Supercharger for Prowler
All Forums >> [OEM Discussions] >> Arctic Cat >> Supercharger for Prowler Page: [1]
Supercharger for Prowler - 10/9/2008 2:47:29 PM
Cajun Ken
Saw this info on a thread over on the ATV Nation site. Thought I would bring it here for your enjoyment.
Home ::  Super Charger Kit ::  ARCTIC CAT PROWLER INTERCOOLED SUPERCHARGER KIT
larger image
ARCTIC CAT UTV SIDE X SIDE PROWLER SUPERCHARGER KITS
ATVONICS AND ATI/PROCHARGER
ATVONICS & ATI’s self-contained (SC) ProCharger models are the first and only gear-driven centrifugal superchargers to feature self-lubrication, and contain the industry’s most advanced technology. In addition to the patented self-contained oiling design, SC ProChargers also feature the highest step-up ratio, exclusive billet impellers, and the industry's only billet gearcases for superior rigidity, sealing and appearance. These proven self-contained ProChargers, introduced in 1999, were designed specifically for internal lubrication and have become the industry standard. WE HAVE THREE STAGES OF SUPERCHARGER SYSTEMS
***********STAGE ONE: BASIC SUPERCHARGER HEAD KIT PRODUCING 7-8 LBS OF SOLID RELIABLE BOOST, NON-INTERCOOLED, COG BELT DRIVEN, MADE IN THE U.S.A. FROM 6061 BILLET ALUMINUM, COMES WITH THREE OIL CHANGES TUBES BRACKETS AND CLAMPS.****************
********STAGE TWO: HAS SEVERAL INTERCOOLER OPTIONS, AND BOOST CHOICES,GAGE MONITORING PACKS, BILLET DASH PANNELS, DUAL EXHAUST, INTAKE SYSTEMS, AND BLOW OFF VALVES
******************STAGE THREE: HAS ALL OF THESE OPTIONS BUT ALSO CAN BE CONVERTED TO FUEL INJECTION AND OPTIONAL NITROUS ASSIST.
IF YOUR LOOKING FOR A LITTLE EXTRA POWER TO CARRY YOUR NEW CAGE AND GEAR, OR EXTRA RELIABLE POWER FOR WORKING APPLICATIONS IN HIGH ALTITUDE AND DEMANDING CONDITIONS OR IF YOU WANT A HIGH POWER RACE MACHINE. GIVE US A CALL, WE WILL PUT A SYSTEM TOGETHER FOR YOU.
Call for price
  • Shipping Weight: 75lbs
  • 25 Units in Stock
    Cajun Ken
    2008 AC 700 H1
    ITP T-4 Rims with 29.5x10 Outlaws
    3.6 Gears
    MX3500 Viper Winch with Synthetic Rope
    Home Made Lift
    http://www.myspace.com/kenandnatalie
  • Post #: 1
    RE: Supercharger for Prowler - 10/9/2008 2:50:52 PM
    Cajun Ken
    also saw they have a long travel suspension kit for the Prowler as well.
    Home ::  LONG-TRAVEL SUSPENSION ::  Billet Aluminum Long-travel suspension Prowler, RZR, Rhino
    larger image
    $5,400.00
    Arctic Cat- Prowler, Polaris -RZR and Yamaha -Rhino Billet Aluminum Suspension Systems.
    ATVonics has released our Solid Billet Aluminum long-travel suspension systems.
    For Arctic Cat Prowlers, Polaris RZR’s and Yamaha Rhino’s.
    Our suspension system is CNC machined from solid 6061 Billet Aluminum for superior strength and lightest wheel weight A-Arm’s. We use Delrin A-arm bushings and serviceable ¾ inch Uniball’s at the wheel joint.
    This is the same technology that off-road racing trucks are using. Not only are Uniballs stronger than Heims but they also offer more articulation angle.
    This suspension system gives you a true 14inches of wheel travel with stock length shocks.
    The Prowlers are 4 inches wider at each spindle, the RZR’s and Rhino’s are 6 inches wider at each spindle for maximum stability and handling.
    The A-Arms can be anodized for color matching and can accept most any shock combination of your choice: King, Elka, Walker, Fox and even your stock shocks if you want to use them for awhile.
    Arctic Cat Prowlers get all new super strong huge journal custom half shaft replacement axles (THE BEST AXLE MADE)while RZR’s and Rhino’s can get new longer axles or new optional super strong custom replacement half shafts as well.
    Not only are they awesome looking but they are light weight and super strong for off-road abuse. Kit’s comes complete with all hardware and parts.
    Rhino and RZR systems start at $ 5400 with Walker evans shocks Prowler systems start at $ 6300 with walker evans shocks and new complete custom half-shaft axle assemblies (the strongest axle made).
