TEMPERATURES ON OUTY 800
All Forums >> [OEM Discussions] >> Can-Am BRP >> TEMPERATURES ON OUTY 800 Page: [1]
TEMPERATURES ON OUTY 800 - 10/4/2008 11:17:23 PM
lips450
hey guys i just picked up a highlifter temperature gauge and tried it out at ideal. In about 7 min the bike was running at 205 deg and then the fan kicks in knocking it down to 180 deg before it shut off. i tried this twice as i then let it go back up to 205 deg as the fan kicked in then shut the bike off. So i Then turned the key on but didnt start it and let the bike cool down useing the fan as this method cooled the bike down at twice the speed. as soon as it hit 180 deg i started the bike back up to see if the temperature changes and it didnt, it stayed the same. so for those that think idleing with the fan on cools the bike faster cause of serculation well it does but not nearly as fast as shutting it off and useing just the fan. so now you know how to cool the bike and just not guessing.
tomorrow i will be trail riding and will let you know what the bike runs at with no mods to help cool it down. Then on my next ride i will add some ice cool and see how much that really helps as it says it will nock it down by 40 deg. it's hard to beleave but now the truth will come out soon, i'll keep you guys posted. After that i will wrap my exhaust & see if it nocks it down even more. I'll be trying all the time to see how i can make this run cooler and keep you guys posted. Anyone think running without the thermostate will make a diffrence? cause i will try that aswell.
< Message edited by lips450 -- 10/5/2008 12:33:03 AM >
2008 outy 800xt
snorkel, uni air filter, dalton clutch kit, hmf exhaust, 1 3/4" front face lift, itp ss 212 rims, 28" outlaws
soon to get:
dynojet power commander, skid plates
l
RE: how hot a outlander ideals at - 10/4/2008 11:20:37 PM
bushhog750
how did you plumb the gauge into the rad hoses. or do you have a triple flow rad.
08 outlander 800 XT red- MaD Cannon tuned- center snorkled- vented- itp ss212's black- 29.5" outlaws- power commander- hmf pipe- uni filter- pipe lift- gorilla radiator relocate- ricochet skid plates- coolanol radiator fluid- crankcase vent mod- amsoil fluids- spider grips- sponsored by VISA and 60 hours a week.
(in reply to lips450)
RE: how hot a outlander ideals at - 10/4/2008 11:27:38 PM
lips450
ORIGINAL: bushhog750
acually that was easy i used the bottom of the rad hose cut it in half slaped the t pipe that came with it and done, this highlifter gauge is amazing just hope it hold up to the beating..
2008 outy 800xt
soon to get:
l
(in reply to bushhog750)
RE: how hot a outlander ideals at - 10/4/2008 11:53:58 PM
bushhog750
so the gauge comes with the hardware. just mount it plumb it. what are the electrical connections on the gauge. they are just for the back light on the gauge right.
RE: how hot a outlander ideals at - 10/5/2008 12:12:05 AM
lips450
ya the gauge comes with the hardware, the electrical connection on the back is ign, ground & lead wire not to mention light of coarse. I'll take a pic of it and try to post it
2008 outy 800xt
soon to get:
l
RE: how hot a outlander ideals at - 10/5/2008 12:56:13 AM
bushhog750
yeah id like to see it if you can get pic posted. thanks lips450
RE: how hot a outlander ideals at - 10/5/2008 3:48:14 PM
blevinsbulldog
my fan wont come on when i turn the 4-wheeler off & the key back on?????
07' 800 Outlander Max
Innova Mud Gear 26X10X12 & 26X12X12
Motosport Alloys CastleRock Wheels
Dalton Clutch Kit
Stealth Snorkel
Ricochet skids
Warn RT30
Pipe Lift
Hmf pipe
RE: how hot a outlander ideals at - 10/5/2008 4:34:48 PM
cobwoy
thats cause it is only cooling the fluid that is in the radiator. if it aint runnin it aint circulating. if it aint circulating, the motor isnt cooling from the fluid.
'07 outty 800, 6" CATVOS, 29.5 10s and 12 laws on torks, HMF & programmer, snorkel, ricochet skids custom bumper, radiator up high
2005 DODGE CTD
(in reply to blevinsbulldog)
RE: how hot a outlander ideals at - 10/5/2008 10:05:10 PM
NBM
Wrapping the exhaust won't make the motor run cooler, but the ambient heat that the exhaust gives off will lessen quite a bit.
(in reply to cobwoy)
RE: how hot a outlander ideals at - 10/6/2008 9:29:41 AM
GYPSY400
On my 400, it runs at an average of 205*F  Fan comes on at 210*F and off at 200*F..  these things run hot!!  This is why I think a temp Guage is so important from the factory..  screw the fancy gas guage, and give us a temp guage!!  you will overheat 10 times before running out of gas!!
2003 BRP Outlander 400
26" XTR's on Stock Wheels
cuz Chrome don't get ya Home!!
My Can-Am 400 Website
Give 'er all she can suffer!!!
(in reply to NBM)
RE: how hot a outlander ideals at - 10/6/2008 9:45:36 AM
007BF
ORIGINAL: cobwoy
I'm glad someone is paying attention!
Lips, you need to tune your bike.  With your HMF and Uni you are probably lean at idle building excess heat so idling is making your heat condition worse.
I-45 RACING
powered by Pit Proven Performance
Russell Coker #55
Texas A&M class of 07'
WHOOOOOP!!
C.M.R POINTS SEASON FINAL
1st OPEN/PRO SWAMPCROSS
1st CLASS 1 MUD BOG
3rd CLASS 2 SWAMPCROSS
3rd CLASS 2 MUD BOG
PSR POINTS SEASON FINAL
2nd LITE CLASS
2nd PRO B CLASS
