Sportsman 500 wont run
All Forums >> [OEM Discussions] >> Polaris >> Sportsman 500 wont run Page: [1]
Sportsman 500 wont run - 8/17/2008 4:42:02 PM
wfo257
I got a 07 sportsman 500 EFI and this past weekend went riding.  I went into a water hole that was up to the top of my fenders and it died right in the middle of the hole.  We pulled it out and there was no water in my airbox but i did get water in my oil.  The next day I changed my oil and filter.  I also drained the water out of my exhaust.  I tried to start it but the dang thing wont start.  My injector is spraying fuel and I am also getting spark through my spark plug.  Anyone have any ideas?
< Message edited by wfo257 -- 8/18/2008 9:02:55 AM >
07 Polaris SP 500 EFI
29.5 Laws
Heelclicker clutch kit
UNI Filter
Strobes
Tunes
06 Arctic cat 650 H1
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
RE: sp500 wont start - 8/17/2008 9:26:16 PM
wfo257
Well I just checked the codes and it is flashing code 22 which is the TPS.  Anyone know how to adjust it?
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
(in reply to wfo257)
RE: Sportsman 500 wont start - 8/18/2008 9:02:03 AM
wfo257
Are the throttle position sensors bad about going out?
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
RE: Sportsman 500 wont start - 8/18/2008 9:17:10 PM
wfo257
Anyone know anything?
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
RE: Sportsman 500 wont start - 8/19/2008 3:11:38 PM
son of the south
did you test your compression you may have bad rings
insane in the brain
DO NOT TUCH THE TRIM
[X] REBEL FOR LIFE [X]
2008 CAN-AM OUTLANDER 800H.O.,29.5 outlaws
2004 kawasaki bayou 250 cobra pipe
2008 polaris 500 sportsman carb snorkel'd
2006 honda rubicon hmf pipe jet filter snorkel/(cold air intake)28'' mudbs 550bbk web cam
for ark mud riding click the link below
http://www.teamackrite.net/
RE: Sportsman 500 wont start - 8/20/2008 8:22:49 AM
wfo257
Yes, I have plenty of compression.  If i give it gas when I try to start it, it will sometimes backfire.
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
(in reply to son of the south)
RE: Sportsman 500 wont start - 8/20/2008 8:32:45 AM
OldSchool
Sometimes even if you can see spark on the plug it is not strong enough to ignite all the fuel being sprayed in the bike.  Not saying that is your problem, but putting in a new plug is a cheap thing to try.  The reason you got water in the oil is the crank case vent line -they have a slit in them down by the motor - it is easy to replace and saves some oil changes.
If you got a bunch of water in your exhaust to the point where you had to drain, you may have to tip the bike up on the back rack.  If there is water still in the header or pipe the bike will not start.  I have seen that on that trail multiple times.
Other than that, as long as you are getting fuel and strong spark then you are hitting all of your key points to make an engine run.
< Message edited by OldSchool -- 8/20/2008 8:34:01 AM >
1997 Polaris SP 500
2" Lift
28x10 Laws
Snorkled and Radiator reloacted
2003 Polaris 500 HO Sportsman
CAMO
1" Lift
27x9.5 Laws
RE: Sportsman 500 wont start - 8/20/2008 1:47:26 PM
arcticcat400
i have the exact same bike and i went in deep water aswell.  Will it turn over but jsut not start?  Might want to check your flywheel key. Thats what mine was
(in reply to OldSchool)
RE: Sportsman 500 wont start - 8/20/2008 3:46:13 PM
wfo257
Yes it will turn over but wont start.  I did flip it up on the back rack and turned it over a few times to drain the water out of the exhaust.  I am going to get a new spark plug today and try it.
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
(in reply to arcticcat400)
RE: Sportsman 500 wont start - 8/20/2008 9:52:44 PM
P.O.S700
THIS THREAD IS LIKE BEATING A DEAD HORSE, BUT PULL BOTH PIGTAIL CONNECTORS OFF THE SURE-FIRE BOX AND BLOW THEM OUT. ITS LOCATED ABOVE THE RADIATOR. THN TRY IT AGAIN, IF IT DONT WORK , COME TALK TO ME!!!!!!
