Dezz
Use away man. There is no reason in the world why you cannot use whatever bolt you want. I know exactly what you mean with Yamaha atv's, snowmachines, and power equipment. The bolts they use are absolute garbage. When I worked at Yamaha, I got real good with using a drill, easy-out bolt/screw removers, and a mig welder (I will not explain). The best part is that Yamaha bolts use common threads. This means that almost all the bolts can be replaced with stronger bolts. The screws are the same way. I hope this answers your question. Dezz
1998 Grizzly 600 27 x 12 - 12 ITP Blackwater XT tires - Back Tires 27 x 10 - 12 Inch ITP Mudlite XL - Front Tires ITP Delta Black Chrome Rims Uni Air Filter Warn A2000 Winch Detroit Gearless Locker Oxlite CV joint protectors
