bansheefan03
your problem is water in the carb gas floats on water so all the water stays on the bottom of the carb and thats why it will idle and die when u give it gas cause ur idle circuit is higher in the cab where there is good clean gas but as soon as u start giving it throttle it starts pulling it from the other jet which are at the bottom of the bowl and where the water is at causing it to die just always any time you sink one unscrew the drain screw and let it drain for bout thirty sec then tighten it back up
2006 rhino 660 29.5 swamplites,lift,rear steer,snorkled 98 300 376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ silverbacks ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb soon to come ex head, disc brakes 98 300 8" lift, ape axles,gear reduction,xl2 wheels, axle paddle,high compression piston, clutch kit,459 cam,big red timing c
