Synthetic winch rope
All Forums >> [Most Popular Discussions] >> ATV Accessories >> Synthetic winch rope Page: [1]
Synthetic winch rope - 9/7/2008 7:10:14 PM
jrf123185
So I ordered a synthetic winch cable for my winch. It will be in this week, so I took the cable off today and the cable bolted to the winch different than I have seen on other winches. The cable actually went through part of the spool and held in with a set screw...How will I bolt a synthetic rope like this one: http://i17.ebayimg.com/08/i/000/bc/5d/fafc_12.JPG on the spool? Thanks for the help. Ryan
1999 Honda Foreman 450ES bored .50 over, 2" HL lift, 27" ITP 589, Warn 424
2001 Chevrolet 2500HD 4x4 CrewCab, 8.1L 496ci Big Block, 11" lift, 38x15.50R20 MTZ, 20" Diamo 18 Karat, Cognito Heim Joint Tie Rods, Cognito Pitman & Idler System, Pioneer AVIC-N3 GPS/DVD, Memphis door speakers, K/N FIPK, Optima Yellow Top, Midland CB, Westin Bull Bar, PIAA 525 lights, Westin Stainless Steel Step Bars
RE: Synthetic winch rope - 9/7/2008 8:19:31 PM
06FX4
Shouldn't your synthetic bolt up just like your other one did ? I just ordered an Amsteel for mine but I haven't pulled my old synthetic one off yet...
A little bit of lesson learned advice I learned, unspool your whole rope about once a month or after you get it wet so it will dry and not sit unused for a while. I didn't do that and didn't use my winch till about 8 months after I got it, it worked fine a few times but about the 5th time I used it and put a heavy load on it, it broke...three times in a row. It looked like it almost kind of dry rotted from sitting spooled up and getting wet from riding in creeks...
07' Honda Rincon
2" HL Lift
14" ITP SS112's
27" Mudlite XTR's
WARN XT 30
ATV-Guru Front Bumper
07' Honda Rancher 4x4
www.myspace.com/djxrayted
(in reply to jrf123185)
RE: Synthetic winch rope - 9/7/2008 8:21:31 PM
Kodiak 450
Replace the allen head set screw with a round head set screw and then use the terminal.
If you have any questions call my cell
580 504 1405
Todd
Team Custom Splice
2008 Rhino 700
"The Rhino Wrecker"
Full boom, 3 Warn 4.0's Custom Aluminium Diamond Plate Bed, Dual Exaust, Snorkels
Yep it's a Tow Truck for ATV's
www.rhinowrecker.com
2009 Polaris 850 XP Rollin on HL XL Rims and 31" Outlaws, 3,500LB Warn Winch- 50' AmSteel Blue.
2007.5 GMC 2500HD Z71 - M12000 Warn Winch, 150' 3/8 AmSteel Blue
(in reply to 06FX4)
RE: Synthetic winch rope - 9/7/2008 8:24:45 PM
Hatchie
I replaced the winch cable on a couple of Warns with synthetic. I pushed the synthetic line through the hole, tied a knot in it, melted it down a little with a torch and called it GOOD.
I don't know if that helps...maybe a pic of your spool without the cable on it so we could see what you're talking about. I don't remember seeing one with a set screw.
HATCHIE
1995 Yahama Big Bear 350
28 inch Mud Lites on ITP Type 5's
Aluminum Wheel Spacers
VIPER 3K Winch-synthetic rope
New Green Plastics
Advantage Max-1 Seat Cover
1997 Yamaha Kodiak 400
Mud Bugs on ITP Type 4's
WARN 2K Winch-steel cable
Faded Green Plastics but....
looking for some Old School Yellow Plastics
(in reply to 06FX4)
RE: Synthetic winch rope - 9/7/2008 8:25:28 PM
jrf123185
Oooohhh. That should work. Alright. I appreciate the help. When the kit comes in Im gonna put it on and if I cant get it to work then I'll holla at you. Thanks for the help and tips on using the synthetic rope.
Ryan
(in reply to Kodiak 450)
RE: Synthetic winch rope - 9/7/2008 8:33:13 PM
Kodiak 450
Most of the major brand winches attach like Hatchie says and thread into the drum and back out with a small steel button that wedges in.
Make sure you keep a few wraps on the drum that crimp will not hold much weight.