    • NO WELDING REQUIRED • MOUNTS IN FACTORY A-ARM PIVOTS • Complete bolt up kit
    Cajun Ken
    2008 AC 700 H1
    3.6 Gears
    Home Made Lift
    (in reply to Cajun Ken)
    RE: Supercharger for Prowler - 10/9/2008 3:34:37 PM
    Dreggsta
    That is nice!!!
    Team Southern Swamp Boyz
    '08 700 H1 SE
    Nology Coil & Wire
    LE Front & Rear Bumpers
    Big OG Racks
    Warn 3k Winch
    Powermadd Hand Guards
    Moose Hand Grips by O.D.I.
    High Lifter Springs
    4.0 Gears
    B & J Customs 2.5" Lift
    ITP 14x8 SS 212's Machined Silver
    Gorila Sliverbacks 30x11x14's On All Four Paw's
    Rad Racked (MudTechInc)
    Gorila Axles
    Fully Snorked w/Pre-filter
    Exhaust Mod & Snorked
    RE: Supercharger for Prowler - 10/9/2008 3:59:48 PM
    BrokenKitty
    The turbo looks sick !! Gona wake the prowlers up and that turbo , speedwerx kit and nitrous oh my god ...beast lol .
    PINNEN AINT EASY....
    ------ 07 650 h1-------
    - 32 " silverbacks on ITP type 7s black
    - 2.5 " Bnj lift on Highlifter springs
    - Snorkels way over the handle bars
    - Radiator on top of the rack
    - Epi white spring and shimmed primary with dalton rollers
    - Hmf pipe with k&n filter and jetted
    - Arcticcat front and rear brush guards and handle guards
    - Exhaust snorkel de attachable
    - Camo seat and black cargo bag
    - Gorilla 3000 winch 4th winch ..yup
    - running 21"s of g/c
    (in reply to Dreggsta)
    RE: Supercharger for Prowler - 10/9/2008 4:03:19 PM
    Cajun Ken
    Interesting statement about the axles for that long travel kit. I wonder if they could hold up to the angle of a big lift?
    Cajun Ken
    2008 AC 700 H1
    3.6 Gears
    Home Made Lift
    RE: Supercharger for Prowler - 10/9/2008 6:18:34 PM
    fall guy
    what is the biggest tire that you could run on the long travel kit?
    RE: Supercharger for Prowler - 10/9/2008 8:34:22 PM
    The Duke
    This is awesome, those prowlers are great machines, I wouldn't mind wheelin up a storm on a blown prowler, LOL!!
    (in reply to fall guy)
    RE: Supercharger for Prowler - 10/9/2008 9:01:59 PM
    bustedknuckles
    ORIGINAL: BrokenKitty
    Its a supercharger.
    This looks like a nice setup. Only have one question. When is the tcat kit coming out?
    STEELHORSES
    08 ThunderCat
    8" raked catvos lift
    gorilla axles
    30"silverbacks
    08 650H1
    4" catvos lift
    gorilla axles
    31" outlaws
    (in reply to BrokenKitty)
    RE: Supercharger for Prowler - 10/9/2008 9:27:18 PM
    swamp_fox
    my buddy and I have talked about it for his.  It'd be so cool to have a blow off valve.
    --Swamp Fox--
    www.BamaBoggers.com
    Push it to the Limits!
    (in reply to bustedknuckles)
    RE: Supercharger for Prowler - 10/9/2008 10:08:27 PM
    Black Cat 650
     Hey Alan you could buy the unit & gears and fab up some brackets and have your T-Cat kit.
    Scott
    '07 Arctic Cat 650 H1 Black, Soundtube ATV stereo, Warn 2500 winch, ITP series 7 wheels, 27" Mudlights
    Radiator relocated, snorkled..
    '08 Fun Finder Xtra Toy Hauler
    1 very understanding wife.....
    (in reply to swamp_fox)
    RE: Supercharger for Prowler - 10/9/2008 11:08:04 PM
    NBM
    A 950 on constant boost would be a monster. I would like to see that!
    (in reply to Black Cat 650)
    RE: Supercharger for Prowler - 10/10/2008 12:32:49 PM
    bustedknuckles
    Taking donations. If you really want to see it.
    STEELHORSES
    08 ThunderCat
    gorilla axles
    30"silverbacks
    08 650H1
    4" catvos lift
    gorilla axles
    31" outlaws
    (in reply to NBM)
    RE: Supercharger for Prowler - 10/10/2008 12:36:42 PM
    How well do you think that would hold up to mud/water...lol open belt and all..
    08 650H1 LE
    Warn 3.0
    Snorkeled,Rad racked
    Custom gauges
    muffler tweaked
    Dyna Tech CDI
    Custom clutch kit
    4.0 gears
    HL springs, HL spacers
    Gorilla axles
    29.5 Laws, custom LE wheels
    30" MLs, Black Castle Roks
    05 500m
    Hidden Snorkel
    muffler tweaked
    HL temp gauge
    26" 589MTs, ITP type 6s
    H.ard P.ack A.rctic C.ats
    RE: Supercharger for Prowler - 10/10/2008 1:09:28 PM
    MUDTECHinc
    Those axles are Turner Cycles driveline, so there is no worry about it holding up to extreme angles.
