Snorking a foreman 450
All Forums >> [OEM Discussions] >> Honda >> Snorking a foreman 450 Page: [1]
Snorking a foreman 450 - 8/28/2008 4:26:02 PM
Brock42
i was thinking about snorkeling my Foreman 450 and was wondering if u guys had done it and if so what did yal use any help will be greatly appreciated
RE: Snorking a foreman 450 - 8/28/2008 5:14:24 PM
350rancherboy
um...im in the same boat..ima do mine up the fender on the left proly..........start off on 1.2 end in 2" it should look better i think...
2003 Honda 400EX 4-SALE! $2100 OBO
Life is alot like a transmission.You start off in 1st and work your way up through the gears as needed.Final gear is great on the highway,but sucks for coming off the line.
(in reply to Brock42)
RE: Snorking a foreman 450 - 8/28/2008 5:20:49 PM
450ForemanDaniel
This is what I used, but it looks like it would be simple to make.
http://www.highlifter.com/product.php?pk=7469&pname=
03 Foreman 450es
Front-29.5 Swamp Lites
Rear-29.5 Outlaws
itp wheels
2" HL Lift
snorkel (snorkit)
HL spool lock
HMF Utility
HL Lift Springs
14% Gear Reduc.
UNI Filter
Dyno Jet Kit
Viper Max 4000
Strobes and LED's
Reverse Mod
Ammo Boxes
(in reply to 350rancherboy)
RE: Snorking a foreman 450 - 8/28/2008 5:50:46 PM
350rancherboy
I dont wanna buy a kit.ima make mine....but im not cuttin a big hole in the front plastic...goin up the fender..i know somebodys done it..if i go all the way up the fender in 1.5 will it run okay with stock carb. settings..or should i go to 1.5-2" towards the rack and up??
(in reply to 450ForemanDaniel)
RE: Snorking a foreman 450 - 8/28/2008 6:21:15 PM
Badforeman475
List of stuff to buy:
2 45 deg. 2in. PVC elbows
2 90 deg. 2in. PVC elbows
3 threaded 2in couplers
1 2in to 1 1/2 PVC reducer
2 22.5 deg. 1 1/2in. PVC elbows
1 1 1/4 to 1 1/2in. PVC reducer
2in. PVC pipe at least 6ft in length
1 1/2in. PVC 3or4 ft. long
1 1/4in. PVC 3or4 ft. long
You are on your own as far as a mounting bracket goes. Mine is a flat aluminum plate 4x6, with an aluminum threaded pipe welded in the middle of it, at an angle. There are also 2 ubolts that fasten it to the racks.
Start out by taking the 90d elbow, and cut about 3inches of 2in pipe and connect the 90 and the 45. Just dry fit it, at this point. (Do not glue yet).
Next cut another 3in piece of 2in pipe and connect the other 45d. If you look at the pics, I am sure you will see what Aim talking about.
Next you will connect the 1 1/2 to 2in reducer to the 90d elbow. Now cut approx 13in. of 1 1/2in pipe and connect it to the reducer.
Next you will slide the rubber coupler on to the end of the 13in. pipe.
Next cut about 10 1/2inches of 1 1/2in pipe. Now connect one of the 22.5in elbows to one end of the 10.5in pipe. Now cut approx. 2 1/4in of 1.5 pipe and connect it to the other side of the 22.5 elbow. Now connect the other 22.5 elbow to the 2 1/4 pipe. Make sure you look at the pic to see how the bend is.
Next you will connect the 1 1/4 to 1 1/2in reducer to the 22.5 elbow. Now cut approx 5 3/4in of 1 1/4in pipe. This will give you a complete snorkel from under the fender to the air box.
Now you will need to decide how you will come through the fender and how you will secure it to your racks. You will have to trim some fender off to get it to the air box as well as some mud flap. Reference the pictures below on where the snorkel goes through the fender. As far as rejetting goes, I didn’t have to. The instructions that come with the kit this one duplicates said to move the clip on the carb needle down to the first slot. They provided another small washer just like the one that is already on the needle. And it said to put both washers under the clip
I know this sounds like a lot, but in reality it took me about 2 or 3 hours to build. Oh by the way.....all measurements that given were approximates, so double check your own measurements. It will more than likely take you awhile to get the 90 and 45's lined up just right to miss the shocks, so take your time, also the 22.5 elbows have to be just right, so pay close attention there also.
Blue 98 Foreman 450 Geared and locked SS112 wheels 28" Silverbacks
Red 07 Foreman 500 Clutch kit snorkled more to come soon
Pic of my bike http://www.myspace.com/blueforeman450
RE: Snorking a foreman 450 - 8/28/2008 6:22:51 PM
joshua99ta
I wouldnt recommend a triangle to anybody... I had one... its going in the garbage
98 Foreman 400- Tan
31" laws on machined XL2s
getting some much needed improvements
08 PoPo RZR 800, 2" HL Lift, HL springs, diamond plate, winch, 28" Zillas on Chrome 14" SS112's, kick **** sterio and a permanent beer cooler
05 suzuki 'Busa on RC Compenents "OUTLAWS"
www.myspace.com/joshua99ta
(in reply to Badforeman475)