Todd
Team Custom Splice
2008 Rhino 700
"The Rhino Wrecker"
RE: Synthetic winch rope - 9/7/2008 8:56:26 PM
jrf123185
Cant really see the typing but the red circles are where the cable went through and the set screw is circled in blue. The only thing is, I dont have a major brand winch. It is a THAC atv 2000 lb winch...works perfect and didnt pay much. Its a replica of a Superwinch model. Hope the pic explains.
Thumbnail Image
Attachment (1)
RE: Synthetic winch rope - 9/7/2008 11:43:51 PM
Hatchie
ORIGINAL: Kodiak 450
Todd
That's the same spool as most other brands. It's just got a set screw too.
If you thread it in the little hole toward the big hole, you'll have room for the knot and the wraps will lay flat over it.
Todd is right. Make sure you keep one layer of wraps on the spool!
< Message edited by Hatchie -- 9/7/2008 11:44:53 PM >
HATCHIE
New Green Plastics
RE: Synthetic winch rope - 9/8/2008 7:25:45 PM
Kodiak 450
The easiest way I have found to keep the first 4-5 wraps on is to basically granny-knot them on the drum.
I know I have had two times I have gotten two much rope off the drum, one was at Mud Nats pulling a Polaris out of the pit with a locked up tranny, the other I was in a ditch in Kansas in my truck.
Since then I have been granny-knotting the drum and it has worked like a charm!
Team Custom Splice
2008 Rhino 700
"The Rhino Wrecker"
(in reply to Hatchie)
RE: Synthetic winch rope - 9/10/2008 10:18:11 PM
CRAIGGRIZZ700
will a rope work on any winch? ive heard the if it has a cable then it wont be geared right for a rope and would burn up? is that true?      i have venom 3500
08 GRIZZLY 700 FI
28X11 WIDES MAXXIS ZILLAS
14X8 WIDES ITP SS 112
VENOM 3500LB WINCH
EHS RACING FREE FLOW INTAKE
EHS RACING OUTERWEARS AIRBOX
EHS EFI CONTROLLER
2" POWER TIP "THE ORIGINAL"
DYNATEK
2004 YAMAHA BIG BEAR
27" ITP MUDLITE TIRES
RE: Synthetic winch rope - 9/11/2008 6:34:28 AM
devildog12210
You just need a hawse fairlead. The roller fairleads can cut the rope if it goes to the side any. Gearing??? You wont have any problems with the gearing bro. Its all the same.
"I think this is the most extraordinary collection of talent and of human knowledge that has ever been gathered together at the White House – with the possible exception of when Thomas Jefferson dined alone." JFK said welcoming fourty nine Nobel Prize winners to the White House in 1962
(in reply to CRAIGGRIZZ700)
RE: Synthetic winch rope - 9/11/2008 8:29:24 AM
Kodiak 450
Yes a synthetic will go on ANY winch.
The speed of the drum does not matter.
The Hawse Fairlead is always something to look into, especially if you cannot see your winch to make sure the cable is not pilling to one side and to keep the AmSteel out of the corners of the rollers.
The biggest problem I have with Roller fairleads is that the AmSteel Blue or AmSteel is so smooth that it will not make the rollers turn.
I have personally gone to using a UHMW fairlead which is made of a very similar material to AmSteel, so there is very little friction between the two materials ( read less wear ). You can look at EBay item #250279900807 to see what I am talking about.
Todd
< Message edited by Kodiak 450 -- 9/11/2008 2:02:12 PM >
Team Custom Splice
2008 Rhino 700
"The Rhino Wrecker"
(in reply to devildog12210)
RE: Synthetic winch rope - 9/11/2008 10:24:19 PM
jrf123185
Yea the kit I went with was on ebay and it was the 50 ft Amsteel blue synthetic rope, 5 ft chafe guard, UHMW hawse fairlead, winch saver, and new hook. All of it was $84.75 after shipping and it was here in 2 days. Item number: 280264101813 on ebay. I got it on today and love it. the hawse fairlead is low profile and I'm no longer scared of knocking my back window out with my roller fairlead.  But thanks to all the guys that helped with all my questions about putting it on.
Ryan
RE: Synthetic winch rope - 9/12/2008 3:00:06 PM
Kodiak 450
Glad to hear it,
I sell those UHMW fairleads and have yet to have a problem with them that was not caused by operator error...
Team Custom Splice
2008 Rhino 700
"The Rhino Wrecker"