    MUDTECHinc Custom ATV Fabrication Bog Team
    2005 ARCTIC CAT 650:
    29.5" Laws on Beadlocks
    Web cam
    2008 Arctic Cat 1000 H2
    Carb slide mod
    http://s226.photobucket.com/albums/dd185/MUDTECHinc/
    Arctic Cat 650 H1 motor for sale $1800 plus shipping
    Arctic Cat 500/ suzuki 500 ported head for sale $450 free shipping.
    (in reply to GWC)
    RE: Supercharger for Prowler - 10/10/2008 2:27:21 PM
    bustedknuckles
    ORIGINAL: GWC
    I wouldn't be in the mud. It would be so fast it would just skim it......without the skis.
    STEELHORSES
    08 ThunderCat
    gorilla axles
    30"silverbacks
    08 650H1
    4" catvos lift
    gorilla axles
    31" outlaws
    (in reply to GWC)
    RE: Supercharger for Prowler - 10/10/2008 2:41:33 PM
    lol
    08 650H1 LE
    Warn 3.0
    Custom gauges
    muffler tweaked
    Dyna Tech CDI
    Custom clutch kit
    4.0 gears
    Gorilla axles
    05 500m
    Hidden Snorkel
    muffler tweaked
    HL temp gauge
    RE: Supercharger for Prowler - 10/10/2008 3:05:32 PM
    BrokenKitty
    I wonder with all the mods for the prowler will there be a wheeling prowler with this kit lol .
    (in reply to GWC)
    RE: Supercharger for Prowler - 10/10/2008 3:33:03 PM
    bustedknuckles
    The thunder prowler will wheelie.
    STEELHORSES
    08 ThunderCat
    gorilla axles
    30"silverbacks
    08 650H1
    4" catvos lift
    gorilla axles
    31" outlaws
    RE: Supercharger for Prowler - 10/10/2008 3:41:23 PM
    Bunk650
    ORIGINAL: bustedknuckles
     really?? that's nuts. I didn't know that...stock? or with a few mods?
    HPAC
    '04 650 V2 LE
    Dynatek CDI
    Drilled N Clipped
    Pink Primary
    Red Secondary
    Custom Teflon Shock Bushings
    28" Gators
    2.5 Warn
    Myspace
    RE: Supercharger for Prowler - 10/10/2008 3:58:35 PM
    MUDTECHinc
    http://www.youtube.com/watch?v=MzHxVdvtcDw
    that is a bone stock prowler 650, it was the first day my brother got it. it had about 2 miles on it at this point. I think there is no doubt a 1000 prowler will do this with out the people in the back.
    Web cam
    Carb slide mod
    (in reply to Bunk650)
    RE: Supercharger for Prowler - 10/10/2008 4:07:53 PM
    8upwithmud
    I pulled the front wheels 2" off the ground on a 700 prowler.  Bone stock with less than one mile.
    05 Evil Twin
    Bored, stroked, camed, ported, polished,
    piped, jetted, snorkeled, clutched, geared,
    dynateked, Gorrilla'd, lifted, and lawed.
    13 axles
    6 motors
    6 differentials
    1 fan
    ? belts
    04 500M with 28 laws
    05 400A with 27 lites
    06 Night Rod
    http://myspace.com/leebo1973
    ........................HPAC.........................
    .............Hard Pack Arctic Cats.............
    (in reply to MUDTECHinc)
    RE: Supercharger for Prowler - 10/10/2008 4:16:23 PM
    bustedknuckles
    ORIGINAL: Bunk650
    The prowler with a tc motor that SteelHorses built just before mud nats. It had a 6" CATVOS lift 32" sbacks and 4.0's and dual HMF's. It would wheelie in Hi gear. It would only do it a few times before exploding the rear diff. They have made alot of changes to it and tuckerracing owns it and competes in the ruv class with it now.
    STEELHORSES
    08 ThunderCat
    gorilla axles
    30"silverbacks
    08 650H1
    4" catvos lift
    gorilla axles
    31" outlaws
    Post #: 22
    RE: Supercharger for Prowler - 10/10/2008 5:04:09 PM
    BrokenKitty
    ORIGINAL: Bunk650
    I want to see the wheelie ....
    Post #: 23
    RE: Supercharger for Prowler - 10/10/2008 11:21:12 PM
    Black Cat 650
    I will help you out Alan....I got some used bolts around here somewhere....
    Scott
    Post #: 24
    RE: Supercharger for Prowler - 10/11/2008 7:00:23 PM
    jpxj94
    I found a video from ATVonics
    http://www.youtube.com/watch?v=mLQq_VgjzLA
    Post #: 25
