 28x12.5 Outlaws on all four corners
(in reply to ARK_SWAMP_RIDER)
RE: THE BASKET BALL TRICK - 8/29/2008 8:33:59 AM
foreman2000
I RUN 27 X 9.5 X 12'S WITH 10 PSI OF AIR IN THEM AND A WARN 3000 LB WINCH ON THE FRONT IT AND IT DONT LIKE FLOATING THE FRONT I MEAN HOW DEEP DO YOU REALLY HAVE TO BE
custom snorkle
27 x 9 laws
hl clutch kit
hl spool locker
hl un locker
3000 lb warn
reverse button mod
brp cdi
(in reply to 06HondaRubicon)
RE: THE BASKET BALL TRICK - 8/29/2008 6:25:10 PM
Green420
right up to the top of the tires on mine......and of course you gotta have to power to make it stand up.
07 425 RANCHER
29.5x10 LAWED
RE: THE BASKET BALL TRICK - 8/29/2008 7:44:33 PM
BrokenKitty
You dont have to have all the power in the world you just aint deep enough .....With my laws i can be half my tire and it can stand it on the back rack just sitting down .
PINNEN AINT EASY....
_07 650 h-1_
- Tall snorkels
- Rad up top
- Wide open on 26s for now
- 2 " lift kit
- Highlifter springs
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Front brush guard
- Rear brush guard
- 3000 lb monkey winch
- Handle guards
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=333810678
http://s218.photobucket.com/albums/cc75/Gwar918/pinnd/
(in reply to Green420)
RE: THE BASKET BALL TRICK - 8/29/2008 7:50:35 PM
machineman350
I can pull into a water hole about to the top of the tire and stop and just lean back and mine will start bobbing.
2003 Rancher
28 in. mudzillas
(in reply to BrokenKitty)
RE: THE BASKET BALL TRICK - 8/29/2008 8:01:43 PM
dcfox
My buddy has a basketball in the front of his Foreman.He swears it helps.
I have 28x12x12 Mud Lites on the front of my Rincon.It doesn't need any more help floating the front end.
--David
Add me on Myspace
(in reply to machineman350)
RE: THE BASKET BALL TRICK - 8/29/2008 8:17:37 PM
James Chapman
big laws float like crazy...i was running 29five 10's on my brute and i couldnt keep it down
Support our Military and their mission
00 Dakota 4wd ext cab 5.9
BFG A/T's
Cherry Bomb
She's fast . She's real fast.
(in reply to dcfox)
RE: THE BASKET BALL TRICK - 8/29/2008 8:41:07 PM
Gordon Fabrications
thats what i'm talking about i have 29.5x10's on my foreman and i fight with it in deep water to keep the front in down cause with giving it any gas it wants to stand straight up but i don't know they float with 27's.
04 foreman S
dyno jet kit
3 in G-fab lift
K&N filter
Snorkeled up
Warn rt 2500
29.5in laws
ITP SS212's
audio pipe
clutch kit
(in reply to James Chapman)
RE: THE BASKET BALL TRICK - 8/29/2008 8:52:25 PM
MUD STUD
i had a basket ball in the front of my rancher at one time and i could not keep the front down it helped me a lot if you think of how hard it is to sink a basket ball in a pool just think how much it will help the front float and allso my rubicon will not water wheelie unless i have a lot of air in the front tires and no air in the back tires if i have a lot of air in the back tires the back will try to float instead of the front and u cant make it bite to wheelie and plus it is a lot harder to keep stable with the back floating  imo
07 HONDA rubicon 4x4
HMF exhaust not quite core
dinojet jet kit
K&N air filter
OUTLAWS
27/9.5/12front
27/12/12rear
http://community.webshots.com/user/mhs09jdw2721
http://www.youtube.com/user/mhs09jdw2721
01 Honda Rancher 2wd with bbk and 25/ 13/ 10 vampire
honda 300 2x4 all stock with crappy tires
(in reply to Gordon Fabrications)
RE: THE BASKET BALL TRICK - 8/29/2008 9:12:58 PM
rebelhunter1
i've got 26-10"s on the front of mine and it floats up really well
Team "Do Work"
Mini General Lee
2003 honda 350 4x4
Hmf Utility
Itp type 5's wrapped with
26-10-12 outlaws
26-12-12 outlaws
2008 honda foreman 500 4x4
26-10-12 swamplites
26-12-12 swamplites
1998 chevy 1500 single cab
18" 2007 silverado rims
3" body lift
4:56 gears
shift kit
2 rockford fosgate 12"s in a sealed box
Memphis 800Watt amp
(in reply to MUD STUD)
RE: THE BASKET BALL TRICK - 8/29/2008 9:56:20 PM
03_VINSON
I've got a b-ball in the front of mine right now I think it works pretty good
03 vinson on 26 inch mudbugs
HMF
UNI Filter
Custom Snorks
(in reply to rebelhunter1)
RE: THE BASKET BALL TRICK - 8/30/2008 9:08:05 AM
JPs300
good ol' light weight 300 here - even with the winch it floats easily with just 25x/8/12's and 5.5 psi.
'96 TRX300
shock relocate + 1/2 spacers in front
snorkel w/ K&N in box
25x8x12/25x10x12 executioners
FO-4 + custom baffle tip
HD half-shafts
2k# winch, high mounted w/ snatchblock off lower frame
nerf bars
*coming soon*
'88 spec cam, p&p head
Vamps
DGL
4-2-4
IRS
(in reply to 03_VINSON)
RE: THE BASKET BALL TRICK - 8/30/2008 9:59:46 AM
bhmudder11
all of yall are over here talkin about how to make your bike float. lol im adding weight so it will stay on the bottom
TEAM ABS (Always Breaking Stuff)
MONEY WELL WASTED OFFROAD
07 AC 650 H1
BLACK ON BLACK
H.P.A.C.
