Slow 650 H1
Slow 650 H1
All Forums >> [OEM Discussions] >> Arctic Cat >> Slow 650 H1 Page: [1]
Slow 650 H1 - 11/11/2008 9:12:25 PM
Credo
Hey;
I need help I have a 650 H1. This bike doesn't seem to have any of the power it should. I have seen H1's pull the front wheels and mine won't even start to pull the front wheels. I bought the bike with the 29.5's, snorkel, and an HMF. The guy I bought it from said he has never been into the blet case. Do I need to do a secondary mod and a clutch? I was wondering if you guys have any suggestions that I could try.
05 Arctic Cat 650 H1
Radiator Relocated
29.5" Outlaws
HMF Pipe
RE: Slow 650 H1 - 11/11/2008 9:46:33 PM
700Blaze
From: Washington MO. home of B&J CUSTOM FABRICATION
Yep do the secondary mod and that should get you moving in the right direction
"700 CAT"
FULLY CUSTOM BUILT BY
MY SPACE-----MY PHOTOS
THE BOYS OFFROAD CLUB
(in reply to Credo)
RE: Slow 650 H1 - 11/11/2008 9:48:15 PM
Read this it will help you give it some good lowend punch.
http://www.highlifter.com/forum/Secondary_Cage_Mod_for_the_700_EFIs%2c_05-06_650_H1s_%26_500s/m_2783142/tm.htm
08 650H1 LE
Warn 3.0
Snorkeled,Rad racked
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
HL springs, HL spacers
Gorilla axles
29.5 Laws, custom LE wheels
30" MLs, Black Castle Roks
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
26" 589MTs, ITP type 6s
H.ard P.ack A.rctic C.ats
(in reply to 700Blaze)
RE: Slow 650 H1 - 11/11/2008 10:01:10 PM
Credo
Yeah I will prob go into the belt case this weekend? I will prob replace the belt while I am in there what is the part #? Any suggestions on which clutch kit to get? I have read forums about people drilling out the rollers themselves; I think just buying rollers will be safer.
Radiator Relocated
29.5" Outlaws
HMF Pipe
(in reply to GWC)
RE: Slow 650 H1 - 11/11/2008 10:09:01 PM
i am cheap i drilled mine out and i think 19.5 grams is gong to be a great weight for them to be at, shim the primary out to lower the belt and do the cage mod likes in that thread  and the secondary mod as well. then install the wet clutch kit from the 500m to gain alittle stall out of it as well.
or you can buy all the in a kit from EPI or SpeedWerx but it will cost alot more is all.
08 650H1 LE
Warn 3.0
Custom gauges
muffler tweaked
Dyna Tech CDI
Custom clutch kit
4.0 gears
Gorilla axles
05 500m
Hidden Snorkel
muffler tweaked
HL temp gauge
(in reply to Credo)
RE: Slow 650 H1 - 11/11/2008 10:17:16 PM
Credo
A couple of picture of the bike.
Radiator Relocated
29.5" Outlaws
HMF Pipe
(in reply to Credo)