DIRTY SOUTH ATV "RID'N DIRTY", 2006 HUMMER H2, 2006 DODGE DUALLY,2002 DODGE 24V(ROAD ROCKET), 2007 H.O POPO, 2003 700 POPO, 2008 RHINO 700 CUSTOM BY DSA, FULL CUSTOM CAGE, PRO 60 WETSOUNDS, 10" KICKER L5, KICKER 800.5, KICKER 700.1, BLINKYS, 28" LAWS, DALTON CLUTCH, 3" PUCK LIFT, MONKEY AXLES, AMR KIT, SS BODY KIT, STEATH SNORKS IN CAGE, AND A BIG **** COOLER
RE: Sportsman 500 wont start - 8/23/2008 10:44:15 AM
wfo257
Ok I pulled the connectors off of the sure-fire-box and blew them out.  I plugged them back in and tried to start it and still nothing!  All it does is turnover.  I ordered a TPS and it is suppose to be here wednesday so I guess we will see if that works.
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
(in reply to P.O.S700)
RE: Sportsman 500 wont start - 8/23/2008 11:39:14 AM
desert500
wfo: I don't have a factory service manual yet, BUT... I do have a 1200cc inline 4 that I have done a lot of work on/with (Suzuki) and it has TPS -- adjustment of the TPS is fairly "touchy" with that bike... basically the TPS with that bike "smooths things out" when properly adjusted and slightly better fuel mileage is achieved... BUT back to your situation -- If I unplug the TPS connector on the 1200 bike, the bike runs and runs very good.. very "touchy" and in fact you might call it "race tune"... seems the first generation bikes did not have TPS (that model) and they later put it on to increase mpg a little.
Anyway, if the 500 works like the 1200 and you think you have a bad TPS, try unplugging it while you are waiting for the new part... maybe you can go riding??
RE: Sportsman 500 wont start - 8/23/2008 12:46:46 PM
800sporty
Had this same problem with my 05 500. Changed the sprk plug and it busted right off. Didn't make sense to me because just like you when I pulled the plug it looked like it had good spark to me.
< Message edited by 800sporty -- 8/23/2008 3:01:53 PM >
(in reply to desert500)
RE: Sportsman 500 wont run - 8/23/2008 6:23:35 PM
wfo257
I tired a new plug and still nothing.
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
RE: Sportsman 500 wont run - 8/23/2008 11:09:42 PM
libertypolaris
if you mess with the tps sensor you have to recalibrate it and the dealer or someone with the right tools is the only way to get it right.  The majority of the problems with the efi systems is the wiring to the sensor.  the wiring will break within the insulation.
RE: Sportsman 500 wont run - 8/23/2008 11:24:13 PM
desert500
ORIGINAL: libertypolaris
Interesting -- I have worked on a Trans Am TPS and also a Suzuki 1200 TPS and only used a volt ohm meter to dial them in.. ran great.
With the Suzuki tho, like I said.. just unplug it and bike ran great.
(in reply to libertypolaris)
RE: Sportsman 500 wont run - 8/23/2008 11:26:00 PM
libertypolaris
Just found my manual for the 08 sportsman 500.  Here is the checks for the tps   pin 1 is violet, pin 2 is dark green, pin 3 is orange.  using an ohms meter measure resistance from pin 2 to ground = nothing if any resistance the sensor is bad.  measure from pin 1-2 with throttle closed ahould be 4 Kohms.  measure from pin 1-2 with throttle open should be 820 ohms. measure from pin 1-3 should be 4-6 Kohms.  if all these check right start pullin on wires and see if u see the insulation changes to a lighter color if it does wire broken inside.
RE: Sportsman 500 wont run - 8/26/2008 9:38:34 PM
wfo257
Well I just received my TPS today and installed it.  Guess thats what it was!  It starts and runs great!  Thanks everyone for all the help!
29.5 Laws
UNI Filter
Strobes
Tunes
29.5 Outlaws
K&N air filter
Jet kit
HMF pipe
0.703