You Know What It Means
(in reply to JPs300)
RE: THE BASKET BALL TRICK - 8/30/2008 10:26:28 AM
03_VINSON
Would puttin about 50 pounds of weight on the back rack help you keep the back down or would it make it harder to balance?  Some people say you need to keep the weight you add low but I don't wanna put water in my tires..Anybody done this?
HMF
UNI Filter
Custom Snorks
(in reply to bhmudder11)
RE: THE BASKET BALL TRICK - 8/30/2008 10:47:13 AM
bhmudder11
ORIGINAL: 03_VINSON
im making a hitch to hold weights and just add how much weight you need
07 AC 650 H1
BLACK ON BLACK
H.P.A.C.
RE: THE BASKET BALL TRICK - 8/30/2008 8:10:28 PM
Jake450s
A set of skid plates cut out of quarter inch steel helps keep them planted a little better.  If you're crafty you can duplicate one of the online aluminum swingarm skids out of the same steel.  The weight is all over, but the extra flat area helps "push" the water in front of you.  Makes it easier to balance IMO.  Weight on the back rack throws the balance off, harder to avoid going over backwards sometimes, especially if there's any current at all.
RE: THE BASKET BALL TRICK - 8/31/2008 11:52:22 AM
REBELRIDER
ORIGINAL: bhmudder11
This is what I'm screaming! I've added 18lbs. of water in each tire just to keep it down............
07' Polaris 700
29 Outlaws
AAEN
Snorkt' Through The Tunes
Visions
Keystone Light
Post #: 22
RE: THE BASKET BALL TRICK - 8/31/2008 10:49:27 PM
monster500s
I GOT 1 N MINE. IT DOES FLOAT BETTER...
07 foreman 525cc s green
29.5-10-12 laws
29.5-12-12 laws
snorkle air & exhausts
k&n
1in wheel spacers
ape axles
dyno jet 155
highlift diamond plate covers
stroker kit 10.5:1
.50 over
Gear Reduction
1996 TIMBERWOLF 250 2WD
25/8/12 STOCK 4MAN TIES N FRONT
22/11/10 MUB BUSTER REAR
.50 OVER
01 RANCHER 350 2WD
3IN HOME MADE LIFT
375 BBK
25/9.5/12 TSL SUPER SWAMPER
25/12.5/12 TSL SUPER SWAMPER
(in reply to REBELRIDER)
Post #: 23
RE: THE BASKET BALL TRICK - 9/1/2008 3:16:32 AM
joshua99ta
guys talking about 29.5s floatin bad... try 30" mudlites!!!!!!! they SUCK when ya get into really deep water!   I believe they are worse than the 31" laws.      the 30's would probably be nice if I would have had my bike spaced out a bunch where I could keep it balanced well... and I didnt weigh soo much... first time I tried deep water I had the bike sitting the the 12 o'clock position floating and I jumped off and used the wheeler for a life boat... I couldn't touch bottom and I stand about 6'4"
98 Foreman 400- Tan
31" laws on machined XL2s
getting some much needed improvements
08 PoPo RZR 800, 2" HL Lift, HL springs, diamond plate, winch, 28" Zillas on Chrome 14" SS112's, kick **** sterio and a permanent beer cooler
05 suzuki 'Busa on RC Compenents "OUTLAWS"
www.myspace.com/joshua99ta
(in reply to monster500s)
Post #: 24
RE: THE BASKET BALL TRICK - 9/1/2008 3:20:17 PM
Amuro
I’ve herd about the basket ball trick or soccer ball and also adding water into your tires. I have 26” Swamplite and also floats really easy and I go really deep to the point when the only thing you see is my snorkel lol. And you don’t need a lot of power to water wheelie, I can be at a dead stop and my bike starts to float/ front end start to float. Also I have 3 psi in my Swamplite so that my bike don’t float to much and it does help out.
2007 Honda TRX420FM
K&N Dry Charger
HL Front and Rear Springs
ITP SS112 on Swamp Lite 26-10-12 & 26-12-12
Probably the first truck bed liner Racks!
Finally snorkel out!!!!
American Muscle all the way but owns a Honda ATV. lol
(in reply to joshua99ta)
Post #: 25
RE: THE BASKET BALL TRICK - 9/1/2008 3:56:01 PM
BrokenKitty
Yea i agree also im trying figure out how to keep my fat cat down and not floating lol
_07 650 h-1_
- Tall snorkels
- Rad up top
- 2 " lift kit
- axle spacers
- Dalton clutch kit
- Hmf muffler
- K&N an jetted
- Front brush guard
- Rear brush guard
- Handle guards
(in reply to Amuro)
Post #: 26
RE: THE BASKET BALL TRICK - 9/1/2008 9:58:55 PM
Honda28s
If I put a basketball in the front of mine id tip...LOL.. I have 28in. swamplites on a Honda 300
Post #: 27
RE: THE BASKET BALL TRICK - 9/4/2008 11:24:36 AM
Lakemonster
My 02 rubicon doesnt even need water to wheelie, and when it is in water it has no issues whatsoever, its hard to keep it down in fact... fr:27x9 r:27x11 XTRs
-96' Honda 400 (Found in lake)
-K&N Filter n Pre-Charger
-2" Shock spacers
-Dynojet Jet kit
-Custom dual snorkels
-Custom exhuast from a yamaha R-6
-2" custom lift
-Warn 4-2-4 select
-26-12-11 Vamps... all the way around on rear rims
http://www.myspace.com/whiter_than_u
(in reply to Honda28s)
Post #: 28
1.094
