4man0822
ORIGINAL: TikiGod77 I have a 1999 Suzuki Quadrunner LT-250FX 4x4. Not really big but I have fun with it. However, I need some more ground clearance and I have not found a lift kit for it. It still has the original tires on it and I thought about going with some bigger tires. The front tires are 22x8-10 and the rear tires are 25x12-10. I can pull these tires without any problems but I want to go bigger. My questions are: What is the largest tire size I can use without a lift? Do I have to keep the same ratio as the 22(f) and 25(r) or can I get them closer in size? I've seen alot of folks with the 300 4trax run the same size on both front & back. They came stock with a 1" size difference(23"x8"x11" front & 24"x9"x11" rear). I've only seen 1 other guy(maybe a couple) thinking like me on this matter, stay the same difference(24" front & 27" rear) IMO! They're geared to run like this, so run it like this! Hope this helps, maybe?? Later Brandon
I'm just some dumb, not plumb dumb, huh!! My new ride= 08 750 King Quad Belt snorked, VDI, M109R injector, EPI yellow spring, 18 gram weights, 2mm shim mod(Coop 45 mod) Twin Air & Yoshi=WOW! 4 a single, she hauls!! "STOLEN"--- 07 700 Camo King Yoshi Pipe, PC3, UNI filter, 27" Swamp Fox Plus, ATV Audiopipe, with the Bazookas(I love this thing)& Gorilla 2500XT W/syn rope 05 500 Foreman 26"589 M+S 0n black C-4's, HMF Utility series, with jet, & UNI filter, boot guards& kimpex b
