8upwithmud
The v-twin is more sensitive to air flow than most motors. If you snorkel, you have to rejet. It isn't really hard. I would get a dyno-jet kit. Use the stock needles with two shims on each each needle. Run the dyno-jet springs and I would start with a 122 front main, and a 124 rear main. Mixture screw about two turns out. Should be pretty close.
05 Evil Twin Bored, stroked, camed, ported, polished, piped, jetted, snorkeled, clutched, geared, dynateked, Gorrilla'd, lifted, and lawed. 13 axles 6 motors 6 differentials 1 fan ? belts 04 500M with 28 laws 05 400A with 27 lites 06 Night Rod http://myspace.com/leebo1973 ........................HPAC......................... .............Hard Pack Arctic Cats.............
