Should the Belt on My 800 Be This Loose (pics)
All Forums >> [OEM Discussions] >> Polaris >> Should the Belt on My 800 Be This Loose (pics) Page: [1]
Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 11:20:15 AM
rubicon03
i filled the belt housing full of mud and water last weekend so i took it off to clean it all out and my belt has been this loose since i have had it. it has a heelclicker clutch kit and only has 300 miles on the fourwheeler.  i just walked the belt off with just using my hands turning the secondary pulley and put it on with just using my hands. when we took the one off my buddys brute force it was a tight fit walking the belt on and off. the first picture with me squeezing it with my hands i'm using hardly and force.
2007 polaris 800 with the goods
hers yamaha Grizzly with 5.5 Primate lift
Your Satisfaction Is Guaranteed
RE: Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 11:23:01 AM
Solitude
I think that might be close cause I know Polaris belts arent constantly tight like the Yamahas. Looks like its saggin pretty bad in the bottom tho.
06' SLC Lifted King Quad 700 EFI For Sale: http://easttexas.craigslist.org/mcy/960791955.html
94' Honda 300 4x4
EDL's, ITP Black 212's, Lift, Progressive 512 Shocks, DJ Kit, K&N w/ Outerwears, Savant Floorboards, Gear Reduction, EPI Clutch Kit, XP Disk Brakes, Snorkles, Gutted Exhuast, Pro Grips
(in reply to rubicon03)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 11:30:46 AM
Rebel64
Looking REAL loose IMO.
07 800 Stealth
(in reply to Solitude)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 12:03:50 PM
rubicon03
i'm goin to take it to the local popo dealer and compare the belt to a stock one.
(in reply to Rebel64)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 9:31:54 PM
500DUSE
Those clutches could use a good cleaning
08 SP 800 ,
01 SP 500 HO ,
97 425 magnum,
07 Rubicon
RE: Should the Belt on My 800 Be This Loose (pics) - 11/8/2008 9:36:30 PM
contentsunderpressur
It's supposed to be loose with the engine off like that.  Does it slip when you ride it?
03 700 sportsman SOLD
6 in monkey lift
29.5 laws
Progressive spring kit
relocated radiator
snorkeled
1.5 wheel spacers
fender extenders
08 800 sportsman (stealth)
Polaris rear bumper
05 Honda Foreman 500
stock with a snorkel
(in reply to 500DUSE)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/9/2008 9:05:26 AM
rubicon03
not after i put a different primary spring in there. it use to slip in high range on pavement from a dead stop.
(in reply to contentsunderpressur)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/9/2008 9:39:37 AM
Rat
No it should nto be that loose.
Possible causes.
Engine mount broken causing the engine to be shifted rearward
Belt worn too thin, This causes the belt to sit too low in the secondary clutch.
Stretched belt
wrong belt for the application or aftermarket belt
But on all ebs systems the belt should have almost zero deflection (your pics show alot more then zero deflection).
The only polaris CVT systems that don't run a tight belt (zero deflection) are the non ebs models.
....SNORAT....
For further help please direct any question for me, to me at www.atvnation.com
RE: Should the Belt on My 800 Be This Loose (pics) - 11/9/2008 6:22:08 PM
142fast
Rat is right you should not have that much play in the belt. There is something wrong. Check all the things Rat said first.
2005 700 EFI popo
28"Mudlites,and 29.5 laws?
HC,
2" highlifter lift,
800 pri,
Team helix
epi sec spring
1" spacer in front,
1 1/2" in back,
Tunes
2002 500 camo popo
snorkeled intake for belt
27" Mudlites and she also rides my old stock tires from the 700
Check out what I've been up to here
http://4wheelingmn.blogspot.com/
RE: Should the Belt on My 800 Be This Loose (pics) - 11/9/2008 6:30:19 PM
rubicon03
thanks guess i'll start with buying a new belt and see how it is then. the front motor mount was broke but i fixed that a few weeks ago.
(in reply to 142fast)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/9/2008 10:34:06 PM
Rat
If the mount was broken then I would check to make sure the Center to Center distance is still correct as the motor might have shifted rearward while the mount was broken.
....SNORAT....
RE: Should the Belt on My 800 Be This Loose (pics) - 11/10/2008 6:26:22 AM
rubicon03
how do i check that? center to center of the primarys? do i measure from bolt to bolt? what should the distance be? thanks
(in reply to Rat)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/10/2008 6:33:00 AM
SPORTSMAN70003
ORIGINAL: rubicon03
Center of each bolt and the the measurement should be 10".
PICS & VIDEOS
POLARIS 700 W/ 800 ENGINE,TURBOCHARGED,NITROUS,40MM CARB,HEELCLICKER,800 PRIMARY,TEAM ROLLER,CUSTOM MUZZY EXHAUST,28" MUDZILLAS,TORK WHEELS,NERF BARS,OIL & TEMP GAUGES,REVERSE LIGHT,FRONT & REAR BUMPERS,2500LB RAMSEY,K&N FILTER,3"WHEEL SPACERS,HEADLIGHT & REVERSE MOD,2"LIFT,SWAYBAR DISCONNECT,SNORKELED
RE: Should the Belt on My 800 Be This Loose (pics) - 11/10/2008 6:43:27 AM
rubicon03
if the its ten inches then i just need a belt? if its not ten inches what do i need to do? do i move the motor up or the tranny back?
(in reply to SPORTSMAN70003)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/10/2008 6:47:29 AM
SPORTSMAN70003
If you had a broken motor mount before its possible you motor has shifted a little. You can loosen the motor mounts and move the motor where you need it and get the 10".
PICS & VIDEOS
RE: Should the Belt on My 800 Be This Loose (pics) - 11/30/2008 9:45:17 AM
rubicon03
ok from center to center of the primary bolts is ten inches. bought brand new belt and its still just as loose. did they make a non ebs model in 07?
RE: Should the Belt on My 800 Be This Loose (pics) - 11/30/2008 9:52:43 AM
honda/polaris
did you start the bike after you put it on. when you just put it on it will be loose. if you start the bike and rev it a bit it should tighten up.
2008 Polaris Sportsman 800 EFI - Polaris LE wheels, 2500# Polaris winch, front Polaris rack extender, Polaris hand guards, reverse override
Pics/Vids
RE: Should the Belt on My 800 Be This Loose (pics) - 11/30/2008 5:05:02 PM
rubicon03
i did i left the cover off rode it down the road came back and still loose. after the new belt though in low range i can ride wheelies it wouldnt do that with the old belt.
(in reply to honda/polaris)
RE: Should the Belt on My 800 Be This Loose (pics) - 11/30/2008 6:17:53 PM
UnderwaterGrizzly
My 700 did this same thing once, Found that the secondary clutch wasn't returning completely to the "idle" or no load position, I disassembled and cleaned it up, has been working perfect ever since.
RE: Should the Belt on My 800 Be This Loose (pics) - 12/8/2008 6:38:04 AM
rubicon03
so i figured out i have a non ebs popo. so is this normal for a non ebs?
(in reply to UnderwaterGrizzly)
