Spilt audio pipe
Spilt audio pipe
All Forums >> [Most Popular Discussions] >> ATV Accessories >> Spilt audio pipe Page: [1]
Spilt audio pipe - 10/2/2008 5:30:02 AM
BrokenKitty
Hey guys im lookin to attempt to make a split audio pipe so can anyone help me that has made one can help out on materials etc ???
PINNEN AINT EASY....
------ 07 650 h1-------
- 32 " silverbacks on ITP type 7s black
- 2.5 " Bnj lift on Highlifter springs
- Snorkels way over the handle bars
- Radiator on top of the rack
- Epi white spring and shimmed primary with dalton rollers
- Hmf pipe with k&n filter and jetted
- Arcticcat front and rear brush guards and handle guards
- Exhaust snorkel de attachable
- Camo seat and black cargo bag
- Gorilla 3000 winch 4th winch ..yup
- running 21"s of g/c
RE: Spilt audio pipe - 10/2/2008 6:52:09 AM
devildog12210
You need about 1.5ft of 6" PVC and two caps and two couplers. Put the amp inside one of the tubes and the rest is just like making a regular one. Really easy and you can still keep the rad up top. I'll see if I cant dig some pics up of mine. I didn't use couplers though so mine doesn't look as good as some of them I have seen. It works for me though.
"I think this is the most extraordinary collection of talent and of human knowledge that has ever been gathered together at the White House – with the possible exception of when Thomas Jefferson dined alone." JFK said welcoming fourty nine Nobel Prize winners to the White House in 1962
(in reply to BrokenKitty)
RE: Spilt audio pipe - 10/2/2008 6:56:42 AM
devildog12210
(in reply to devildog12210)
RE: Spilt audio pipe - 10/2/2008 2:07:03 PM
BrokenKitty
Looks good anyone else ??
RE: Spilt audio pipe - 10/2/2008 4:21:17 PM
supergrizz05
i Sent you a Pm on the one Im selling
2005 "special edition" grizzly 660,27" executioners, itp ss112 wheels,snorkled out,alum. bumper cover,extreme 2500 winch,kodiak 450 clutch rollers,homemade stereo, relocated radiator.
2006 honda cbr600f4i,yellow w/titanium trim
http://s285.photobucket.com/albums/ll80/schultzy007/
RE: Spilt audio pipe - 10/2/2008 5:33:00 PM
jakedogg
Devildog, how do the speakers mount inside the PVC? Looks good....This is how I'm gonna do mine since my radiator is in the way.
Brute Force 650 (SRA)
27" Laws on MSA Torks
28" Gators
Fully Snorkeled
Relocated Radiator
Dyna CDI
2" Lift
EPI Lime Green Secondary
Custom Skids & Bumper
Water Temp Gauge
Big Gun Exhaust
(in reply to supergrizz05)
RE: Spilt audio pipe - 10/2/2008 6:26:40 PM
toyazman76
2008 Can AM 800XT Camo. Completly stock temporarily. 2003 Grizzly 660, Snorkeled, Mudbuster cam, Wiseco piston, DIY split audio Tube, 27" laws, EPI clutch Kit, Relocated radiator,Rear G*rilla axles, Temp-gauge, Custom cooler rack.Custom front bumper with Reese hitch.
1992 Banshee-SOLD
(in reply to jakedogg)
RE: Spilt audio pipe - 10/2/2008 6:48:57 PM
toyazman76
This how I built mine
1. bought 2 6" caps and couplings (drainage not sch 40) sch 40 is to expensive.  Bought at Lowes
2. I already had the pipe. I used SDR 35 which is for drainage not pressure.
3. Glued the caps on about 8" of pipe then glued the couplings on all with pvc primer and solvent glue. (length will vary due to diffrent rack sizes)
4. Glued a 2" piece of pipe in the open end of the coupling flush with the coupling end for the speaker screws to bite into
5. Hot glued blocks of wood to the bottom of my phase linear amp I bought from Auto Zone
6. Meaasured  and drilled holes in the bottom of the tube for power supply and to supply second speaker wire.
7. Marked speaker screw holes onto tube and pre-drilled for the screws. Installed amp. hot glue blocks of wood to pipe
8. painted the tubes with bed liner spray paint
9. secured speakers and ran a bead of silicone around them for added protection (remember silicone will not accept paint that is why I painted first)
10. Marine goop'ed at all wire penetrations (marine Goop or Plumbers Goop can be found in the paint section of Home Depot)
Hooked up power and ground wire to battery and second power wire to Aux power port.
I used marine grade Kenwood speakers.
I also put in a in-line fuse between the amp the battery.
The RCA cables would not fit very well at the amp so I bought 90 degree adapters from Radio shack.
Good luck with the build
1992 Banshee-SOLD
(in reply to toyazman76)
RE: Spilt audio pipe - 10/2/2008 6:51:33 PM
toyazman76
1992 Banshee-SOLD
RE: Spilt audio pipe - 10/2/2008 6:56:19 PM
toyazman76
1992 Banshee-SOLD
RE: Spilt audio pipe - 10/2/2008 6:57:57 PM
toyazman76
1992 Banshee-SOLD
RE: Spilt audio pipe - 10/2/2008 7:00:26 PM
toyazman76
1992 Banshee-SOLD
RE: Spilt audio pipe - 10/3/2008 6:34:44 AM
devildog12210
^ Thats how I did mine. Great instructions too. I love mine.
RE: Spilt audio pipe - 10/3/2008 1:34:07 PM
texasfirefighter
if u go to home depot or any hardware store, look for 6 inch pvc cleanout adapters and caps. if u put those on the ends instead of just regular caps u can screw the ends off if u ever need to work on the amp or a speaker or something. its also good to check to c if u have water in the pipe. once u screw the cap on it is completly water tite and its easy to remove. just a hint for something a little different.
2007 Eiger 400 4X4 Manual
3000 Champion Winch
Custom Audio Tube
26" Mud Lites
Custom Snorkel
Uni Filter
RE: Spilt audio pipe - 10/3/2008 5:09:33 PM
toyazman76
Yep I thought of that to but I started adding up all the additional fittings and the cheap mode kicked in. The cleanout adapters and caps I found were sch 40 and were like 8 0r 9 bucks each so I said nope. But definitly a good idea if you want to spend the $$.
1992 Banshee-SOLD
(in reply to texasfirefighter)
