Stock Honda 300 Jet?
All Forums >> [OEM Discussions] >> Honda >> Stock Honda 300 Jet? Page: [1]
Stock Honda 300 Jet? - 11/23/2008 8:05:54 PM
Solitude
Hey I have a Dyno Jet Kit on my 300 but it had a 116 Main Jet in it and its getting WAY to much fuel. Whats the stock Jet that supposed to come in it?
06' SLC Lifted King Quad 700 EFI For Sale: http://easttexas.craigslist.org/mcy/960791955.html
94' Honda 300 4x4
EDL's, ITP Black 212's, Lift, Progressive 512 Shocks, DJ Kit, K&N w/ Outerwears, Savant Floorboards, Gear Reduction, EPI Clutch Kit, XP Disk Brakes, Snorkles, Gutted Exhuast, Pro Grips
RE: Stock Honda 300 Jet? - 11/23/2008 9:22:05 PM
bansheefan03
what is the 116 dyno jet compared to kehin jets cause i know the size for the number aint the same  cause thats all i run i dont waste my money on the jet kits
2006 rhino 660
98 300
376 bbk,4.5mm stroked crank,ported head,ids2,snorkle,lift,body lift,locker,EDL/ silverbacks ,axle paddle,459 cam,gear reduction,clutch kit,warn 424,chrome XL2 wheels,katana oil cooler,400ex carb
98 300
8" lift, ape axles,gear reduction,xl2 wheels, axle paddle,high compression piston, clutch kit,459 cam,big red timing c
(in reply to Solitude)
RE: Stock Honda 300 Jet? - 11/23/2008 9:49:46 PM
Solitude
Well I got a free DynoJet Kit with it so I installed it and Drilled the Slide, and Im now set on the Top Notch, and the A/F Screw 1 1/4 Turn Out with a 116 Jet in it. Its still running ruff at idle a little but then again I dont have the stock rubber snorkle tube to the airbox so thats where my airs coming from. Whats the symtoms of a bad Timing Chain and or Valves needed adjusted, but I took the covers off and my valves are as tight as can be.
94' Honda 300 4x4
(in reply to bansheefan03)
RE: Stock Honda 300 Jet? - 11/24/2008 5:36:33 AM
steveo3318
stock jet is a 125 in the factory carb.
08 Brute Force 750
NRA fuel injected
2" SS lift
HL lift springs
Black HMF Utility exhaust
HMF optimizer
29.5" Outlaws on 112 SS ITP
WARN 2500 winch
UNI air filter
RED secondary clutch spring
ASR X series tie rods
Moose bushings
snorkel MIMB
Custom jam box
1992 honda 300 4x4
26 outlaws and clean
EPI clutch kit
UNI filter
gear reduction (coming soon)
RE: Stock Honda 300 Jet? - 11/24/2008 6:52:56 AM
bansheefan03
take the adjusment screw out the end of the tensioner for the timing chain and tightin down on the screw  some if it makes less noise then its the chain after you do that lossen off on the tensioner and let it self adjust to normal also it will be a louder noise at idle and not be so lound when you give it gas
2006 rhino 660
98 300
98 300
(in reply to steveo3318)
RE: Stock Honda 300 Jet? - 11/24/2008 6:55:47 AM
bansheefan03
are just check the valves it dont take but about ten min to do put it on tdc of compression stroke and the intake should be .005 and exhaust .006
2006 rhino 660
98 300
98 300
